Series I AT-Specific Performance Mods Discuss engine and transmission modifications for your AT equipped RX-8
My new install project.
Old Jul 5, 2011 | 10:11 PM
  #401
Turblown's Avatar
Boostin'
Well sell that boost controller you obviously can't use since you don't have enough injector.. Seems like a logical move
Old Jul 5, 2011 | 11:01 PM
  #402
09Factor's Avatar
Original Turbo 'd Auto !!
trade me a .81 ar hot side and I will sell it.
Old Jul 25, 2011 | 02:52 PM
  #403
FazdaRX_8's Avatar
Originally Posted by Turblown
Did a 3rd gear pull( same as the dyno boost curve) and the car hits 8 psi by 3500~ish rpms now that the vband leak is fixed.
Wow, I have the 1.00 devided on a log, same cold side as 09facter, but I dont get full boost till around 5200 rpms. Would going with the .96 undevided really make that mutch of a difference?
Old Jul 25, 2011 | 03:32 PM
  #404
Turblown's Avatar
Boostin'
Zero difference, might even spool a tick slower with the undivided housing .96 housing.
Difference is in the turbo manifold...
Old Jul 25, 2011 | 04:31 PM
  #405
FazdaRX_8's Avatar
So your manifold provides the 1700rpm difference?
Old Jul 25, 2011 | 10:58 PM
  #406
Turblown's Avatar
Boostin'
Fix your v-band leak and see when you hit peak pressure... I seriously doubt there is 1700rpms difference between the manifolds, more like 1000rpms...
Old May 25, 2013 | 07:26 AM
  #407
CapJAY's Avatar
I have a question on the engine mount i see you couldnt use the stock what did you end up doing for the bracket?
Old Jul 3, 2013 | 02:37 PM
  #408
FazdaRX_8's Avatar
is this car still around
Old Jul 3, 2013 | 03:39 PM
  #409
09Factor's Avatar
What car? Mine or someone elses? if your talking about mine, yep, drove it to work today.
Old Jul 3, 2013 | 04:34 PM
  #410
FazdaRX_8's Avatar
Yes your car goof, its your thread!!
good to hear it!!!
Old Jul 3, 2013 | 07:44 PM
  #411
09Factor's Avatar
Works great still. but i really should figure out a way to power the OMP. pre-mix "seems" to work alright, but on decel no pre-mix is injected with the fuel.
in 115 degree heat today, i saw a max temp of 213. Of course that was stop and go. once going it quickly dropped off to 197.
@ idle it pulls a consistent 7gms.
crimson809
Aug 14, 2016 10:03 PM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
