View Full Version : Water in Tail light
Rootski 05-17-2006, 05:18 PM After about a weeks worth of rain here in Ohio, I decided to give my 8 a bath. Before I even touched water to the car, I noticed a huge amount of condensation inside the rear passenger tail light, so much that the whole thing was nearly obscured. It's never leaked before, and all the lights inside still work fine, but it looks like hell! Is there any way to fix this?
NgoRX8 05-17-2006, 05:31 PM take it to the dealer and show them. it should be a replacement under warranty.
N rider89 05-17-2006, 06:26 PM yeah warranty work for sure.
Rootski 05-17-2006, 06:45 PM God I hate the dealers.
tejon 05-17-2006, 08:59 PM I had a tail light assembly replaced for condesation problem under warrenty without any hassle. I just showed it to the dealer and they replaced it with a new one - no questions. Your situation is not unique, there is a discussion about it else where on the forum.
NgoRX8 05-17-2006, 09:01 PM I hate dealers too... my headlights have condensation, but i've been stalling to get it replaced because i don't wanna have to swap my bumper. No way do i want the dealer to take off my aftermarket bumper.
Brettus 05-17-2006, 09:06 PM I drilled two small (approx. 1.5mm ) holes in the bottom of mine & the problem went away
you cant see the holes unless you are looking for them.
Crazy Rx-8 Driver 05-21-2006, 05:07 PM I drilled two small (approx. 1.5mm ) holes in the bottom of mine & the problem went away
the bottom of your rear tailiights or the fronts? i'm assuming the rears and you drilled them from the back right?
msrecant 05-22-2006, 12:05 PM Known issue that Mazda fixes under warranty. Check out http://www.rx8club.com/showthread.php?t=62150 .
poorman 05-22-2006, 10:42 PM warranty it. If u drill the holes you will sometimes still get moisture in ther but no pooling, and if u drill the holes, they might void the tail light warranty lol.
When i got my water in tail lights, i had like a cup full of water in them lol
nycgps 05-22-2006, 11:12 PM My left tail light had water in it b4, it was like maybe 2 cups of water in it.
Replaced under warranty, its a known issue, no questions asked.
if you drill holes, condensation will come back one day. especially rainy days. and, you will not get any warranty cuz "you drilled the holes and no it does not going to look like its a factory defect"
rx2kill 10-15-2009, 08:02 PM Wow too many ppl relying on warranty what about the ppl out of warranty??
Mazurfer 10-15-2009, 08:07 PM Wow too many ppl relying on warranty what about the ppl out of warranty??
Well.....you can drill holes as some will do(but I won't), or you can go get a gasket and do it yourself.
http://www.finishlineperformance.com/store/product.php?productid=16881&cat=302&page=1
If you get that far and see the gasket, be sure to click on "WATER IN REAR COMBINATION LIGHT" to see how and what to do!
If you do a search, there are many threads on this subject.
Ralker 10-16-2009, 08:24 AM Wow too many ppl relying on warranty what about the ppl out of warranty??
I just fixed the gasket recently on my 04: screwdriver, silicone sealant, a small hairdryer and about thirty minutes of effort on my part. It's been about a month now and no new water :).
rx2kill 10-17-2009, 10:40 AM haha yea a $54 gasket, damn thats expensive, im not rebuilind a top end on e dirt bike lol. Yea Imma try the silicone approach and c how that plays out, good and bad thing is florida prolly wont rain for a few months from by the time I do it, alright anyways thanx
lepichichi 10-17-2009, 11:00 AM i used cilicone and problem solve :)
9krpmrx8 10-17-2009, 11:22 AM You will have to let the light dry out though. I removed mine, removed the connectors and rinse the housing out with filtered water (so no spots are left) and then let it sit in the sun for a few hours.
When you remove it you will see the water line on the gasket. After the light is dried out just run a bead of black RTV along the factory gasket (after you clean it up of course) and a bead along the body where the tail light goes (you will see the outline of the gasket) and it will never leak again.
mkmike103 10-17-2009, 09:47 PM +1 on removing, cleaning, drying and siliconing the hell out of it. Weird thing for me was the first couple rains after, I still got condensation so I figured it didn't work. After that, it rained a bunch here and its dry as a bone, so I consider it a success.
corners 10-20-2009, 04:14 PM Mine's at the dealer getting fixed right now. They said there's an upgraded gasket kit for the lights available now. They don't replace the whole assembly any more.
9krpmrx8 10-20-2009, 04:36 PM Mine's at the dealer getting fixed right now. They said there's an upgraded gasket kit for the lights available now. They don't replace the whole assembly any more.
Upgraded gasket my ass. They work as well as the upgraded visors. I have had two of the upgraded gaskets and finally did my own upgrade. A new gasket and black RTV would be the best solution.
Shijin-Kun 10-21-2009, 04:00 PM i had about half the taillight of water. It was so much water that it fried my brake light. I removed it poured out the water and then used a hair dryer to dry it. Warning!!! do not use the hair dryer for a long period of time because it will melt the plastic. I drilled 3 holes at the bottom of the taillight. At first there was condensation then after a day it went away.
rx2kill 10-21-2009, 07:39 PM The dealer told me im way outta warranty , not a surprise, it was up in 07, a lil waters not all that bad..... Lame, I cant see myself getting a 54 dollar gasket for a light, maybe im crazy. What is RTV?
9krpmrx8 10-21-2009, 08:33 PM http://www.mcmelectronics.com/content/productimages/s4/3852855.jpg
adamwzl 10-22-2009, 09:53 AM I have a passenger tailight brand new I can sell you... fits 04-08 models.
Tamas 10-22-2009, 08:09 PM If you use the silicone sealant, can you still remove the tail light if necessary? I mean, using the sealant between the car's body and the gasket acts like an adhesive, no?
mkmike103 10-22-2009, 08:26 PM Probably with some effort. I'm hoping to never have a reason to remove it again :)
mscamp02 10-22-2009, 08:26 PM why are there two of these threads right now??? I mean one is enough of a fail....search guys
~ Kuro ~ 10-23-2009, 10:23 AM If you use the silicone sealant, can you still remove the tail light if necessary? I mean, using the sealant between the car's body and the gasket acts like an adhesive, no?
why not use neoprene...
wouldn't that be a good barrier? I think I'm going to try it.... still researching..
http://www.go2marine.com/product.do?no=52213F&WT.mc_id=gb1
rx2kill 10-23-2009, 07:30 PM If you use the silicone sealant, can you still remove the tail light if necessary? I mean, using the sealant between the car's body and the gasket acts like an adhesive, no?
It wont seal it its silicone, not like an epoxy, it will peel off still but ud have to seal it again if u took it off
