2nd Gear Problems
Old Jun 6, 2006 | 09:12 AM
Howdy1606's Avatar
Howdy
Angry 2nd Gear Problems
Here is the deal when i go into to 2nd with RPMs over like 7 it wont let the gear go in. I also i let a pro drive my car and he couldint get it in eather. But when i am driveing just around town going into 2nd dose not give me any trouble. So what should i do, my car still has its warranty but what am i suposed to say when i floor my car and shift into second my gear wont change? I dont know what to do so here i came to you guys to give me pointers.
Old Jun 6, 2006 | 09:23 AM
lurch519's Avatar
www.evoperform.com
i was experiencing similar problems with my tranny. high rpm shifts, especially the 1-2 shift, would cause it to grind going into 2nd. took it, told them during high rpm shifts it would grind. so here we are, 5 days and over 20 parts later, i should be getting my car back.
https://www.rx8club.com/series-i-trouble-shooting-95/tranny-issues-ver-2-0-a-91357/
Old Jun 6, 2006 | 09:41 AM
yiksing's Avatar
the giant tastetickles
You go into second from third or first?
Old Jun 6, 2006 | 10:23 AM
Howdy1606's Avatar
Howdy
from 1st
Old Jul 5, 2006 | 06:51 PM
wisconsinben's Avatar
Black and B-E-A-UTIFUL!
I have this same problem. No grinding noise, but very difficult (if not impossible) to get the car into 2nd gear (from 1st) at higher RPMs. After all the horor stories I've been reading lately...the transmission has become my #1 concern with the long-term reliablility of this car.
Old Jul 5, 2006 | 06:56 PM
r0tor's Avatar
my Axialflow short-shifter solved this problem on my car
make sure you are pulling straight back and not straight back and to the left. It seems (at least on my car) if you didn't pull straight back the shifter would get into no man's land and the gear wouldn't engage.
Old Jul 5, 2006 | 07:04 PM
otherside's Avatar
I dont care...
What year is your rx8? Mazda had problems with early vehicles having a bent or cracked shift fork affecting 1-2 gear shift. Could cause gear grind or no shift problems. Just a thought.
Old Jul 10, 2006 | 04:35 PM
2004. I haven't brought this up to the dealer yet, since it is only an issue at high RPM...I figure they will just BS their way out, since I have 4,000 miles left on my warranty. I suppose I will mention it just to get it on record in case the tranny dies in 5,000 miles. I am also looking into the AFE short shifter...just don't feel like droppin' the $$$ just yet.
Old Jul 10, 2006 | 11:22 PM
Rx-8 TT's Avatar
I have the same problem too. I thought it is normal.
From 1st to 2nd shifting is really hard, feel like someting is holding
my shifter not to going into the 2nd gear. 2~3, 3~4, 4~5, 5~6 is good, smooth.
Should I go to dealer to check it up?
so, most of you guys have solved this problem at dealer?
or solved by short shifter?
What if dealer says it is normal? cuz my dealer is really...really...no good..
Old Jul 11, 2006 | 11:31 AM
zenmoused's Avatar
the stig is my hero
I had the same problem. Took it in to the dealer and they said nothing's wrong (big surprise). I thought that perhaps I was shifting wrong. Nope.
Here's what you do:
1. Look up the DIY on replacing your transmission and differential fluid with RedLine or Royal Purple. Do this after you have a good 4-5 k miles on the clock (don't know how old your car is, but it's good to let a transmission "work in" before you replace fluids). I did this a few days ago and what a difference! Totally solved my problem.
2. Ask the dealer to fix the clutch problem. There's a service bulletin out for the clutch not engadging/disengadging.
3. If it's still not doing what you want, replace your clutch line with a stainless steel line. Mine cost 31 dollars shipped from corksport.com.
4. If you do all this and STILL have problems, get a short shifter. You may want to get this regardless as it sounds amazing. I have yet to do this.
Old Jul 11, 2006 | 09:03 PM
Rx-8 TT's Avatar
Here's what you do:
Ok...I will try from #1. My dealer would have said same thing that nothing's wrong. Anyway...mine has 9,000 mile and it''s time to change fluid. Thanks.
Old Jul 13, 2006 | 08:42 AM
The RedLine fluids made only a slight difference for me. I changed them at around 30,000 miles. I'll have to mention this to the dealer the next time she goes in...just to see what they say.
Old Jul 13, 2006 | 08:51 AM
fanaticz's Avatar
I have this problem sorda... not really that noticeable though. Just a little bit of a harder shift into second and reverse is a PITA sometimes. I ordered the redline fliuds the other day; however, I've never used a torque wrench before.... so it'll be a new experience. Any advice on that? I assume it's like any other wrench... set the torque, and I assume it clicks or stops whenever it's tight enough. I've already read through the DIY.
WranglerFan
May 31, 2022 07:51 AM
Azki23
Jun 27, 2018 03:48 PM
nowakm99
Oct 9, 2015 07:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
titaneum_grey
Sep 6, 2015 10:21 PM
