rx8 type s how to recognise?
Old Jun 17, 2006 | 12:59 AM
unfolded's Avatar
hi guys, im new in this site and im interested in buing an RX8, but i want to get the type s model, here there are all sorts of import models and i cant distinguish between the type s and other models, is there a chassis code or engine code that i should look for to be sure that im looking at the type s model?
thanks in advance..
Old Jun 17, 2006 | 01:00 AM
BlueRenesis82's Avatar
Registered Tracker
no type s's in the US
Old Jun 17, 2006 | 01:31 AM
NgoRX8's Avatar
you want type s? make sure you get the manual Grand touring then...
Old Jun 17, 2006 | 01:56 AM
c41250n's Avatar
the 6 speeds in the japan are the type-S
Old Jun 17, 2006 | 07:18 AM
rotor_man's Avatar
the easiest way to tell is 6 speed and the 18" rims. Another thing i would check for is the dsc (dynamic stability control) button which is fancy driver aids not just traction control. This is located to the right of the ignition switch.
Type S also will have the HID headlights. the way to tell this is turn the lights on and it should be like a camera flash at first. If its got these things its a JDM type S
Old Jun 17, 2006 | 07:51 AM
mysql101's Avatar
the GT package on the automatics come with 18" rims too. So you can't tell with that.
Old Jun 17, 2006 | 08:00 AM
8 lover in Japan's Avatar
g'day! I'm in Japan ri9ght now and they have 3 different grades here.
Type S is the 6spd manual, 18"rims, 250ps engine, better brakes, suspension than the BASE grade which has a 210ps engine, 5spd or auto, poxy 16" rims, and probably other below type S grade parts. then theres the
Type E which is sort of an in between version of the 2. you can get the 18" wheels, the interior is more luxurious, leather etc... cruise control, but not the 250ps engine Ive really only looked into the type S coz I want the sporty pack! hope this was some help to you.
Old Jun 17, 2006 | 11:00 AM
Discman2's Avatar
Rotary Noob
No type s in USA. I have an auto an have DSC and 18 inch rims.
so i guess i would have a foriegn type E
Old Jun 17, 2006 | 11:05 AM
CyprusRX8's Avatar
JDM Type-S 6-speed 250PS
Type S is always 6-speed, I know I have one! Plus I think it the only one that redline starts at 8500 revs (correct me if im wrong)
http://www.rx7.net.nz/RX-8-models-jp.html
Old Jun 19, 2006 | 08:36 AM
yiksing's Avatar
the giant tastetickles
^^ Correct
Old Jun 19, 2006 | 08:55 AM
Fab 8's Avatar
Redline for all 6 MT is 9000rpm (not just for type S). The 8500 rpm to 9000 rpm range is when the warning buzzer sounds.
Jazzmeson
Aug 30, 2015 02:23 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
Jazzmeson
Aug 2, 2015 09:49 PM
AussieGray
Jul 16, 2015 03:58 AM
