what the hell did I break.. what does it do?
Old Jun 25, 2006 | 05:12 PM
globaljase's Avatar
I was vaccuming up in the car and the top of the thing hit this plastic piece that sits right above the clutch pedal.. there is a box with a grey plastic thing about the diameter of an ink pen, when the clutch is pressed in, this plastic thing is let out of the box its attached to, when the clutch is returned/let off, it goes back inside the box (green tab on the top of the clutch hits it, makes it move in).. what is that, what does it do? I drove it around the block and nothing seemed different.. but nontheless its broken off, so to the little box the plastic thing goes in and out of, it thinks the clutch is depressed ALL the time now.
I superglued it back, and it seems to be fine temporarily.. ugg..
thanks
Old Jun 25, 2006 | 05:32 PM
MazdaManiac's Avatar
Clutch engagement sensor. How did you break it vacuuming?
It might affect your cruise control.
Old Jun 25, 2006 | 06:41 PM
StealthTL's Avatar
Metatron
Maniac....
The Maniac is right, it's the switch that turns off cruise before the clutch lets go.
Your cruise won't work if it thinks the clutch is always "in".
S
Old Jun 28, 2006 | 08:56 AM
Haze's Avatar
Yup, it's the cruise control sensor. If it is actually broken, your cruise control won't function.
There should be another one that engages when the clutch pedal is fully depressed telling the car that the transmission is fully disengaged so you can start the car. Car won't start without that one.
Old Jun 28, 2006 | 02:45 PM
globaljase's Avatar
Thanks guys.. A little superglue fixed it right up.. it puts pressure on it when the clutch is released so it held itself inplace nicely until it dried..
The cruise WILL WORK with the thing broken off tho, but when I took it out of gear, the throttle still stays engaged obviously.. could get around it by cancelling the cruise b4 changing gears.. or just get the darn thing fixed.. a lil superglue was a good alternative.
thanks again
j
Old Jun 29, 2006 | 09:08 AM
Haze's Avatar
Wow, it works without that switch. That is pretty interesting. Alot of cars have that switch read the position as the clutch being up. This one must be reading the clutch as depressed. Neat. Thanks for the info.
Brokegang
Jan 3, 2016 12:45 PM
juicemantwon
Sep 26, 2015 12:30 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
PortedRotorTuner
NE RX-8 Forum
Sep 7, 2015 01:06 AM
yapakanichi
Aug 25, 2015 01:24 PM
