Need Your Expertise On Wheel Offset
Old May 2, 2006 | 01:47 PM
EsCoBaR1's Avatar
I'm ordering a pair of black wheels on the internet but I'm concerned about the offset.
Theyre 19.85 front/19.95 rear and the wheel offset is 38mm front/ 35mm rear. When
I called the company I was told that I might need spacers for the front wheels.......I
really dont know much about the correct size of wheels for the Rx8 or 'spacers' so
any help on whether these wheels are too big or too offset for my car would be
appreciated, Thanks. Also, could someone tell me what Spacers do?
Old May 2, 2006 | 03:41 PM
kwescott's Avatar
One ball, corner pocket
sounds similar to my setup...ooops, nevermind, just looked back at my thread.
https://www.rx8club.com/showthread.p...ght=volk+black
Old May 2, 2006 | 03:46 PM
NgoRX8's Avatar
19x8.5 with 38mm shouldn't need spacers. you are already getting more inner clearance.
Old May 3, 2006 | 01:52 AM
c41250n's Avatar
i think your rear is gonna rub the rear fender, im not running 18X8.5 30+ offset with 245/40/18 in the front and 18X9.5 40+ offset with 275/35/18 in the rear, i lowered the car all the way with tein basic coilovers, my rear bearly clear the fender!! but the front still have a lot of space!!
also, i do have -1.75 camber all around!
Old May 3, 2006 | 04:13 PM
EsCoBaR1's Avatar
^^What size wheels do u have?
Old May 3, 2006 | 04:17 PM
rotaryengine's Avatar
you don't need any spacers !
I have wheels with 8,5x19 Offset +25 and rear 10x19 Offset +35mm !
tires sizes front 235/35/19 and rear 275/30/19
Attached Thumbnails Need Your Expertise On Wheel Offset-aez19.jpg   Need Your Expertise On Wheel Offset-aez23.jpg
Old May 3, 2006 | 04:25 PM
Frnt should be OK...but I think the rears will rub if you are lowered very much.
I have 9.5" with 45 offset on the rear and they barely clear at the drop I have dialed in..... almost another 1/2" probably would rub.
Old May 3, 2006 | 06:31 PM
lesper4's Avatar
T-29 years and counting
What wheels are those Rotaryengine, they look similar to the axis decade, something i might be intrested in? do you have any more pictures?
Old May 5, 2006 | 04:37 PM
EsCoBaR1's Avatar
Ok THanks for the help
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
