Another CEL with limp mode !!!!!!!!!!
Old May 16, 2006 | 01:33 PM
snkpkp's Avatar
CEL Diagnosed with P1688 service guys have no idea HELP !!!!!!!!!!
Ok this is probably the 4th time the car came with a solid CEL and to limp mode. I drove the car about 2 hours with interval of 20 mins once during that 2 hours . I parked the car went to buy a dvd, came out and started the car no problem, I pulled up and the cel came up solid and went to limp mode restricting rpm to 3000. Then i pulled over , turned engine off and started again after 5 mins, i was fine took up to 9000 rpm no problem but CEL remains. Outside temp is about 85 . I cant go to the dealer for another week to check the error code. So far i have changed
engine mounts
clutch plate/ pressure plate
Coils
Plugs
Air Filter
Cleaned MAF
Checked ALL electrical points of the car excluding the EPS (no one here understands it)
changed all these 5 weeks ago , drove abt 600 miles.
Do you guys think its safe to drive like this for a week until i take it in to check the code?
Last edited by snkpkp; May 22, 2006 at 03:28 PM. Reason: needs new name as thread has changed path but same topic
Old May 16, 2006 | 01:56 PM
Marc_GS's Avatar
Hooked on go-fast crack
If the CEL on your car works the same way as North American RX-8s, then yes it is safe to drive with the solid CEL. When it is blinking, that can mean something more serious is wrong, but solid won't lead to any damage.
Another piece of info, again assuming your car works like ours do. Certain faults detected by the ECU will cause the CEL stays on solid. It will stay lit for a while even if the fault is not detected again. After a few complete start/warmup/shutdown cycles without the fault being repeated, the CEL will shut off, but the code will stay in the ECU. So if it turns off in the next little while, it means that there was a one-time fault that occured, but the car is now fine. This can happen if something out of the ordinary happens (bad gas, high peak temperature for a brief moment, etc.)
Old May 16, 2006 | 02:06 PM
snkpkp's Avatar
it does work more or less like North America spec vehicles. The car stays in limp mode for two drive cycles? it seemd like that? anyway i am begining to think i need to update to a 2006 model car. by the way i also changed the battery 5 weeks ago along with the other things.
Old May 16, 2006 | 04:09 PM
snkpkp's Avatar
Anyone know how exactly the safe mode works? I got the safe mode only when the CEL came on and NO other lights. Car comes out of limp mode automatically? I turned the car off and turned it back on drove around and the limp mode was gone. Is that normal? I am freaking out , what if I get a limp mode in the middle of the highway tomorrow? have official visit out of the city...pls advice anyone.....!!!!
Old May 18, 2006 | 11:01 PM
dastallion951's Avatar
when ur cel is blinkin its just a misfire take it to mazda u might be runnin to rich or lean an AFR, do u have an aftermarket midpipe or hi flow cat.....??? if so ur 02 sensor might be malfunctioning..... best bet find someone with a generic scanner or if u have access to mazdas scanner, plug into the OBD II connector,n find ur code n then u should know where to look next???
Old May 20, 2006 | 09:05 PM
snkpkp's Avatar
just got the hymee scanalyzer, but did the ecu reset thing before my trip. Now have to wait for another cel. I cant understand all the numbers in the log either. and what does lean and rich mean? Ok i am totally lost. any post to educate a dummy?
Old May 21, 2006 | 02:08 PM
snkpkp's Avatar
OK stalled the car a bit , couldn change gear fast enough from a red light and my throttle was too low so the car stalled followed by a solid CEL. Connected the scanaluzer software and i got P1688 which is some initial check blah blah....can anybody suggest what is it? do i need to change the MOP wiring harness ? Whats going on? pls anyone..advice....
Old May 21, 2006 | 05:59 PM
takahashi's Avatar
Sounds like the oil pump...
Attached Thumbnails Another CEL with limp mode  !!!!!!!!!!-p1688.jpg   Another CEL with limp mode  !!!!!!!!!!-p1688-2.jpg
Old May 21, 2006 | 07:32 PM
Post the freeze frame data from the scanalyser...it might help us figure it out
Old May 22, 2006 | 05:59 AM
snkpkp's Avatar
already cleared the CEL from PCM can I retrive again to save it?
Old May 22, 2006 | 11:54 AM
snkpkp's Avatar
P1688 Freeze Frame
Ok here are freeze frame data, i dont know how to save them so took a picture.
I took it to the service center and as they are not mazda expert, the work shop manual does sort of work but they dont specifically know what to check , but they did check the wires and pcm harness, i did the reset from the scanalyzer few times and it keeps coming back, what do i do. help pls guys. sucks ......maybe time for a new car??? should i replace the wires and oil pump?
Attached Thumbnails Another CEL with limp mode  !!!!!!!!!!-1freezeframep1688.jpg   Another CEL with limp mode  !!!!!!!!!!-2freezeframep1688.jpg
Old May 22, 2006 | 12:06 PM
That's a Metering oil pump fault.
It could be a wiring fault...or a fault with the pump itself.
If you do the diagnostic procedures you can tell if it is the wiring....
That would leave the pump.
What do you have for mods....your LTFT is 7%...you must have intake/exaust??
Old May 22, 2006 | 12:33 PM
snkpkp's Avatar
stock intake, stock exhaust what does LIFT 7% mean ????
...sorry for being a dum ***. I know almost nothing about vehicle engineering, I had 0 problems with the car until it hit 18000 miles and all hell broke loose, coils, shocks, clutch, mounting, new battery.....and now this....
Old May 22, 2006 | 01:09 PM
snkpkp's Avatar
Also i am trying to reset the CEL from the scanalyzer, it is going off but every second start after clearing it comes back on. I guess its a constant failure of the Oil Pump?
Old May 23, 2006 | 06:45 AM
snkpkp's Avatar
Wires Checked , is it the MOP?????
Took the vehicle for service for 2nd time. Changed engine oil, Oil filter. Checked all connections as per workshop manual, and all seems to be in order. Vehicle still showing CEL with P1688 code. After vehicle shows the error vehicle rpm locks at 3000. But after 30 mins the vehicle is drivabale at normal speed, accelaration.
questions : Pls help if you guys can.
Now to what i understand the P1688 is an error code from the MOP circuit or switch which is inside the MOP??
If the MOP is toast then how would the engine get its lubrication, and wouldn it be showing the red oil indicator lamp which looks like aladdin's lamp?
If I change the MOP do you guys suggest changing all the wires even if the wires test shows the connections are ok?
If I get the wiring harness for the ecu to MOP would it require the whole stack of wires as shown in this attachment or just the 8 wire connections?
Do you think it could be from faulty ecu ?
I know I am asking too much questions, but pls advice as much as possible, love this car, wouldn want to loose it so fast.....
Attached Thumbnails Another CEL with limp mode  !!!!!!!!!!-rx-8-rear-wiring-harness-replaced.jpg
Old Jun 6, 2006 | 08:54 AM
turbine's Avatar
4th Year runnin
Check this out. Maybe some help for you.
https://www.rx8club.com/showthread.p...er+loss+solved
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Sep 26, 2015 12:30 PM
