Need help sourcing a plug
Old May 26, 2006 | 03:43 PM
Bindon's Avatar
Fire-Spewing Maniac
Ok guys,
I need help sourcing the 5 pin and 7 pin plastic harness plugs that go into the MAF and the throttle body. Anyone know where I can get these?
-Bryan
Old May 26, 2006 | 07:14 PM
Go48's Avatar
I doubt if you can purchase just the connectors from Mazda. In which case you would have to do a little detective work to determine the manufacturer and one of their vendors. Then you might have a problem convincing a wholesale vendor to sell you a few connectors. Anyway, try Mazmart (http://www.mazmart.com/) for a used wiring set with the connectors.
Old May 27, 2006 | 03:22 AM
bindon,
you also might pm overload.... i know he has some connections in connections..
Old May 27, 2006 | 11:58 AM
Bindon's Avatar
Fire-Spewing Maniac
Cool.
We need new plugs, and mazda only sells full harnesses. We need to find the actual maker of the plugs, im thinking its kawaseki, but im not sure.
Old May 29, 2006 | 02:00 PM
Charles R. Hill's Avatar
Owner of BHR
I know that Canzoomer had some difficulty, but was successful, in sourcing the ECU plugs from Tyco. I tried the same thing to help TeamRX8 source some ignition coil connectors, but to no avail. I know that Mitsubishi makes the MAF sensor(which I think is 4-wire) so they may be a place to start asking questions, but I don't yet know who makes the throttle ***'y. That is a 6-wire connector. AMP also makes plugs/connectors for a variety of purposes.
CRH
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
extreme_rotary
Sep 10, 2015 08:58 PM
Rupanrx
Sep 4, 2015 06:44 AM
