Speed senor
Old May 4, 2006 | 11:09 PM
SE3P_HKG's Avatar
Force Fed @ 308ps
Speed senor
I am getting a Yellow Box but I need to know,
Does our 8 have a 3-wire hall-effect type speed sensor or a 2-wire inductor type speed sensor??
Old May 5, 2006 | 02:09 PM
appears to be 3 wire hall ...
Old May 5, 2006 | 05:55 PM
rkostolni's Avatar
I think that wiring schematic is only for an auto tranny though.
Old May 6, 2006 | 09:03 AM
Rasputin's Avatar
No, it's inductive. It has 2 pins.
I'm talking about the engine speed sensor, also called excentric shaft position sensor. Team, the schematics you posted shows the vehicle speed sensor.
Fabrice
Old May 6, 2006 | 10:38 PM
SE3P_HKG's Avatar
Force Fed @ 308ps
So, the Speed Sensor is a 3-wire hall-effect type speed sensor, correct?
Old May 7, 2006 | 07:31 AM
Rasputin's Avatar
Vehicle or Engine Speed????
Old May 7, 2006 | 11:07 AM
SE3P_HKG's Avatar
Force Fed @ 308ps
Vehicle speed, thanks!
Old May 8, 2006 | 11:03 AM
rkostolni's Avatar
Do you want to know what type of sensor it is or just where you can tap a speedo wire?
Old May 8, 2006 | 12:02 PM
What I posted earlier is for the vehicle speed sensor (mph/kph) regardless of transmission type:
According to the diagram it has three wires; power, ground, signal output. I don't know for sure what type it is though.
he's trying to do a speedo error correction:
https://www.rx8club.com/series-i-tech-garage-22/yellow-box-89252/
Old May 8, 2006 | 03:46 PM
Moonrover333's Avatar
My Goodness My Guinness
sooo whats a yellow box
Old May 8, 2006 | 04:38 PM
KWS's Avatar
KWS
Check out: http://www.blackrobotics.com/yb_home.htm
YELLOW BOX: Electronic speedo re-calibrator
• World's smallest and most high-tech speedo recalibrator!
• Tiny size, only 1 x 2 inches, weighs only 1.5 ounces!
• Inbuilt microprocessor accuracy
• Instant response, no speedo lag
• Fine 0.25% adjustment from -28% to +28% correction
• Also has KPH-MPH conversion mode for imported vehicles
• (KPH mode has additional -10% to +18% adjustment)
• System testing on power-up
• Flashing light shows switch settings and test modes
• Input and output tests
• Rugged solid epoxy construction
• Models to suit most modern bikes and cars
• Legendary reliability and 10 year replacement warranty!
Old May 8, 2006 | 09:05 PM
SE3P_HKG's Avatar
Force Fed @ 308ps
TeamRX8
This is perfect!! Exactly what I wanted, thank you so much.
JCTaylor
Sep 30, 2015 07:31 PM
Quiggs321
Sep 30, 2015 05:34 PM
Racingjunkie
Sep 29, 2015 05:05 PM
