Replacement for incompetent gas cap?
Old May 26, 2006 | 06:23 PM
rollerbldes's Avatar
I swear this dumb gas cap will not stay on. Every time I screw it on 10 turns it'll just fall off with 1 tiny touch. It seems like the cap only takes half a turn to screw on. Is there anything more competent? Also.. I bet this is one of the many causes of our low miles per gallon!!! The gas cap is stealing our gas!!
Old May 26, 2006 | 06:40 PM
two rotors's Avatar
If you have not had a CEL then your gas cap is fine.It is only supposed to take a turn to put on.There is a system in your car which checks for leakage in the evaporative emissions system,so you will know when your gas cap is leaking
Old May 26, 2006 | 06:57 PM
Go48's Avatar
Ten turns? You're abusing your gas cap! All you need to do is screw it in until you hear one or two clicks.
Old May 28, 2006 | 12:45 AM
Well heres the thing, my car threw a CEL and I went to the dealer. They told me to give it an additional 5 turns to make sure it is on. I don't think there is a difference between 1 turn or 100 turns to be frank.
Old May 28, 2006 | 12:46 AM
cjkim's Avatar
^noob
why don't you just tell the dealer? I'm sure they'd replace it for you..
Old May 28, 2006 | 02:27 AM
phroztbyt3's Avatar
ebay has some cool ones for the 8.. a mazdaspeed 1.. and 1 in the shape of a rotar
Old May 28, 2006 | 03:57 AM
poorman's Avatar
anyone know if those seal or tighten more?
to me the gas cap varies in tightness... always makes me paranoid
Old May 28, 2006 | 04:06 PM
I'm not sure a new one would be any different. It seems after numerous trials that the tightness is random. It is quite a weird animal.
Old May 28, 2006 | 04:30 PM
tiggerlee's Avatar
May Cause Anal Leakage
Yep! Never had an issue with mine. Put it on,rotate two clicks and done.
Old May 29, 2006 | 12:02 PM
Easy_E1's Avatar
I concur.
Stop abuseing the cap. When you hear the click that is an internal ratchet
that engages when you reach optimum torque (ftlbs.) on the cap.
This is tight enough. Extra turns do nothing to tighten the cap more,,just to wear out the ratcheting system.
CLICK,, CLICK.
Old May 29, 2006 | 12:44 PM
r0tor's Avatar
Originally Posted by Easy_E1
I concur.
CLICK,, CLICK.
exactly...
Old May 29, 2006 | 12:56 PM
cgrx's Avatar
DRIVEN
I had the same issue
Don't push the cap when turning
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
Quiggs321
Sep 3, 2015 04:28 PM
endowdly
Aug 24, 2015 02:32 PM
GracefulShanks
Aug 18, 2015 11:40 AM
