FL22 Coolant
Old Aug 25, 2006 | 11:42 AM
PitchBlaC's Avatar
FL22 Coolant
Where do you guys get the FL22 Coolant as stated in the manual?
Anyone flush out the original coolant and using shell coolant instead?
Old Aug 25, 2006 | 01:23 PM
CoupeM's Avatar
Night Rider
from MM
Old Aug 26, 2006 | 12:09 AM
Mugo's Avatar
FL22 is just another one of the variations of a long-life coolant. German origin. FL22 is Mazda branded long life coolant. It's one of the best stuff out there with 100,000km life.
Please don't change to some inferior off the shelf coolant.
Old Aug 26, 2006 | 01:54 AM
sgrenesis's Avatar
THE GREAT WHITE
what about ARC racing coolant
Old Aug 26, 2006 | 07:35 AM
PitchBlaC's Avatar
Other than MM, any other places that sell them? Can't seems to find even at autobacs.
Old Aug 26, 2006 | 01:42 PM
coupe07's Avatar
SC 300HP!!
dun flush out at all... factory coolant is the best
Old Aug 26, 2006 | 08:07 PM
gfoo's Avatar
You may wanna try prestone coolant - buay pai, avg 5 deg drop from factory across da board. I'm using a 70/30 water/coolant mix. And it's def not a waterwetter
Old Aug 26, 2006 | 10:03 PM
PitchBlaC's Avatar
I know that factory coolant is the best but the problem is no other place sells them except MM.
I just need something that is easily available off the shelf and is already premix.
By the way do you buy extra bottles from MM and keep for emergency?
Old Aug 27, 2006 | 01:39 AM
coupe07's Avatar
SC 300HP!!
MM will not sell to you. In fact all the tor kors will not sell to u.....
the next best thing is to get wat u deemed is best, off the shell..... i personally am using prestone, which is wat nissan' tan chong is giving to their customers now in their 350z and cefiro, as factory coolant.
Old Aug 27, 2006 | 01:50 AM
zavhan's Avatar
Since u mention water wetter, Let me highlight the issue with water wetter and engine ice.
There is a floating mechanism in the so call reserve tank which is where our coolent are stored. This float is a device that triggers the sensor to inform us if the level is low. Using the wrong type of coolant will damage and affect the buoyancy of this float (mine did). If u see black residue on the bottom of the tank, chances r the float within will not last long.
cheerios
Old Aug 28, 2006 | 07:36 AM
sportsgirl's Avatar
but i'm gonna get new coolant
better to flush out the old stuff rite?
Old Aug 28, 2006 | 11:08 PM
coupe07's Avatar
SC 300HP!!
if u r getting new one, yes, flush out the old one.....
coolant lifespan is ard 2 yrs...
Old Aug 28, 2006 | 11:20 PM
mkl22's Avatar
cheerios
this is the issue with water wetter and some coolants. use it with pure water and you will not see this black deposits.
Luiss7
54
Aug 20, 2019 08:56 AM
Azki23
Jun 27, 2018 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
Rx8_412
Sep 24, 2015 08:51 PM
