Sputtering low rpms....
Old Jun 26, 2006 | 02:28 PM
cleoent's Avatar
n00b
I dont know how to explain this, but it started in the last month or so. Between 1 and 2 rpms (x1000) there is a sputtering or hesitation. Like it's spitting or gurgling gas and then the car goes. Gas mileage has gone down a bit as well. I thought maybe since i'm at 23k it may be a dirty air filter, but i took out the one i had in there and cleaned it with an air compressor just to see if that helped and it didn't.
Any ideas?
Old Jun 26, 2006 | 02:35 PM
devious12's Avatar
Flame Thrower
I'd like to know the answer to this as well. I just got my 8 back from Mazda after a replacement of the engine and tranny, I'm getting sputtering and loss of gas mileage too. Almost sounds like a long drawn out constant burble and a loss of power from 3-5k rpms.
Old Jun 26, 2006 | 05:53 PM
Old Rotor's Avatar
Exclamation
Could it be this???
http://www.finishlineperformance.com...21-06-1559.pdf
Old Jun 26, 2006 | 07:57 PM
cleoent's Avatar
n00b
that was the only one i saw that could be it. But i dont have any 3rd gear probs, only 1k - 2k rpms... ?!??!?
Old Jun 27, 2006 | 11:10 AM
cleoent's Avatar
n00b
Is it possible i'm the only rx8 owner to have this problem?
Old Jun 27, 2006 | 11:34 AM
davedb62's Avatar
"A complete engine and tranny replacement"?? Yikes! What's up with that?
This is weird, because I just got back from a quick drive at lunch. I happened to run across a Model "A" Ford owner's convention at a local hotel near where I work. Was just barely moving through the parking lot in 1st gear, checking out the old cars and suddenly it felt like my car was intermittently losing power, or maybe "hiccupping" a bit. I just got it a month ago brand new. Wasn't a big deal, but I hope it's not something that's about to get worse.
Old Jun 27, 2006 | 11:39 AM
Avalonstar's Avatar
Beauty Without Rice
Holy crap... I thought all this was normal... I remember feeling this problem when I test drove an 8.. and then again when I bought my 8 and it's been happening ever since. o_o; I guess I should show this TSB to my dealer?
Old Jul 13, 2006 | 04:33 PM
devious12's Avatar
Flame Thrower
Update on the sputtering...
I had a new engine put in after MNAO finally confirmed that the rear rotor had lost 36-40 PSI. Mazda installed the engine, I drove the car for about 1 week, I was hearing sputtering and exhaust sounds which were abnormal. Ends up, today it was confirmed that coolant was leaking into the new engine. I don't know how or why, I wasn't told. But, now Mazda has ordered another engine which will arrive on Monday or Tuesday of next week. So still haven't found out why an engine blew twice, hopefully the third one does blow also.
Old Jul 13, 2006 | 04:59 PM
Slims8's Avatar
Piston Traitor
??? Am I missing something?
That does sound pretty wierd. Good luck!
Old Jul 14, 2006 | 11:10 AM
devious12's Avatar
Flame Thrower
Sorry, what I meant was that this new engine that will be coming in on Mon. will be the third one including the original that came with the car. I'm just hoping that this new one (3rd so far in the car) doesn't blow.
Old Aug 8, 2006 | 03:10 PM
ROAD WARRIOR's Avatar
I noticed an intermit. hick up or sputtering at idle sometimes.
Its weird it almost acts like the the engine is misfiring. Give it alittle gas & no problem with acceleration. Idle for awhile and the tach starts jumping. Happens once in a while.
Any feedback?
Old Aug 8, 2006 | 03:21 PM
mysql101's Avatar
road, what you describe is normal. there's a fine line they have to play between burning excessive fuel at idle, and giving you a smooth idle.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Michael Bryant
Oct 12, 2015 03:07 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
xAgyex
Sep 28, 2015 08:54 AM
