How hard would it be to install an exhaust system for a noob to exhaust?
Old Nov 3, 2009 | 05:39 PM
  #26
jessedrifter's Avatar
so cal
Originally Posted by xun4gvn4everx
First I backed the car up on ramps. Next, unbolted the OEM catback from the midpipe. Second, I removed the shrouds so as not to damage them. Then, I used two large screw drivers, one medium sized screw driver, and a lot of WD-40 to get the muffler out of the four rubber hangers. When I did it by myself, I used a jack to support the muffler. When I did Leshil's, I had him hold up the one side of the muffler after I released it from the hangers as I was taking out the other side. Then lastly, I pulled the last hanger bar (or whatever you call it) out the rubber hanger that supports the pipe between the muffler and cat. Then reverse for install.
thanks alot man. is there any way to unbolt the muffler from the oem midpipe and and leave the muffler on. (so it looks like i have a muffler but its really not used)???
thanks unforgiven : )
Old Nov 3, 2009 | 05:46 PM
  #27
xun4gvn4everx's Avatar
True love is blue x2
Technically, yes. But, the pipe that goes from the muffler to the cat is usually pinched pretty tight (it actually pinches the medal piping on the muffler and pipe together) with a U-clamp and is usually rusted since it is bare metal, so it is hard to get the two separated. Aftermarket catbacks bolt the muffler to the pipe (at least the three I have installed were), so there is no U-clamp to pinch the metal. So if you wanted to do that, an after market catback would be the easiest unless you just sawzaw the pipe on the OEM muffler.
Old Nov 3, 2009 | 05:48 PM
  #28
so cal
:0 thanks bro really appreciate it.. like i was trying to take off my muffler today and i couldnt get that damn thing off haha it was stuck in the pipe. ughh
Old Nov 3, 2009 | 05:54 PM
  #29
No problem bro. Taking off the muffler is a biotch the first time you do it, but then you get the hang of it so it is easier each time there after. The second exhaust I also did by myself and it took me only 45 minutes to take off the OEM and install the RB catback. Of course it was a little easier because it was an R3 so there were no shrouds to remove and nothing was rusted.
As for separating the OEM muffler from it's pipe, good luck!!
Old Nov 3, 2009 | 05:59 PM
  #30
so cal
damn youuuuu hahaha :p
Old Nov 3, 2009 | 06:05 PM
  #31
Old Nov 3, 2009 | 06:06 PM
  #32
Spinning Sushi's Avatar
I <3 Sushi
Advice: Hack Saw
That is all.
Old Nov 3, 2009 | 06:13 PM
  #33
so cal
i dont want to do that though. im not a licensed welder if i wanted it stock. and id rather save the hack saws for "left 4 dead 2".
what about resonatorsss...have u ever took it off unforgiven?
or john?
Old Nov 4, 2009 | 12:23 AM
  #34
Are you referring to the midpipe? If so, then yes. I took off my cat and installed a gutted supercat. It is fairly easy. You have to unbolt the cross member that runs perpendicular under the midpipe and then unbolt the three bolts that attach the midpipe to the headers. I jacked up the passenger side of the car and put jack stands under it to access the pipe.
Old Nov 4, 2009 | 12:28 AM
  #35
so cal
thanks again man
u might just be the reverend haha
Old Nov 4, 2009 | 08:51 AM
  #36
Huey52's Avatar
Registered Zoom Zoomer
I would recommend you first remove the black plastic exhaust surrounds (aka rear bumper guards). Easy one screw and plastic tabs affixed. Precludes any potential for damage and at ~$50 ea. for a surround good insurance.
ref: https://www.rx8club.com/showthread.p...Bumper+Removal
Old Nov 4, 2009 | 09:55 AM
  #37
L337fpc's Avatar
ლ(ಠ益ಠლ)
WD-40, 2 flat heads <- Hangers
WD-40 and 12mm and 14mm sockets for the exhaust bolts. I got a racheting torque wrench, makes getting the hard to reach exhaust bolts easy to get out.
IMO, i'd take your time and plan for set backs. I had to deal with siezed rusted bolts...talk about your set back.
Old Nov 4, 2009 | 10:19 AM
  #38
so cal
^^^thanks man will do
Old Nov 4, 2009 | 10:21 AM
  #39
L337fpc's Avatar
ლ(ಠ益ಠლ)
On more thing. For god's sake, take your time! I can't tell you how many times I stripped bolts because I was careless. If you take your time, you'll be fine.
Also, +1 for an extra set of hands.
Old Nov 4, 2009 | 10:22 AM
  #40
so cal
Old Nov 4, 2009 | 11:22 AM
  #41
Old Nov 4, 2009 | 02:38 PM
  #42
Mazurfer's Avatar
Surf Hard, Drive Hard
^ That was the joke
Yup.....I know!
Old Nov 4, 2009 | 03:09 PM
  #43
Originally Posted by Mazurfer
Yup.....I know!
Old Nov 4, 2009 | 03:15 PM
  #44
Mazurfer's Avatar
^....+1
If you doing this by yourself(as I did), then you almost have to take these off to give you just a little more room to operate!
Just don't break the tabs.....be careful.
Old Nov 4, 2009 | 03:20 PM
  #45
^ Trying to not break the tabs was the hardest part. On mine, I broke quite a few getting the shrouds out. It was an 04 so I think the tabs were a little brittle from age. When I took off Leshil's shrouds on his 07, I didn't even break one.
Old Nov 4, 2009 | 03:44 PM
  #46
Huey52's Avatar
I bent/broke one tab, but JB Weld to the rescue. "Tab A into slot B."
^....+1
Old Nov 4, 2009 | 03:49 PM
  #47
Mazurfer's Avatar
Actually I changed my exhaust out when the car was almost brand new, so no issues with tabs, rust, or bolts. Only issue I had was slightly with the hangers until I figured that out.
Old Nov 4, 2009 | 04:35 PM
  #48
^ Never thought I would need lube to get my rod "out" of a hole......
Old Nov 28, 2009 | 09:08 PM
  #49
uncleant's Avatar
Eat Sleep Drive
http://www.myrotarycar.com/portal/fo...3le/index.html
Old Nov 28, 2009 | 09:09 PM
  #50
uncleant's Avatar
Eat Sleep Drive
click on engine.. then exhaust system then EXHAUST SYSTEM REMOVAL/INSTALLATION and there you go step by step!
RXeckless
Aug 16, 2015 12:51 PM
akagc
Aug 11, 2015 07:07 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
