Clear corner help
Old Jun 21, 2006 | 04:21 PM
futbolplaya10's Avatar
rx-8chico
Clear corner help
I was thinking about having my first mod be clear corners. I was wondering if anyone could tell me where i could get them (cheapest site). And if they differ from different sites. Also would i have to change the bulb inside to led or could i keep the same one, what color is the bulb inside the stock corner.
Thanks,
Jc
Old Jun 21, 2006 | 05:44 PM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
The stock corner has a clear (white) bulb in it. As supplied, the clear corner comes with an amber bulb of the same type installed. Some vendors also supply a "stealth" bulb, an amber bulb with a silvered coating that makes it invisible except when illuminated, so it shows white in the daylight, amber when lit. The stealth bulb may be included or may be additional cost. None of these are LED. I'm sure that there are LEDs available.
There are many vendors on the internet. Start with those listed in the "Vendors and Group Buys" forum, maybe Mazdaparts. All are the same product, the Japanese Domestic Market (JDM) OEM part. Prices, shipping, and availability will vary somewhat.
Old Jun 21, 2006 | 05:47 PM
tiggerlee's Avatar
May Cause Anal Leakage
Alot of folks here are also removing the reflector inside the clear corner. I did. IMO it spreads light more evenly throughout the fixture. Leaving it in gives the back 1/3 of the clear corner kinda dark. Just use a pair of needle nose pliers to remove it.
Old Jun 21, 2006 | 06:22 PM
rx-8chico
Why not just use the white bulb that is stock with the new clear corners
Is it illegal or what, something i heard
Old Jun 21, 2006 | 06:49 PM
Aipex8's Avatar
X e p i A
Not all clears come with replacement bulbs, the ones that I got off of ebay didn't. I wanted to put LEDs in, so this was ideal for me.
You can use the bulb that is in the stock amber corner, but like the front parking lights, the weak incandescent 194 bulb gives off a dim, brownish yellow color and is not very attractive. Technically the corner should illuminate and REFLECT amber, but I've never heard of anyone getting hassled for it.
Amber 194 bulbs are like .99 at any auto store.
I use amber refractor style LEDs from www.v-leds.com
Good luck with your first mod!
Old Jun 22, 2006 | 09:03 AM
ScreaminRX8's Avatar
Crashing is not an option
Do you have any pictures of what it looks like with the reflector out and illuminated?
Old Jun 22, 2006 | 10:34 AM
RotrDoc's Avatar
Yes!! Most states require that there be an amber marker light on the side front of the vehicle for nightime marking. You might expect to get hassled (and ticketed) for not having that if you are stopped for a moving violation at night.
Some states also require an amber reflector on the side front. That's why we get the amber corner instead of the JDM clear corner that comes stock to the rest of the world. In those states, the clear corner with amber bulb is illegal (there isn't an amber reflector anywhere), but I've never heard of anyone getting hassled about it. It might possibly become an issue if your vehicle was involved in a non-moving incident (parked car collision, maybe?) at night when the lights are off.
Old Jun 22, 2006 | 10:45 AM
RotrDoc's Avatar
Aipex8--Thanks for sending this link. I always thought that LED replacements were something exotic and expensive. Looks like I need to re-read the threads about them and select a bunch of replacements. The clear corners and the interior cabin illumination come to mind.
A little project for my after-work web browsing.
Old Jun 22, 2006 | 03:44 PM
tiggerlee's Avatar
I'll snap a couple pics for ya and post them here.
Old Jun 22, 2006 | 07:56 PM
Thanks!!
Old Jun 22, 2006 | 08:24 PM
tiggerlee's Avatar
Oops almost forgot. I'll do that shortly.
Old Jun 22, 2006 | 10:13 PM
tiggerlee's Avatar
Just a couple quit snapshots. Not the best but you get the idea.
Old Jun 23, 2006 | 11:33 AM
R-Xtreme's Avatar
Simple mannn.. get the AB Flug Body Kit for your car and you won't have to worry about all this clear corner stuff and getting hassled by police.
But in all honesty.. I had the question of whether I should do this too or not.. Autolumination is a site where all they do is sell lightbulbs for the car, LEDs and what not.. they also have this "new" thing called the Switchback that is ideal for signal lights [even side markers if you choose to make them signal]. Its a LED tower bulb that lghts up white as a running/stand-by light and automatically turns amber when you signal.
Heres the site: http://autolumination.com/1156_1157.htm
Good luck!
Old Jun 23, 2006 | 02:38 PM
Thankyou that helps alot!!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
duworm
Oct 1, 2015 04:57 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
