Non-Rotary Swaps Engine Swap Forum
383 Stroker RX8 hoping for 500+ hp and tq buld.
Old Mar 19, 2010 | 10:23 AM
  #76
olddragger's Avatar
Dude have you ran solid mounts on a high tq/hp car before? With the cam you are running and the power you will be playing with--sooner or later something is going to give. Not critizing now--please understand. But the vibrations are going to break something--- especially with a PPF setup. You also will be more likely to bend something.
Figue out a way to put some polys in there? And more of them. 3 mounts instead of 2?
OD
Old Mar 19, 2010 | 10:52 AM
  #77
This thread makes me wanna cry, a carbed small block in an RX8? To each his own I guess.
Old Mar 19, 2010 | 10:54 AM
  #78
mscamp02's Avatar
Blue Bullet?
^really?
I find it very cool and cant wait to see it finished
Old Mar 19, 2010 | 11:03 AM
  #79
I dunno, to me it just won't work. I don't see this project ever being successful. There are just some swap that should never be done. IMO, anyway.
But if we all did the same things it would be no fun anyway so good luck and hopefully I am proven wrong.
Old Mar 19, 2010 | 12:20 PM
  #80
mscamp02's Avatar
Blue Bullet?
He may have some problems with the electronics of the 8 and all of the modern gauges and wiring harness but even if those dont all completely work correctly I still think the car will run with the 383
Old Mar 20, 2010 | 10:22 AM
  #81
outinnowhere3193's Avatar
outinnowhere3193
OD
Yeah I've gave a lot of thought about the bracing. I've added a lot of solid metal to the front end. Some are terrible worried about weight gain but I'm personally not. I've got the two mounts in the front there... I'm making braces that run towards the back...that run back down to the sub-frame. Then I have plans for a brace from the strut mount to the motor. I then have looked at welding a piece of 1/4 inch to the rails of the car a support to the transmission. On top of that even though the ppf would still be there. I'm also looking at adding some solid mounting to the rear. I basically plan on doing away with the ppf with the bracing I'm doing. But I'm going to leave the ppf for the extra strength.
As far as some poly. I've thought about putting about a 1/4 piece for a little padding. but IDK. figured I'd start it and see how she runs and what it feels like and then go from there.
Old Mar 20, 2010 | 10:27 AM
  #82
outinnowhere3193
I'm using the stock cpu..and putting the oil pressure and temp gauges and stuff like that on my motor. So the stock cpu will pick all that up and send it like normal. The only thing I'm worried about is my tach. Sense I'm not going to be running a crank sensor I'm concerned with it. But I'm hoping I can use the current that flows on the distributor to send the signal...
In the end they both do the same thing. Just not sure what the signal power is compared to the OEM power...and the other thing is will my gauge be reading 1000 rpm when I'm 1000 or will it be like 4000 when it really is a 1000. Since it would be picking up 8 sparks per rotation rather then 2 per rotation.
Old Mar 20, 2010 | 06:40 PM
  #83
olddragger's Avatar
should have known you already had it figued for the power> Sounds like a plan
I think the ecu/tach problem will be unsolvable--heck you need a different one anyway
Outside-- on the hood:0 JK dude.
I wouldnt worry about weight right now!
OD
Old Mar 23, 2010 | 08:43 PM
  #84
outinnowhere3193
OD
Man this is getting tiring....lol now my cam has been moved to next monday. Third time this cam has been moved back
Old Mar 24, 2010 | 02:16 AM
  #85
Talic's Avatar
technically it would be 3 per rotation of the crank on the wankel
(correct me if im wrong 2 ignitions on 1 rotor 1 on other depending where you start from)
compared to 1-4 per crank rotation on a v8 (depending on crank style)
so it souldnt be too far off if anything it would be showing lower rpms
but it may not read from the ignitions
it may read from the crank sensor this the experts would have to answer
so if you wire in the distribuator to the guage the rpms would show lower amount or wont work at all
since it would be voltage based off of the crank sensor or what not
or im completely wrong which is also a high possibility
Old Mar 24, 2010 | 08:54 AM
  #86
olddragger's Avatar
is this a custom ground cam or something?
heck this kind of delay would cause me to have 2nd thoughts. Cams are easy to come by.
As far as the ignition is concerned------you know what to do. Its a carburated car ---right?
Apply the KISS rule
OD
Old Mar 24, 2010 | 09:49 AM
  #87
outinnowhere3193
Apply the KISS rule
OD
Yeah it's carb...and what is the kiss rule???? But I talked to summit yesterday and they said it wouldn't be here till like next monday or tuesday...and I had a email from summit and they shipped it last night over nighted it to me!!!! So it shows it's out for delivery for today!!!!!
So give me a few days...and this car should be back on the road and I'll start giving you a heads up on everything. I still have a lot of the bracing and brackets to do that I haven't done.
As far as the cam it's one they show and offer but it's very aggressive it's only for street strip applications and it's a very aggressive cam for street use.
Old Mar 25, 2010 | 12:56 AM
  #88
outinnowhere3193
Originally Posted by jmc23200
KISS
Keep It Simple Stupid
Oh yeah... I've heard of that...lol Guess it was kinda a smack in my face for asking what kiss was. I just showed my true colors....stupid lol
Old Mar 25, 2010 | 01:00 AM
  #89
Fate710's Avatar
Super Low & Super Slow
Without knowing the specs of the cam, 90% of all Street/Strip cams are entirely streetable. Its just basically down to when you want the power to come on and how big of a lope at idle.
If I could see the specs of the cam, I could figure on whether or not its a big street cam.
Old Mar 25, 2010 | 04:36 PM
  #90
outinnowhere3193
http://www.summitracing.com/parts/CCA-K12-433-8/
Basic Operating RPM Range
2,500-6,000Intake Duration at 050 inch Lift
236Exhaust Duration at 050 inch Lift
242Duration at 050 inch Lift
236 int./242 exh.Advertised Intake Duration
288Advertised Exhaust Duration
294Advertised Duration
288 int./294 exh.
Old Mar 25, 2010 | 06:41 PM
  #91
Fate710's Avatar
That is actually a very good street cam. You could probably go a little bigger, but I don't know what your head work on Intake manifold is. Very nice choice though.
Old Mar 25, 2010 | 09:44 PM
  #92
olddragger's Avatar
yea--you should have good vacuum with that grind.
KISS is a rule i have to remind myself all the time--i have a habit of "over thinking" things a bit
get a vid of when you fire it up!!
i would really like a picture of the underside once it all is in
OD
Old Mar 26, 2010 | 08:20 AM
  #93
outinnowhere3193
OD
First fire up??? well ya know I have a new cam I have to break in so it's got to sit up at around 2000 to 2500 to slash a good amount of oil up there for a good break in. Plus I'll only be running the headers at that point....new rings on a old bore well motor didn't have a lot of miles on the old bore..but still it isn't a fresh bore or homed engine...so it's going to take a while for these rings to seat well. So she is going to smoke pretty good at first.
But anyways I've been sick...so I've been working but not a whole lot. Plus I have two other cars that I'd doing transmission rebuilds on and then another that I got to swap a engine. So with being sick I really don't feel like working on my own once I've worked on the others.
Old Mar 26, 2010 | 09:41 AM
  #94
olddragger's Avatar
understand that dude--take it easy and let the ole body recover. Thats comes 1st.
Oh and I understand that the engine will have to be in a "break in" mode --it just that if you do post a vid--it will be the 1st such vid of a v8 sound coming from a rx8 car that I know off.
the amount of hits that vid will take would be unbelieveable?
Old Mar 26, 2010 | 10:54 AM
  #95
Fate710's Avatar
I dunno maybe its me, but when I've rebuilt and engine, I just take it out and beat the **** out of it for like 500 miles, change the oil, and then baby it for 1000 miles or so and its good to go.
Old Mar 26, 2010 | 10:59 AM
  #96
lafrad's Avatar
Wanna-be RX Owner.
Roller cam engines don't really have any "break-in" that gets done in the driveway (no load). turn the key, get your timing/jetting close and go for a drive!
Old Mar 26, 2010 | 06:07 PM
  #97
outinnowhere3193
well according to comp cams...I should idle it up to 2000 rpm and keep it there for a good 30 minutes for a good break in..and then change the oil.
Old Mar 26, 2010 | 07:11 PM
  #98
E.M.S.'s Avatar
Stupidity keeps me busy!!
i say beak the **** out of it. but thats just me....
Old Mar 27, 2010 | 01:37 AM
  #99
outinnowhere3193
Well to let ya all know...tonight I finished putting the motor together and stuck it in the car for the very last time. Did some half *** wiring and bumped it over to hear it try and start. My battery was dead!!!! But anyways tomorrow we'll be making the brackets for the radiator and mounting that. Then it will be the wiring part.
Anyone know anything about the starting side of things??? I wired my starter up and tried to start it with the key and I could hear the relay clicking...but it wasn't sending juice to the starter to kick the solenoid. So I ended up just doing a jumper for now. But could it of been that my battery was dead or does the cpu control the cranking over as well??
Old Mar 27, 2010 | 02:37 AM
  #100
HomicidalApple's Avatar
I dont understand buying an RX8 and then taking the heart of it away... they are a unique breed and you just turn into something else... i would never do that and you could never justify it to me either..
