quick question about rb springs
Old May 9, 2006 | 11:22 PM
johnnylee3's Avatar
jonathan
hey guys, i was just wondering who has rb springs, perhaps with konis cuz that is the set up i have could let me know how many finger gap there should be between the wheel and the fender. for some reason my front seems kinda higher than what i expected. thanks again.
Old May 9, 2006 | 11:39 PM
Winning 8's Avatar
Hot Pit
it only drop 1/2 inch, so it should look the same.
Old May 9, 2006 | 11:43 PM
NgoRX8's Avatar
as long as it doesn't look higher than stock, i think it's fine. it really is hard to see if you're lowered with rb springs because they are so conservative. Plus you also have to remember than the springs need a few days to settle. If you tightened your upper control arms with the car on the ground, you should be fine.
shocks won't go about as to adjust the height of the car. Only springs or coilovers adjust the height.
Old May 10, 2006 | 12:49 AM
TheDosDog's Avatar
Recovered Modaholic
I've been running Koni's with RB springs for quite a while now. They settled in at 14.25" from center of hub to fender lip in front and just a smidge over 14" in the rear. Stock, new was 15.25" all the way around.
Old May 10, 2006 | 02:38 AM
johnnylee3's Avatar
jonathan
hm..alright thanks guys
Old May 10, 2006 | 11:23 PM
Silverarrow's Avatar
OldeSpeede, Inc.
With my Konis and RB springs, i have two fingers between the tire and the fender. I noticed more drop after the konis installed, so i think the shocks may be shorter themselves.
WranglerFan
May 31, 2022 07:51 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Rupanrx
Sep 4, 2015 06:44 AM
