Non-Rotary Swaps Engine Swap Forum
LSX/T56 Swap Build Thread..Pics inside
Old Mar 6, 2012 | 10:36 AM
  #126
The most common turbo kit is the Greddy and I can tell with 95% confidence that the kit complete with BOV, couplers, clamps, etc. etc. is no more that 75lbs. I had everything shipped to me in one box.
Old Mar 6, 2012 | 10:47 AM
  #127
coreyhendo's Avatar
I don't doubt you OR that weight one bit.
I'm just saying that other kits use bigger turbos, bigger FMICs, bigger piping, bigger downpipes. Bigger, in this instance, definitely weighs more.
Old Mar 6, 2012 | 10:49 AM
  #128
coreyhendo's Avatar
The bad part is that if one of us doesn't do a swap we're stuck using the propaganda that companies put out there. And of course they're going to make their product shine. "Virtually no weight gain" "Excellent balance" "Handling just like stock"
Old Mar 6, 2012 | 11:13 AM
  #129
One day I would love to see one of these swaps completely done.
Old Mar 6, 2012 | 09:27 PM
  #130
it replaces a 15# exhaust manifold, the intake box, etc. so the net gain is lower
does it weigh more than factory NA? yes
does it weigh net LSx engine & transmission more? not even close
Old Mar 7, 2012 | 08:44 AM
  #131
supra_speed's Avatar
Who cares!
If someone is doing a lsx swap they know the weight difference just like anyone who swapped a 3rotor it adds weight
How much weight does a 3 rotor add? Does the rack stay in the oem position?
Is the porsche gt2 50/50? Does it handle well?
Old Mar 7, 2012 | 08:54 AM
  #132
olddragger's Avatar
The FC's and FD's I have seen ( multiple ones) have significant suspension/chassis handling upgrades if they go on a road track. Brakes also.
Chassis bracing, differental bracing, high end coil overs, bushings replaced, roll bars upgraded, etc etc. BBK usually go on especially for the front.
Sometimes even fender flares are added in order to get a big enough tire on the rear.
Then we have a oem FD that is laying down 380-400rwhp that is also lighter and he will catch people in the corners/ during braking. He doesnt have the Torque off the corners or the long straightaway speeds that the v/8's have and in the end the v/8's usually win.
Just a fact of life.
Old Mar 7, 2012 | 09:33 AM
  #133
coreyhendo's Avatar
Odd that you claim the V8 fds are heavier than OEM 13b cars. Everything I've ever read (magazines and personal experiences on forums) says otherwise. The turbocharged 13b is heavier than the LSx setups.
Old Mar 7, 2012 | 08:40 PM
  #134
olddragger's Avatar
that particular FD is a track only version. The v/8's are too. In reading my post back--i realize I wasnt clear about that.
In most cases of street driven only cars that I have seen, the weights are similar.
Old Mar 7, 2012 | 10:01 PM
  #135
Originally Posted by supra_speed
Who cares!
the guy I was responding to who said it matters to him
I don't expect a guy with Supra in his username to care
Old Mar 8, 2012 | 01:35 AM
  #136
shr3da's Avatar
When I was at wakefield last year their was a race spec FD with an ls2 in it, it put down 1:02 or there abouts, this guy was no amateur at the track either. I have seen a twin turbo FD also race spec put down 0.59. The straight is average in length but its a very technical track with lots of corners.
Putting a v8 defeats in the purpose of what mazda try so hard produce a well balances sports car.
Old Mar 8, 2012 | 12:03 PM
  #137
Blackbriar2189's Avatar
When you add anything aftermarket you defeat what mazda made the car for.
People are still trying to compare apples to oranges. comparing v8 rx7's to rotary powered 7's does not mean the same comparisons can apply to the rx8.
Both cars are two completely different beasts. Even if you wanted a similar comparison for the RX8, i dont think a turbo renesis could even compete against another 8 stuffed with even the L33 from the other thread... except for the few that have hit 500 hp, THE FEW... it's not the horsepower that hurts us on the track, it's the torque
ppl complain about traction in v8 rx7's. RX8 weighs 300 lbs more, before any motor swap
Old Mar 9, 2012 | 02:09 AM
  #138
shr3da's Avatar
When I had my coilovers installed the car was corner weighed with me in it, it is true 50-50 I wonder what it will be with a v8.
Old Mar 9, 2012 | 02:29 AM
  #139
Its obviously going to be front heavy unless your fabricator can get the motor mostly behind the front axle. Good luck with
Old Mar 9, 2012 | 02:34 AM
  #140
tofu_box's Avatar
Well i dont know about 3 rotor,
But here is an alloy 4 rotor that weighs 132kg, same as stock MSP with manifolds on.
Enjoy :P oh and coming a rx8... far away from you Americans.
Old Mar 9, 2012 | 02:52 AM
  #141
Its obviously going to be front heavy unless your fabricator can get the motor mostly behind the front axle or relocate some components to the trunk.
Old Mar 10, 2012 | 09:50 AM
  #142
wow thats sweet but how much is that going to cost?
Old Mar 10, 2012 | 06:53 PM
  #143
shr3da's Avatar
70k I think
Old Mar 18, 2012 | 03:37 AM
  #144
shr3da's Avatar
It is going in an 8 soon apparently ^
ShellDude
Oct 1, 2015 09:55 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
Trekk
12
Sep 25, 2015 03:08 PM
jtdwab
Sep 12, 2015 04:57 PM
