I think this is BS...
Old Jun 21, 2006 | 05:53 PM
gobluerx8's Avatar
DEE-TROIT BASKETBALL!!!!!
So I took my car to my local dealer for her oil change and while I was there I also had them check out my squeaky brakes and rattling rear view mirror.
Well the oil change went fine and the mirror doesn't seem to rattle anymore but here's the BS part... They said that the squeak in the brakes are normal due to the build up of moisture and grease???? WTF!!!
I've been searching squeaky brakes and found that some people are getting it taken care of by the dealer and there is also a TSB on it. This sucks cause the next closest dealer is 35 miles away. Should I be the dick and tell them to fix it or should I deal with the stupid squeak?
Old Jun 21, 2006 | 05:56 PM
tiggerlee's Avatar
May Cause Anal Leakage
Squeaky front brakes are common on the 8. Print out the TSB and take it in and demand they at the very least, make an attempt to fix it. I finally got mine fixed but I had to go to another dealer.
Old Jun 21, 2006 | 06:00 PM
Dinhx8's Avatar
My Rex goes to 11!
they should atleast try once. i wouldn't be a dick cause thats just gonna **** them off, but just come with the printed out TSB and request they take care of it.
I've had them TSB' em 2x, and it still squeaks, but have tried some of the methods in the threads, and its gotten better. (i.e., bed them by driving around the block dragging brakes, etc).
Old Jun 21, 2006 | 06:08 PM
zoom44's Avatar
dont be a dick. be a respectful mature adult. explain to the service writer or service manager that you know that the squeaky brakes is a recurring issue with the rx-8 and that many people get it repaired following the instructions of the TSB . show them the TSB they will say something like " oh you cant trust what you get off the internet. then tell them that you got it from your freind at the dealer 35 miles away and that you wish them to call the tech line or the district rep to verify the TSB and to download the TSB them selves from the MX Connect website. Tell them you will wait while they verify all of this.
If you go in as a Mature Informed owner you will get a much better response than if you are a dick
Old Jun 21, 2006 | 06:12 PM
r0tor's Avatar
you have a sports car with high performance brake pads that make it one of the best stopping cars ever, which by nature are prone to squealing. Drive around the block once with the brakes dragging to scuff up the pads or get rid of your sports car.
Old Jun 21, 2006 | 06:16 PM
rodrigo67's Avatar
My brakes have been screaming for about a month, and they were getting worse and worse each week. This TSB came out just in time. I was driving by my dealer and stopped in to make an appointment. I told him about the TSB, they looked it up and told me to bring it in.
At first he said I might be responsible for the brakes because I was over the 12K warranty but mazda would pick up the labor and the kit. I asked how much and he went to look it up. When he came back he said that when he put in the part numbers it came up as one kit, so there would be no charge. Got it done the next day, no more screaming and no charge...
Old Jun 21, 2006 | 06:17 PM
therm8's Avatar
Bummed, but bring on OU!
In my experience, the brakes will continue to squeak no matter what. After servicing, they'll take a little longer to do so. It seems the brakes are so good, that you really don't have to stress them much. I hardly use the brakes due to engine braking, and even when I do, I rarely need anywhere near full pedal pressure. Bedding them in occasionally will keep the squeak from coming back. You don't even need the full bedding process, just a few hard applications of the brakes will do.
Old Jun 21, 2006 | 06:24 PM
gobluerx8's Avatar
I know I shouldn't be a dick but sometimes I can't help myself
Being an adult can be boring sometimes but I understand what you guys are saying...and your right.
I think I will talk to them with the TSB when I get back from vacation. Great approach zoom44, I'll have to use that!
And r0tor, how dare you tell me to get rid of my sexy TIgress!! I may end up buying a big brake kit anyway so I think I'll keep her
Thanks again guys!!
oliver
Old Jun 21, 2006 | 06:43 PM
I found if you bevel the leading edge of the pads it will stop the squelling. Remove them...bevel the edges, and lube the slide points and you will be good for a while.
Old Jun 21, 2006 | 06:44 PM
Search on bedding.
Bed your brakes.
what helps is new pads from Porterfield
Old Jun 21, 2006 | 06:46 PM
tiggerlee's Avatar
How did you bevel them? Metal file? Grinder?
Old Jun 21, 2006 | 07:02 PM
r0tor's Avatar
those will squeal even worse depending on the pads
Old Jun 21, 2006 | 07:17 PM
^^ No kidding...mine is so loud I'm embarassed to drive it to work
Sure kicks *** on the track though....
I bevelled them with 80 grit sandpaper.....It's quick
Old Jun 21, 2006 | 07:29 PM
moete87's Avatar
Ohio State
Where can I locate the TSB you guys are referring to? My brakes are screaming too and I hate it.
Old Jun 21, 2006 | 07:42 PM
UhateMyRX8's Avatar
UhatemyRX8
Dude go to http://www.finishlineperformance.com...ins_index.html
It has a list, go down to the "squeal noise from front brakes..." Print it out and take it to the dealer. It comes from Mazda themselves. I already had it done and no more noise.
Old Jun 21, 2006 | 09:50 PM
DarkBrew's Avatar
Extraordinary Engineering
I took mine in for the new TSB and the squeal is gone.
Old Jun 22, 2006 | 07:06 AM
labutler's Avatar
I got the same thing the first time I complained about my squeaky brakes - everything was fine. So, I came home double-checked the TSB and called them back. Said, "I was really worried about my brakes so I got on the internet and was looking around and found a TSB for them. Don't you have to fix that?" Sounded real innocent (course I'm a girl) and got them fixed.
In the dealership's defense, I really don't think they knew about the TSB. They were very nice about it and so was I.
Old Jun 22, 2006 | 05:31 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
I had mine TSBd and the squeal was worse than it had been before I took it in. But it's not a problem in warm weather, at least. Now, for the other six months of the year . . .
Old Jun 22, 2006 | 06:03 PM
DOMINION's Avatar
I don't buy Kool-Aid
I tryed to be a Mature Informed owner/Person but that did not work. So now I'm in a civil lawsuit.
Old Jun 22, 2006 | 06:07 PM
Nopstnz's Avatar
^^^ Ive noticed that too. I had squeal from October to around March and I havent heard the brakes since
Old Jun 23, 2006 | 06:59 AM
r0tor's Avatar
When its cold outside and you use the brakes hard, the hot pads cool too quickly as get a glass surface otherwise known as "glazing" which will cause squealing (the more aggressive the pads, the more prone they are to this). You need to scuff the pads up every once in a while to get rid of the squeal - usually light braking once around the block will do it, or you can take the pads out and lightly sand them.
JIN13
SE RX-8 Forum
69
Apr 8, 2019 11:46 AM
fossumja
RX-8 Racing
50
Mar 18, 2009 02:25 PM
dshiznit1489
RX-8 Racing
Jul 12, 2008 11:04 AM
whatbadgerseat
RX-8 Racing
Jun 9, 2008 04:59 PM
dpulse2930
Jan 2, 2008 10:37 PM
