Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
Stainless Steel Clutch Line - Same as Series I?
Old May 17, 2012 | 04:49 PM
Chris_Bangle's Avatar
I had this on my 05. Improved feel and engagement.
Anyone knows if the part is the same for series I and II. I called a few places and it seems that series I may be different from series II in that respect.
Want to weld/reinforce the clutch pedal and put this on as preventative measure.
Thanks for you help.
Old May 17, 2012 | 04:53 PM
Yes, it will work fine. But you can PM Ash8 for confirmation.
Old May 18, 2012 | 09:35 AM
^ Are you speaking from experience? I will try pm'n ash8.
Old May 18, 2012 | 09:41 AM
Well my buddy (houstonrx8er) has a 2010 tranny in his 04' and I don't recall him needing a new clutch line. I'm 99.9% sure the line is interchangeable. I also have a 2009 tranny sitting in my garage and i don't see how the line would be any different.
Old May 18, 2012 | 10:42 AM
laurichj's Avatar
Speaking from experience, it's the same. I put https://www.rx8club.com/series-ii-diy-161/diy-clutch-brake-line-replacement-bleeding-231802/ in the diy forum but it's the same as S1. The only things that are different is the oil filter moved so that's no longer useful as a reference point.
I recommend putting a speed bleeder on the slave since there's limited room there. I didn't and it sucked.
Old May 18, 2012 | 10:53 AM
Yes, it sucks bleeding it with the everything on the engine.
Old May 18, 2012 | 03:06 PM
Originally Posted by laurichj
Speaking from experience, it's the same. I put https://www.rx8club.com/showthread.php?t=231802 in the diy forum but it's the same as S1. The only things that are different is the oil filter moved so that's no longer useful as a reference point.
Thanks. Which line did you get?
Old May 19, 2012 | 04:55 AM
ASH8's Avatar
Super Moderator
YES, hydraulic flexible Clutch Line Hose is the same for ALL Series RX-8's and is actually the same Mazda Part Number for ALL NC MX-5/Miata's.
Old May 19, 2012 | 11:03 AM
laurichj's Avatar
Got it and SS brake lines from thmotorsports.
BigMikeATL
May 26, 2016 12:31 AM
fireishot34
Sep 11, 2015 12:54 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
AussieGray
Jul 16, 2015 03:58 AM
