Fuel Pump Solution - All Failure Modes
Old Sep 15, 2009 | 12:16 PM
  #176
mrslysly's Avatar
07 Rx8
Originally Posted by rodjonathan
wish i had read this before ordering my oem replacement LOL ..
You can still get the pump and modify the old assembly you took out. Keep the new one as a spare, or sell it. So you still have options.
Old Sep 15, 2009 | 01:52 PM
  #177
TheWulf's Avatar
My 8 looks like a Smurf
^ Count on an order from me when you guys are setup.
Old Sep 15, 2009 | 03:38 PM
  #178
mrslysly's Avatar
07 Rx8
Originally Posted by Charles R. Hill
I am too busy getting ready for SSXII to read your "revelations". When was the last time you read mine?
I am now trying to source the o-rings for inclusion with the pump when ordered from BHR. I am also trying to source a taller o-ring for perfect fitment.
May want to include the fuel injector clamp as part of the kit. I could not find any store within an hour drive that had a non crimp clamp that would go small enough. Found plenty that would go down to 11mm, but nothing smaller.
Old Sep 15, 2009 | 03:53 PM
  #179
09Factor's Avatar
Original Turbo 'd Auto !!
Huh? The problem is the opposite - you need more "O" ring height to get the pump to sit in the proper position.
It won't "bulge", it'll fall in!
You put the additional "O" ring on the pump above the existing factory "O" ring.
Look at the pictures of the pumps. The Walbro has a lower shoulder that needs to be accommodated.
Not in my case, Jeff. Thats the basis for the question. I looked at the pics when I took it apart and when installing the new pump. Then again when the retainer cap didn't go back on. using the OE "O" ring its a very tight fit. If I use the additional "O" ring you mention it's not possible to snap the bottom insulator and cap on.
I have checked to make sure that everything seated flush and no extra debris in the way.. SoI'm confused....
Old Sep 15, 2009 | 05:02 PM
  #180
mrslysly's Avatar
07 Rx8
MazdaManiac,
I just realized that you changed the modification to the siphon tube from enlarging the siphon venturi to 1/8 inch to just melting the pop off cap on to the siphon tube.
I have already enlarged my venturi to the 1/8 inch per your earlier instructions. Should I replace it with a stock one and then melt the pop off cap on, or is it safe to melt the cap onto my already modified siphon tube?
Old Sep 16, 2009 | 06:16 AM
  #181
Talic's Avatar
I noticed you removed the part of drilling an 1/8? bit through the ventrai and added melting the popoff valve is the drilling still neccessary/benificial? question bump for mrslysly
Old Sep 16, 2009 | 12:17 PM
  #182
Apparently, drilling the venturi was emptying the fuel bowl faster than it could refill it.
When the fuel level would get to a point that the pump was no longer submerged, the pump would empty the bowl entirely.
Old Sep 17, 2009 | 01:05 AM
  #183
swoope's Avatar
Zoom-Freakin'-Zoom
The '07 - '08 are the same as the '04 - '06.
Only '09 got a new pump.
I've found the solution for the 1/4-tank-empty fuel pump run-out.
really?
did you get my package.. it was the one without a obscure scotch.. i thought it would be cheap this time..
just wondering?
Old Sep 17, 2009 | 10:01 AM
  #184
mrslysly's Avatar
07 Rx8
Understand why now.
Old Sep 20, 2009 | 03:52 PM
  #185
mrslysly's Avatar
07 Rx8
Everyone reading this you may want to check out my writeup of my experience so far in fuel pump land.
https://www.rx8club.com/showthread.p...19#post3234319
Its a work in progress and more information will be forthcoming
Old Oct 6, 2009 | 09:36 AM
  #186
09Factor's Avatar
Jeef,
Find any extra siphons in your stash?
Old Nov 5, 2009 | 12:34 PM
  #187
Nemesis8's Avatar
Bigus Rotus
Kind of off topic, but I need to move my fuel pump resistor, any problems with me doing that? I assume it does not matter where it is located.
Old Nov 5, 2009 | 01:32 PM
  #188
shaunv74's Avatar
Power!!
Hey Jeff: Could you update the first post with the specifics on the o-ring thickness and diameter or part number? I need to run down to Lowes this weekend to get one but will need my car running to do it first.
Old Nov 7, 2009 | 08:18 PM
  #189
shaunv74's Avatar
Power!!
Victory is mine!
Man that retaining ring is a PITA. Once I figured out the surf/skate style technique and had the wife on the cheater bar it moved with no problem.
The o-ring size I used was1-5/16"ID, 1-9/16"OD and 3/8" wall.
I used a 1/4" hose clamp but a smaller one would have been better.
Thanks for the help Erick, Dan, and Ray!
Old Nov 7, 2009 | 08:41 PM
  #190
cool man - you are now pumped .
What did you use to cap the siphon tube ?
Old Nov 7, 2009 | 08:58 PM
  #191
shaunv74's Avatar
Power!!
I melted the top on per Jeff's instructions. Just a little Scripto bbq lighter around the outside lip melted it to the top. Don't worry I cleaned any gas off and let it dry first.
Old Nov 23, 2009 | 08:05 PM
  #192
Rootski's Avatar
DGAF
Any ETA on BHR's fuel pump?
Old Nov 23, 2009 | 09:13 PM
  #193
Originally Posted by Kane
I look forward to reading this thread in the morning...apparently;
lol
Al will probably clean it up again. He's just not signed on at the moment.
Old Nov 23, 2009 | 09:20 PM
  #194
Kane's Avatar
Senior Member
lol
The mods are ruining my fun.....
Old Nov 23, 2009 | 09:27 PM
  #195
since purchasers will be probably getting a loaner tool and will have a core to return.
A little complicated for us, but a massive time-saver for the customer.
good idea - I'd be into this but I guess you don't want to send your tool too far ????
Old Nov 24, 2009 | 01:27 AM
  #196
Now THAT sounds like a gay joke! lol
I dunno - I think its about $24 in shipping each way and you would be sending a pump back anyway, so it probably isn't an issue.
We'll have more than one tool out there!
Old Nov 24, 2009 | 05:17 AM
  #197
Benjamz's Avatar
Tony says, RX8s are GREAT
Soooooo..... Mazda Maniac, maybe your pm's dont work.
Are you interested in doing the tune for my car when my s/c kit is done. I choose you because your are the best tunner for the RX8 with the cobb and the cobb is more developed then my previous choice.
I have not been able to get a response from you lately, maybe my pm's have been getting lost in the massive amounts of pm mail you must be receiving
Ben
Old Nov 24, 2009 | 08:23 AM
  #198
czar's Avatar
Almost boosted
lol i forgot what this thread was about after reading all that, cant wait to see the fuel solution bhr completes
Old Nov 24, 2009 | 11:41 AM
  #199
Benjamz's Avatar
Yes, we did.... I'll pm you the details.
Old Nov 24, 2009 | 11:44 AM
  #200
Sorry, Ben.
I don't get to PMs too often and, when I do, they fill up as fast as I can answer them.
Use my e-mail - at least that ends up in my face eventually.
Just look at the first post and you can see it! lol
