DIY: Better Flowing Intake Box (Similar to RB Intake Box)
Old Sep 24, 2009 | 12:03 PM
  #401
Nabisco's Avatar
noobie
I'm not expecting much at all. I am just curious as to see how efficient the factory air box really is.
For the sake of reusing it, I'm switching to an AEM filter.
I can't justify spending $300.00 on an intake when I can save for a BHR mid pipe and an AP tune. :-)
My RX-8 is a blast to drive the way it is. I really love this car.
Old Oct 29, 2009 | 05:04 PM
  #402
SayNoToPistons's Avatar
Wheels, not rims!!
Originally Posted by Renesis SE3P
I can't seem to find the exact post that states how to reset the ECU.
There are a couple of procedures and consists of two phases.
Step 1: Warm up your car
Step 2: Turn it off, take out the key.
Step 3: Put the key back in, turn it to the ON position but do not start the car.
Step 4: Step on the brake pedal 20 times or until you see your oil pressure gauge sweep up and back down.
Step 5: Take out the key.
PHASE ONE COMPLETE!
Step 1: Put the key back in.
Step 2: Hold down on the Trip Meter Reset button (DO NOT LET GO)
Step 3: Turn the ignition to on, do not start the car.
Now, the Trip Meter should read TEST.
Step 4: Turn off the car and take out the key.
Step 5: START THE CAR. Drive around for about 15 minutes so the ECU will relearn everything. CONGRATULATIONS!
Win post is win
Old Nov 11, 2009 | 12:29 PM
  #403
treitz's Avatar
Cool. I am excited to try this. I couldn't bring myself to spend $300+ on cold air intake. This should be a nice cheap little fix.
Old Nov 19, 2009 | 09:58 PM
  #404
fedno5's Avatar
Jordan
cheaper options
for those of us who dont have the 145 to spend on the RB duct im sure u can go to your local muffler shop and just cut and bend a tube that would fit in place of the Vfad and a simple flange could be used to bolt on to the airbox this will run u maybe $50 depending on the shop owner. and you can tailor fit it to be as low or high off the ground as u like so no "hydro-locking" problems which is hard enough to do in a rotary
i do have a question after taking out the walls of the airbox and the screens... will reseting the ECU add any power or make it smoother? or will it just do nothing?
Old Nov 20, 2009 | 07:17 AM
  #405
alnielsen's Avatar
The ECU will just return to it's normal settings after a couple of driving cycles.
The whole idea behind the RB duct is to take the air input from a large opening and force it through a smaller hole into the air box. This, in theory at some point, will reduce the engine suction through the intake. Your solution doesn't provide for that.
Old Nov 20, 2009 | 08:24 AM
  #406
Huey52's Avatar
Registered Zoom Zoomer
I've had the Brettus-inspired RB duct mated to my stock airbox, with plastic baffles removed, and K&N flat filter installed, for a season now and can highly recommend it. $185 USD out of pocket very well spent. Of course you have to remove the relatively useless VFAD.
I didn't remove either of the two intake screens as I believe they have a job to do smoothing out the airflow passing the MAF.
Old Dec 1, 2009 | 02:45 AM
  #407
fedno5's Avatar
Jordan
FL
Originally Posted by Solidtrance
I also cut most of the top off, and replaced it with plexi. I've seen this done a few times. Most of the others I have seen are a little better than what I ended up with. Just another idea.
what did cutting the top do for u,,, EG: sound, power.... i like the way it looks but is it more form then function? i did my walls and screens... it didnt do much but after i removed the VFAD i felt a little more low end torque and slightly louder intake sound...might be placebo or even the fact that a cold front hit miami earlier this week and the car was flying anyway ... i left the tube from the Vfad and took out only the actual unit that closed of the tube...i also havent installed the K&n filter yet so i know ill gain more MPG and sound when i get rid of my nasty old filter... i def. need one...
Old Dec 1, 2009 | 02:47 PM
  #408
Wheels, not rims!!
Have been driving my RX8 with both walls removed and one screen removed for over a month. No increase in performance and the increase in sound is almost unnoticeable. Very small increase in sound while cruising ~3500 RPM on the highway. One thing I did notice was that it took away most of the jerkiness I get in RPMs below 2k in first and second gear, enough to make me stall twice the first day I did the mod because it was so smooth.
Old Dec 17, 2009 | 11:06 PM
  #409
Myriad's Avatar
did this mod today when i was replacing stock filter with k&n drop in, removed both of the plastic pieces in the box, but left both screens in. Drove about 50 miles today, no idle issues, very very slight change in sound (probably filter related), overall not much difference that I can notice but hey it can't hurt.
Old Mar 17, 2010 | 08:36 AM
  #410
catalan's Avatar
removed the both walls/baffles today and tried to remove the horn to get to the first screen, but was unsuccessful. i tried warming it up then taking a flat head to pry it open, but it felt as if i was doing more harm to the horn than good. any suggestions?
Old Mar 17, 2010 | 08:54 AM
  #411
redcopper06's Avatar
'06 copper red shinka #66
i believe the purpose of the screens is just to prevent large debris getting inside. a screw would be deadly. a bug or piece of plastic wouldnt be so bad.
keeping 1 screen is probably worth it.
Old Mar 17, 2010 | 08:56 AM
  #412
catalan's Avatar
yeah, my plan was to leave on the screen near the MAF like many suggested, but i was unable to remove the horn to get to the screen. trying to find some solutions besides just cutting it out for a clean removal and just in case the idle is rough.
Old Mar 17, 2010 | 09:25 AM
  #413
JinDesu's Avatar
went back to srsly broke
The MAIN purpose of the screens are to smooth the airflow. The fact that they may catch large debris is a side-effect. If you honestly have something that can punch through your filter, especially the K&N, then those screens will come into play.
Old Mar 17, 2010 | 12:47 PM
  #414
rotarygod's Avatar
If you have something large enough to punch through your air filter, it's going straight through those screens too!
Old Mar 17, 2010 | 01:46 PM
  #415
JinDesu's Avatar
Not always true, RG. Them squirrels can go through that air filter like nothing, but they usually don't go much further!
Old Mar 17, 2010 | 05:02 PM
  #416
StrifeX's Avatar
Just did this mod (only the first screen and plastic things). Car idles much smoother. Gonna pick up K&N filter tomorrow. Is the filter worth it?
Old Mar 18, 2010 | 01:41 AM
  #417
catalan's Avatar
Any tips on how to remove the horn? I tried earlier today and failed. I took a flathead to it, but i didnt want to dmg the horn too much so i stopped.
Old Mar 18, 2010 | 01:42 AM
  #418
shaunv74's Avatar
Power!!
Cutting out the horn to remove the screen is like cutting off your ***** because you think it gets in the way of delivering sperm from your ***** to a girl's vagina.
Old Mar 18, 2010 | 01:55 AM
  #419
catalan's Avatar
uh i meant just ghetto cutting the screen so just incase my idle is rough i can always reinstall it. wouldnt cut the horn as i read in this thread it helps air flow.
Old Mar 18, 2010 | 04:18 AM
  #420
WTBRotary!'s Avatar
Drummond Built
Old Mar 18, 2010 | 06:50 AM
  #421
JinDesu's Avatar
I'm pretty sure the horn is held on by two screws. If you mean the screen itself, I don't know. You can take out the horn and get a better look at the screen, I suppose.
Old Mar 18, 2010 | 07:40 AM
  #422
discomonkey's Avatar
Ok so what's the going anserw right now to remove one wall or both?
Old Mar 18, 2010 | 07:43 AM
  #423
alnielsen's Avatar
Originally Posted by discomonkey
Ok so what's the going answer right now to remove one wall or both?
Remove one. However, most that have removed both have had no problems.
Old Mar 18, 2010 | 08:53 AM
  #424
xsnipersgox's Avatar
One Shot One Kill
i've had no problem with both removed. hell i really don't even know where the dividers are anymore.
Old Mar 18, 2010 | 09:48 AM
  #425
I have been skimming the pages and there are screens and baffles? What should I remove?
