Gas/Oil Premix Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old Feb 3, 2012 | 10:52 PM
  #3376
swoope's Avatar
Zoom-Freakin'-Zoom
Originally Posted by PeteInLongBeach
I still have almost 2 gallons left when the light comes on, and I have often run it down to this level (I usually fill-up when it's down to 1/8 tank). No problems with fuel delivery or the pump in 50,000 miles, so I don't consider this an issue.
Also, I think premixing the premix before adding it to the tank is a bit of overkill. I've been premixing since the car was new by just adding it to the tank before each fillup - no issues.
when it hits yellow you really have 2.5 gal left.
if you dont track your car you will never have an issue..
premix or not..
Old Feb 3, 2012 | 10:56 PM
  #3377
swoope's Avatar
Zoom-Freakin'-Zoom
Originally Posted by Brettus
I ALWAYS run it into the yellow and below the empty mark . Then I dump in the premix and fill her up .
Been doing this for 5 years now.
Hi Swoope
yep,
but your racetracks run backwards!!!! i bet your get fuel starve in right hand turns.
or your weird rhd cars have different fuel pumps..
Old Feb 5, 2012 | 06:40 PM
  #3378
GK1707's Avatar
At my local Autozone (which i also happen to work at) we have a limited selection of 2 stroke oil. The lucas semi synthetic we sell in 2.6oz conatiners which is tiny and insanely expensive $2.49. We also have valvoline outboard 2 cycle which is mostly for marine engines and we have Coastal tc-w3 multi purpose 2 cycle oil.
Should i try the Coastal since its multi purpose and sounds like my best option (it comes in a quart). Has anyone tried Coastal 2 cycle? How is it compared to the other premixes and does brand really matter since i hear idemitsu is the best because its formulated for rotaries. I dont really have access to the idemitsu and dont want to order a whole case since i just want to premix occasionally i think buying quarts would be my best solution.
Old Feb 5, 2012 | 09:27 PM
  #3379
Premixing occasionally is pointless. Heck there really isn't any scientific data to show using it all the time even prolongs engine life in a street car. Look up the MSDS sheet of the Coastal and compare it to Idemitsu. It it is T3CW then don't use it if you have a cat.
Old Feb 10, 2012 | 09:30 PM
  #3380
Chino_rx3's Avatar
Gulf Coast Rotaries
FL premix
I buy Idemitsu by the case (lasts about 18 months for me) locally at MazdaTrix. 1 case @ $67 = 1 quart @ $5.58.
wow it last 18 months I think im ordering this once my car is running where i want it, how much do you guys put on each tank I was trying to read but make it simple im slow lol
Old Feb 10, 2012 | 09:59 PM
  #3381
Darkning's Avatar
I think 4-6oz per tank is the general consensus for non-track purpose. Moreso if you're on the track.
Old Feb 10, 2012 | 10:46 PM
  #3382
Originally Posted by swoope
yep,
all to do with the way our toilets swirl in the opposite direction to yours .
Old Feb 11, 2012 | 10:58 AM
  #3383
Chino_rx3's Avatar
Gulf Coast Rotaries
ok sounds good I never have used premix on my previous rotaries Just Royal Purple 20-50 and I ve been happy with results `
Old Feb 12, 2012 | 03:39 AM
  #3384
Anubis88's Avatar
I'm adding to fuel 8,4 OZ motul 710 2t my premix is for a full tank. I thing adding premix to fuel will help this rotary engine everytime when I go to 9500prm
I'm not running at track.
Old Feb 12, 2012 | 10:08 PM
  #3385
swoope's Avatar
Zoom-Freakin'-Zoom
so you are saying premixing while you are at a track event is pointless?
Old Feb 12, 2012 | 10:12 PM
  #3386
swoope's Avatar
Zoom-Freakin'-Zoom
no Coriolis effect on racetracks i think? think is you drivers seats are on the wrong side..
btw, brettus. might suck to be you soon! rules have changed..
Old Feb 14, 2012 | 05:25 PM
  #3387
DZ808's Avatar
Hi Guise,
thanks in advance if you have any input. for my questions. I have a 2005 RX8 that just got the engine and cat replaced at 64k miles by mazda. I lucked out as it failed smog recently when i moved to CA and came in under warranty for replacement of both. Though from the sounds of it you guys don't like the mazda factory reman engines.
I would like this engine to last longer than the original (i know maybe wishful thining since a mazda reman)so I want to do the premix and am thinking about doing the Idemitsu. I had never done it before on my original engine.
Will doing premix wear out my new cat faster? If I should remove the cat and save it for only smog tests and replace with cat bypass what kind of trouble can I get in here in CA?
again thanks
Old Feb 14, 2012 | 05:28 PM
  #3388
shadycrew31's Avatar
WENTGERMAN
Originally Posted by DZ808
Hi Guise,
again thanks
As long as you don't speed around like Vin Diesel you should be fine. Every now and a again you'll run into an a-hole cop that will look under the car. but usually they leave 8's and other nice looking cars alone.
Old Feb 14, 2012 | 08:34 PM
  #3389
xexok's Avatar
I would be a little worried about going catless in california since they are so serious about smog. It is a huge federal fine to be caught, I just don't know what a cop would actually do since they are state level. Probably just make you take it in for a smog test, but if you were a repeat offender they may catch on. If your midpipe has a resonator on it you could just say one of those is the cat.
Anyone ever had the misfortune of a cop inspecting your car, and finding no cat? What happened to you?
Old Feb 15, 2012 | 09:24 AM
  #3390
gwilliams6's Avatar
40th anniversary Edition
premixing will not do any harm to your cat. Proper premix will be combusted in your engine, long before it could get to your cat. Why risk going catless and face fines and also risk loss of your auto insurance if caught (yes that has happened in some states). The modest hp boost from less restrictive exhaust is NOT worth the problems.
40th anniversary edition RX8
Seven rotary RXs since 1973
Old Feb 15, 2012 | 09:38 AM
  #3391
MS Addict's Avatar
Needz moar Mazdaspeed.
That's the way I do it. I prefill a bunch of these (similar anyway) 8 oz bottles with Idemitsu and keep a couple in the trunk at all times. I use Idemitsu in the SOHN reservoir and in the tank.
I used to do that, until those bottles started leaking, haha. Now I just have a quart of that, and Idemitsu engine oil strapped where the flat tire kit used to be.
I'm too lazy to look around, but have you posted any pics of where you put the reservoir?
Just curious as to other people's set ups. I still need/intend to put one in, as well as a catch can.
Old Feb 15, 2012 | 10:17 AM
  #3392
xexok's Avatar
I guess it just depends on where you live. I still have not seen anyone who has actually gotten a ticket or fine for it. So far have not had any problems yet, even the emissions tester guy didn't say anything. He was crouched down by my door to attach his obd2 connector and when he started the car I could smell the exhaust standing a few feet behind him, so I know he could smell it.
Also premix can harm your cat, if you use the wrong type. If someone were to start reading this thread and get only through the first few pages they would see marine 2 stroke as recommended. If they use that they will end up messing up their cat, according to posts later on in this thread.
Anyway I am more worried about the car itself toasting the cat. I would much rather not have to deal with that particular issue with this car.
Old Feb 15, 2012 | 11:02 AM
  #3393
paimon.soror's Avatar
heres my question though, i assume you are running with the CEL on a normal basis since us S2 guys don't have a means of masking. So how exactly are you made aware of any other queued up MIL codes?
Old Feb 15, 2012 | 01:04 PM
  #3394
xexok's Avatar
Now I just check whenever I get a cel, and then delete it. When I didn't have an obd2 scanner I just checked weekly at autozone(or whenever the cel popped up), which is honestly not the best option. So far there have only been 2 or 3 cels, p0420(cat) and one for the o2 sensor on the midpipe I forget what the other one was.
Since my last cel reset I have gone over 550 miles, and today my cel finally came back on. So sometimes it can be off for half a month or more. Sometimes it comes back within a few days, seems random.
Old Feb 15, 2012 | 01:30 PM
  #3395
maxchao's Avatar
How about put the bad one on just for driving around. If you got it from the dealer when they changed it.
I totally forgot the reman might not last as long as the orig. I just wish I can get 100k out of my reman.
Old Feb 16, 2012 | 08:04 AM
  #3396
gwilliams6's Avatar
Note: I said proper premix won't harm your car . If you use just plain old marine 2 oil it won't lubricate the seals properly or combust fully in the engine, Use only premix designed and tested in rotary engines like Pettit Racing's Protek-R and the Idemitsu. I know some of the RX owners here have removed their cats and gotten away with it. I live on the East Coast and here in New Jersey drivers have been fined and lost their insurance for going catless.
If you love to live dangerously go ahead and remove the cat, the benefit is small and the risk large. With proper care and use, the rotary engine will not fry the cat. I have had past RXs with original cats with over 100,000 miles on the odometer.
Old Feb 16, 2012 | 08:09 AM
  #3397
bse50's Avatar
You don't need a wankel specific premix, just a good premix. Do you think pettit has its own lubricant? Protek is just rebranded 2 stroke oil, a simple google search will tell you exactly which one.
Old Feb 16, 2012 | 08:17 AM
  #3398
bse just let it go man...
Old Feb 16, 2012 | 08:20 AM
  #3399
bse50's Avatar
You're right... we'll have to blame it on freedom of speech.
Old Feb 16, 2012 | 08:21 AM
  #3400
fuztupnz's Avatar
Phone Booth'd
bse: He's driven trillions of rotary miles with his 1000 different rx cars over the last 100 years.
How do you compete with that?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
