View Full Version : struts and sway bars!
panda
08-24-2003, 04:02 AM
whats evryones thoughts on getting member bars, sway bars etc.....
im more into the suspension/handling of the car than the all out power that it makes to the wheels! its more fun being side ways and still being in control!
does anyone have any preferences on makes etc.. and does anyone have any on their cars allready? i have found a few products on corksport....but i am debating as to go with auto exe or mazdaspeed?
comments/suggestions etc...all appreciated!
andrew
Sin
11-29-2003, 09:02 PM
I'd just get the ones at RX8store a the vendors section.
tpryor
11-30-2003, 10:56 AM
andrew
I am ALL about handling, as I autocross my RX-8, and have been scouring the sites for any kind of adjustable shock replacement. I have the RB front sway bar, and have been meticulous about setting the alignment to the proper settings to optimize the handling (three alignments so far and one more this week).
All of the coilover kits so far include proprietary springs that are designed by manufacturers to suit what they do best (drifting, rally, etc.). If you go this way, there are several to choose from (HKS, JIC, etc.).
If you go with the shock only replacement, the only ones available right now are the MazdaSpeed set, which are not adjustable. Koni and Penske (my choice) will custom make you a set to any length and with whatever damping and adjustment(s) you want. I just can't afford $4500 for a set of custom shocks!
In speaking with Racing Beat and Mazda Motorsports, they both have said that fitting larger wheels (in both of thier cases, it was 19") actually lowered the handling threshold of the car. The cornering force actually went down significantly, apparently due to the shorter sidewall making the car much "twitchier" at the limit. So, stick with the 18's, unless it's for looks.
This is all I have been able to find out so far. If you come up with anything else, please let me know (PM).
emack
11-30-2003, 05:15 PM
I've fitted the Racing Beat sway bars and it makes a sweet handling vehilce even sweeter..............body roll is reduced and ride comfort is not compromised.
There's a lot of companies out there telling you how world beating their products are, but racing beat have been around forever and produce high quality after market products!
miata2rx8
12-01-2003, 04:30 PM
I did notice a ride penalty with the racing beat sway bar, but for me, it was worth it for the noticeable flatter cornering and improved steering input
panda
12-01-2003, 07:56 PM
ikm thinking about the RB sway bars,
what exactly will the member bars do to improve my ride quality? im confused!
andrew
