Noise/clank when turning engine off?
Old Jun 2, 2006 | 11:53 PM
Stavesacre21's Avatar
1.21 Jiggawatts
Question Noise/clank when turning engine off?
Hey all, got a quick one for ya...and I searched it out and couldn't find anything really similar.
Since i've gotten the car, i've noticed that after the engine is warmed up and all, I'll drive to where i'm goin, and then go to turn the engine off. It almost sounds like something coming to a haltering/stammering stop, almost like a clanking stop. I'm not sure if it's transmission or engine, but I know that anytime I've got the windows down, it's definetely there. When I turn off the engine, i have the car in neutral with the clutch fully engaged.
If this normal, or have any of you noticed this? It's not enough to scare a person outside the car or anything, but it just sounds...abrupt for when you turn the engine off.
What do you all think?
Old Jun 3, 2006 | 01:00 AM
NgoRX8's Avatar
its like a clank when you turn the engine off? i get that too. you get to hear it a lot more when you do it inside the garage. it's fine.
Old Jun 3, 2006 | 01:52 AM
1.21 Jiggawatts
Come to think about it, I hear it a lot more often when I'm in the hospital's parking garage... that's definetely where it's most distinct.
Glad to see i'm not alone...not sure if it's the rotary by nature or the transmission finally resting, but it certainly had me a lil concerned when I first heard it. And yea, a stammering clank is the best way to describe it. thanx
Old Jun 3, 2006 | 02:10 AM
Crazy Rx-8 Driver's Avatar
XYELLR8
ignition turning off. that is all i believe. no biggie
Old Jun 3, 2006 | 03:41 AM
presequel's Avatar
ay bay bay
snakes on the transmission.
Old Jun 3, 2006 | 03:58 AM
Freddie's Avatar
Correct. It's an electrical relay or solenoid de-energizing.
Old Jun 3, 2006 | 07:08 AM
1.21 Jiggawatts
i'm rather suprised its electrical to be honest...i'd have defientely guessed it was mechanical. Reassuring nonetheless that it's nothing serious thanx all
Old Jun 3, 2006 | 11:18 AM
zoom44's Avatar
when you turn the engine off the SSV flaps open and closed to make sure its not stuck
Old Jun 3, 2006 | 06:04 PM
DOMINION's Avatar
I don't buy Kool-Aid
^Ahh thats what that is. Thanks Zoom44
Old Jun 3, 2006 | 08:40 PM
Freddie's Avatar
^^^ What he said. Great info. Is the SSV operated by vacuum, or electrically?
Old Jun 3, 2006 | 08:46 PM
dillsrotary's Avatar
jersey fresh
nope, its a unicorn in the muffler jumping up and down
Old Jun 3, 2006 | 08:51 PM
mysql101's Avatar
It's a known fact that snakes are attracted to planes, not car transmissions.
Old Jun 3, 2006 | 10:58 PM
Imidazole's Avatar
Whats the SSV?
And, it does it without you ever turning the engine on. Put it in accessory mode, right before the engine cranks - then turn it off. Clunk
Old Jun 3, 2006 | 11:04 PM
tiggerlee's Avatar
May Cause Anal Leakage
Originally Posted by Imidazole
Whats the SSV?
Secondary Shutter Valve
Old Jun 5, 2006 | 02:26 PM
KeithL's Avatar
mmmmm, Pale Ale!
I'd guessed that's what the "clack" (that's how *I'd* describe it) about a second after shutdown was, but, I couldn't guess why the SSV would've been opened while the car was at idle..... Makes perfect sense now. Thanks Zoom.
Old Jun 5, 2006 | 02:28 PM
Cattywampus's Avatar
Turbos blow!!
or it could be the flywheel. It does the same on the G coupes and the 350 z's. Or it could really be the ssv thingy.
Old Jun 5, 2006 | 02:55 PM
1.21 Jiggawatts
Glad to see i'm not alone...just found it rather funny that the topic has never been covered before! Or maybe i'm just search deficient.
Old Jun 5, 2006 | 03:03 PM
alfy28's Avatar
Yah like previous poster posted. shouldnt worry bout
Attached Thumbnails Noise/clank when turning engine off?-dimsig.jpg
Old Jun 5, 2006 | 04:49 PM
zoom44's Avatar
well
https://www.rx8club.com/showthread.p...ighlight=clank
and i was wrong here- i forgot the actual source and as you'lll see in those threads it isnt the first time
if the test failed you would get a CEL with the following code
DTC P2119
Throttle actuator control throttle body range/performance problem
DETECTION CONDITION
* The PCM compares the TP with default TP when the ignition switch is turned off. If the TP is higher than the default TP, the PCM determines that there is a throttle actuator control throttle body range/performance problem.
* Diagnostic support note
This is a continuous monitor (CCM).
* The MIL illuminates if the PCM detects the above malfunction condition in two consecutive drive cycles or in one drive cycle while the DTC for the same malfunction has been stored in the PCM.
* PENDING CODE is available if the PCM detects the above malfunction condition during the first drive cycle.
* FREEZE FRAME DATA is available.
* The DTC is stored in the PCM memory.
Old Jun 6, 2006 | 09:38 AM
KeithL's Avatar
mmmmm, Pale Ale!
So, just out of curiosity, are the aux. and secondary shutter valves tested anywhwere?
Old Jun 6, 2006 | 08:49 PM
1.21 Jiggawatts
Originally Posted by zoom44
well
Gosh dang it....I freakin knew someone would find this somewhere if they looked hard enough! I search under clank/bang/shimmy/bang/studder/shudder and lock. Of course it wouldn't be any of those words.
Blasphemy.
Old Jun 6, 2006 | 09:20 PM
zoom44's Avatar
clank was the search subject see highlight=clank
really i found it cause i knew it was there because i was in the thread
Old Jun 7, 2006 | 06:08 PM
stickman's Avatar
I never hear any clank but the engine does say "ah ****, I wanted to do more" when I shut it off.
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Eirulisse
Aug 15, 2015 12:34 PM
ironj221
Jul 16, 2015 10:16 PM
