EPS problem
Old Aug 31, 2006 | 07:28 PM
nelson08's Avatar
EPS problem
ok....i started have in problems with the electronic power steering after shuttin my 8 off and then turning it back on. so i unplugged the batery to reset the computer. that worked for a few start ups. then if failed and i did the same thing. again it worked for a while. then it stoped and now i dont know what to do. the darn light keeps commin on and i have no power steering . i checked all the fused and conections to the steering rack. does anyone have any suggestions
Old Sep 1, 2006 | 02:58 AM
which connections did you check for the steering rack??? the location... and what was the lableing on the connectors???
Old Sep 1, 2006 | 10:28 AM
I would check the plug on the radiator shroud on the rt side of the battery box....remove it and spray with WD40 or Silicone and reassemble. I fixed mine like that after the dealer replaced about 3K worth of parts and it still didn't work
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
Evan Gray
Sep 26, 2015 12:30 PM
