CZ installed. CZ gurus, experts- i need your input.
Old Jun 17, 2006 | 02:25 AM
trustbuddy's Avatar
below three were all done in 2nd gear. 87 octane.
am i running too lean at the higher rpms?
Old Jun 17, 2006 | 07:49 AM
mysql101's Avatar
see that green line that shifts from a high position down to a lower one? That's the area you should shoot for. The bottom of the green line is the "safe" tune. The top is the "extreme" tune. You shouldn't go higher. And at the higher rpms, I'd go for a slightly lower range, especially with low octane.
You should definately be able to feel the added power with your current map though.
Old Jun 17, 2006 | 11:21 AM
trustbuddy's Avatar
thanks. this is a different question, but i'm having problems trying to connect to the cz unit. my laptop is telling me that there's some sort of a malfunction with the usb or something like that. i was reading in your website that there is a cd that comes with a usb cable, which i have to install first. can that be the problem?
Old Jun 17, 2006 | 11:36 AM
If it connected once..you should have the driver installed. If it has never connected...then the USB cable drivers need to be loaded.
Old Jun 17, 2006 | 11:37 AM
Also if you bought a used unit...the firmware has probably been updated..and you will probably need to check that the software is OK for that firmware level.
Old Jun 17, 2006 | 12:04 PM
trustbuddy's Avatar
^^ how do i check that the software is ok for the firmware? the firmware is updated. and i already contacted the person i bought this from regarding the usb cable driver but is there somewhere i can DL these from?
thanks.
Old Jun 17, 2006 | 12:10 PM
http://www.mohdparts.com/emanage/ind...20&%20Firmware
I'd probably uprade to 1.25 and see if that works...1.25a and 1.49 are new and probably the unit is not at those firmware levels. You can upgrade to 1.49/1.49 with software/firmware from that site
Old Jun 17, 2006 | 12:23 PM
mysql101's Avatar
the usb drivers will need to be loaded if you can't connect. As said above - if you were able to connect before, then it's not going to be a usb driver issue.
Old Jun 17, 2006 | 12:53 PM
trustbuddy's Avatar
i never did connect before. yesterday night was my first try.
Old Jun 17, 2006 | 12:55 PM
trustbuddy's Avatar
can i use the newer 1.49 software even if the unit is not at that level? would there be a problem?
Old Jun 17, 2006 | 02:08 PM
The software upgrades with the e-manage tend to be a bit dodgy....
The honest answer is I don't know. I would contact your seller...
and ask him what software version he had working last...and try that first.
If the cable drivers aren't loaded...you have to start there......
Once you get it connected...then you can upgrade the software and
firmware and be good to go with the latest updates
When I went to the gold upgrade..I had a difficult time getting it to
work the first time.....after that it connected every time. The other thing
I noticed was some people plug the cable in backwards.....
it doesn't work that way
Old Jun 17, 2006 | 02:12 PM
r0tor's Avatar
its tough to tell what your afr is with that goofy scaling on the right axis, but from the looks of it I'd richen it up a tad - more then likely you will see the timing hold at a steady 30 when you reach the right spot
Old Jun 17, 2006 | 02:28 PM
Timing is different because the MAF voltage is being changed by the ECU.....the only way to get the timing to LOOK stock...is to turn the unit off You can add back the missing advance with the ignition adjustments...and a bit more in some spots...but the CanScan won't see that
Old Jun 17, 2006 | 02:35 PM
r0tor's Avatar
i can tell you on my car if you stay in the <13.3 range it holds 30 degrees the entire way to redline
Old Jun 17, 2006 | 02:38 PM
It will depend on how much you are adjusting the MAF values....and where. Mine used to vary the timing up to 4.5 degrees at WOT.
Old Jun 18, 2006 | 02:19 AM
trustbuddy's Avatar
how do i load the usb cable drivers? is there a cd? i downloaded the emu usb driver from www.mohdparts.com/emanage/in...%20&%20Firmware
it's not working. maybe i need to DL the upgraded software first???
help me out here guys....
Old Jun 18, 2006 | 07:24 AM
PM me an e-mail address
Old Jun 19, 2006 | 10:00 PM
trustbuddy's Avatar
thanks. got the zip file, installed cable driver everything seems fine...
and i thought i was ready to go....
another problem prevails.
i don't get the bs usb cable problems message any more. the computer seems to acknowledge it fine.
when i turn on the emanage support tool, i don't get the "start offline?" message either....but thats about it.
the emanage support (i'm currently running version 1.25 per donnebre's advice) is just not connecting. i can't adjust the throttle since the throttle caliberation button isn't even highlighted. i can't upload or download from the cz unit, etc etc...but the funny thing is, even if i unplug the usb cableand try to access the emanage support tool from my living room, there's no difference. i still don't get the "start offline".....
what can be the problem.....rrrggggg....this is very frustruating......
in despration, i tried reversing the cable plugs...i just get another usb problem popup from windows.
JCTaylor
Sep 30, 2015 07:31 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
rrubenr33
Sep 21, 2015 06:44 PM
