Engine Dyno testing of Renesis
Old Apr 21, 2006 | 04:20 PM
  #26
Rasputin's Avatar
To stop the controversy, I would just mention that the European Power Homologation Test is a witnessed test, by an official authority. All engines manufactured under this homologation must meet peak power and torque within +/- 5% (at engine speeds meeting the same tolerance). The European authorities can, and do check engine taken from the production line.
I think I read somewhere on this forum that the US Certification test is of the same type now. Before, anything could be, and was, advertised. I should know, I ran the Certification test of the Ford Focus 2.0 and Ford Escape 2.0. In UK. No witness.
See this article I wrote a few years ago about this : http://www.enginepsd.com/techpages/TP0301.pdf
Fabrice
Old Apr 21, 2006 | 04:24 PM
  #27
Gomez's Avatar
Shifty Bastard.
Originally Posted by TeamRX8
how about locking this thread for results only so we don't end up with 50 pages of inane, pointless posts to dig through for the occasional gold nugget
How about you stop postwhoring with your negative comments all the time?
Let the thread run free, Hymee .
Old Apr 21, 2006 | 04:25 PM
  #28
brillo's Avatar
Go Texas Longhorns!
Iwas just hoping it wouldbe possible to test the engine with the stock PCM on your latest flash down under, but that sounds like that won't be possible.
So, I wish you luck, given what I'm seeing on some of the interceptor NA tunes, 250 isn't out of the question.
Old Apr 21, 2006 | 04:30 PM
  #29
Rasputin's Avatar
One can always approximate the OEM set-up by using same fuelling / spark advance and other engine parameters with the stand-alone ECU.
F
Old Apr 21, 2006 | 04:53 PM
  #30
Hymee's Avatar
Race Steward
Of course it is possible. I could (as the esteemed Rasputin mentioned) run a cable out to the chassis, parked 5m from the dyno cell, "fake" the wheel speed sensors, and off I go. But I gotta ask myself the question... for all the cost that incurrs, what does it give me? When at the end of the day, I have gathered all my development data on the engine dyno, and then I can compare that to baseline chassis dyno results for a stock car, then with whatever mods I like, using the same brand/manufacturer of dyno/dyno software and everything. What would it give me? Not much.
Like Rasputin said, with the sCANalyser, we have the technology to map out the basic fuelling and timing characteristics of the stock PCM. Then we can put a "equivalent" tune up in the MoTeC - i.e. achieve the same timing advance as stock, and the same Lambda readings (Air Fuel Ratios) as stock. What then is the difference?
Cheers,
Hymee.
Old Apr 21, 2006 | 04:57 PM
  #31
Nemesis8's Avatar
Bigus Rotus
Did you guys lift the Renesis up by hand when you installed it on the dyno? That would have blow awy the V8 guys waiting I bet. How many days did they give you to finish your work?
Old Apr 21, 2006 | 06:35 PM
  #32
Hymee's Avatar
Race Steward
What do you mean "you guys"?? I did it by myself :p
Old Apr 24, 2006 | 07:12 AM
  #33
SomeGuy_sg's Avatar
Thread booked marked .
And the V8 F1 engien was sweet. I love the way you can see the injectors spraying fueling on the the bell mouth , sucked in by the engine :P
Old Apr 24, 2006 | 07:29 AM
  #34
Hymee's Avatar
Race Steward
Yeah - I get a 1/2 moungrel every time I watch that clip.
Old Apr 24, 2006 | 06:48 PM
  #35
Muzz's Avatar
I dont think 'they' will know what that means Hymee
Old Apr 26, 2006 | 09:48 AM
  #36
Glyphon's Avatar
脾臓が痛みました
i think we can figure it out
Old May 13, 2006 | 12:47 PM
  #37
Hymee's Avatar
Race Steward
Its running...
We got the engine started the other night. Just ran it for a couple of minutes to make sure we are ready for the trip to the engine dyno.
I took video, but the "studio" was less than ideal. It really needed some more light, as the engine was sitting against a dark backdrop of race car tires.
But at least it shows it running, all by it's little self...
http://www.hymee.com/videos/RenesisRunning_s.wmv (8MB)
I've got a larger resolution version I am just trying to get uploaded (with some difficulty )
If you look carefully, there are a couple of instances of the flames coming out of the exhaust. Try at about the 1min 10s and 1:25 marks. Pity I didnt have a dark background behind the 'zaust!
Cheers,
Hymee.
Old May 13, 2006 | 01:03 PM
  #38
Bart!'s Avatar
RAWR!@#
Okay so, what are the results.
Old May 13, 2006 | 06:16 PM
  #39
SlayerRX8's Avatar
'03 Dodge Viper
He just said he was making sure it's ready for the dyno. That doesn't mean he's done it yet!
Old May 13, 2006 | 08:35 PM
  #40
Bart!'s Avatar
RAWR!@#
Yeah I know, I was being semi-sarcastic.. 3 pages and nothing. Just kidding Hymee.
Old May 13, 2006 | 08:54 PM
  #41
Hymee's Avatar
Race Steward
You'll keep.
Old May 13, 2006 | 09:10 PM
  #42
maikelnait's Avatar
I'd wager, with the motec, it's just gonna be where expected. I managed to almost get 220 flywheel Hp with the stock ecu (ABS lights on when dynoing).
The Renesis seems to be a pretty formula one engine, I mean high rpm performance.
When in high rpms (Dyno time) it seems to hold back a little (Which I never get with normal driving).
Thing is, my dyno graph showed the renesis coming alive from 6.200 to 8.500 rpm. No twin-turbo REW, BTW.
The renesis shows it is managed by a pretty conservative ECU. Mazda has really held back the potential through PCM maps. I am really positive on that.
Bottom line is, the Renesis can actually even cope with REW performance, although emissions standards have kept it from being engine of the year all along. I mean HP not torque, the REW has torque the Renesis can never dream of.
Remember Torque moves cars, Hp just sell 'em...
Old May 14, 2006 | 01:02 AM
  #43
Hymee's Avatar
Race Steward
Lets not start that one again!
Cheers,
Hymee.
Old May 14, 2006 | 01:09 AM
  #44
rotarygod's Avatar
Cheers,
Hymee.
He still hasn't figured out that more torque is also more horsepower and that's what moves cars.
Old May 14, 2006 | 01:19 AM
  #45
Hybridesque's Avatar
horsepower is just torque higher up in the rev range.
Old May 14, 2006 | 04:10 AM
  #46
MazdaManiac's Avatar
^^ Ugh. I love the basment of the science building...
Torque is force. HP is work. One references time, the other does not. You can "real-world" the difference to death but it won't change the math.
BTW - I watched that video and it made my skin crawl. You ran that thing up to operating temp and gave it an Italian tune-up without any coolant?
I guess your thinking is impared by having that open exhaust indoors...
Here in the states we call that hillbilly engineering.
Old May 14, 2006 | 04:24 AM
  #47
yiksing's Avatar
the giant tastetickles
Isn't HP is how long you can apply the torque RPM wise?
Old May 14, 2006 | 04:45 AM
  #48
http://en.wikipedia.org/wiki/Horsepo...ip_with_torque
Essentially, horse-power is about how fast you can spin it.. torque is about how hard you can spin it. The Renesis revs pretty high to make that 230 hp (flywheel), to 8500rpm on the paper figures.
Old May 14, 2006 | 08:23 AM
  #49
Hymee's Avatar
Race Steward
Since you have given it to me, I guess I deserve the right of reply.
The total length of time it ran was what was on the vid. No load. Not enough temp to need coolant for those couple of minutes. It wasn't a tuning session. As you could see, the tune up we had was enough to make it start and run, and free rev a little. It was purely a brief excercise to ensure we could start it, so that when we got to the engine dyno we didn't waste any time.
I'd ask you to show more respect, not just to me, but moreso to someone who is too modest to get on the internet and brag about thier own achievements.
Down-under we use the term "******" on the odd occasion. I'd hate to see it applied to you for some loose comments you made.
Cheers,
Hymee.
Old May 14, 2006 | 08:28 AM
  #50
only one solution to this .....
THUNDERDOME!!!!!
may the best man win ...
