EGT gauge
Old Apr 19, 2006 | 06:13 PM
stickmantijuana's Avatar
Unregistered User
EGT gauge
just got a defi EGT gauge from a friend of mine.
now some people are telling me I can use the EGT gauge instead of the wideband o2 to see if engine is running lean... someone else on this forum is now throwing me off by saying that the EGT numbers are meaningless without the torque curve.
bottomline is i just want a gauge that'll INSTANTLY tell me when my engine is running too lean, so i can step off of gas before i do any real damage.
I know wideband sensor will do this, but since i got this for free i was wondering if this will accomplish the same task.
thanks all.
Old Apr 19, 2006 | 06:17 PM
colin204's Avatar
It will not accomplish the same task, you will still need the wideband but having both will help keep your motor safe.
Old Apr 19, 2006 | 06:23 PM
Petrus's Avatar
v e i l o c i t y
Listen to colin204. You´ll need a wb02 sensor to read the afr and lambda numbers. The egt sensor can not do this although it can give you a hint if you´re engine is running lean or rich. A leaner mixture will produce higher egt´s and a richer mixture will provide a lower egt. But then again, you´ll need a reference point and it would still not be good enough.
Get a wb02 sensor. I myself use the zeitronix, it kicks ***!
Old Apr 19, 2006 | 06:24 PM
Unregistered User
why would i need both?
Old Apr 19, 2006 | 06:29 PM
Petrus's Avatar
v e i l o c i t y
Read again my friend... You DON´T need both, however having both will help to keep your motor safe. Too hot egt is not good you know.
Old Apr 19, 2006 | 06:32 PM
Unregistered User
got ya.
is there any 60mm wideband gauge you can recommend to be displayed next to defi BF gauges?? that way i can just replace the egt slot with the wideband one.
Old Apr 19, 2006 | 06:48 PM
guitarjunkie28's Avatar
port hacker
afr with a wideband, timing with an egt, or a knock sensor, if you have the means.
Old Apr 19, 2006 | 06:54 PM
Petrus's Avatar
v e i l o c i t y
Not really that easy...
I´ve never seen a 60mm wb02 gauge! The Zeitronix unit I have has a lcd-display (the size of a visa-card) that shows the afr, lambda, rpm etc.
Here´s my setup:
EGT gauge
Boost gauge
Water temp gauge
Oil temp gauge
Narrowband o2 gauge
+ Zeitronix WBo2
The 5 gauges is for driving monitoring (the narrowband o2 gauge just shows 3 different status; lean, stoich, rich)
I use the WBo2 sensor for tuning and logging afr, lambda etc... Once this is tuned I don´t need to monitor it that much. That´s why I use the narrowband o2 gauge instead.
Old Apr 19, 2006 | 07:03 PM
OontzTonic's Avatar
EGT gauge wouldn't be a great idea to use to see if its lean because it doesn't respond fast enough. WBO2 sensors respond very quickly, but EGT sensors don't give up to the second readings.
Old Apr 19, 2006 | 07:25 PM
rkostolni's Avatar
A WB won't tell you if you are pinging, an EGT gauge will. Although, with the Renesis, by that time the motor might already be done.
Old Apr 19, 2006 | 07:43 PM
BigOLundh's Avatar
#1 Legend
Yup, by the time the EGT tells you you are too lean, its probably too late.
-hS
Old Apr 19, 2006 | 08:22 PM
port hacker
Here´s my setup:
EGT gauge
Boost gauge
Water temp gauge
Oil temp gauge
Narrowband o2 gauge
+ Zeitronix WBo2
watch your egt's VERY CAREFULLY if you have a zeitronix gauge. it uses the 7057 sensor--totally unacceptable above 700c
a wideband that uses the ntk, lsu4-6066, or lsu-11 sensor would be much more trustworthy.
Old Apr 20, 2006 | 02:47 AM
Unregistered User
thanks for all your inputs guys. i guess i'll leave egt for now and look to purchase a wideband with an appropriate sensor asap.
thanks again for all your help.
by the way, how does egt detect pinging exactly? does it suddenly drop in temperature at high boost?
Old Apr 20, 2006 | 06:46 AM
Petrus's Avatar
v e i l o c i t y
No worries,,, I don´t use the zeitronix egt-feature. I have a VIVID gauge that reads up to 1400c.
Old Apr 20, 2006 | 08:31 AM
Unregistered User
http://cgi.ebay.com/ebaymotors/Innov...56159434QQrdZ1
what do you guys think?
Old Apr 20, 2006 | 10:52 PM
port hacker
nope, it still uses the 7057 sensor. they really don't like rotaries.
techedge makes a great unit. the more expensive plx is ok, and i'm happy with the turboxs unit i've been using the last ~9 months or so.
Old Apr 20, 2006 | 10:53 PM
port hacker
the egt is fine--i think it's just a k-thermocouple. it's the o2 sensor itself that has a problem with rotary heat.
Old Apr 30, 2006 | 07:34 AM
SWVA_RX-8's Avatar
Purge Addict
I have a question what type of senor are we suppose to use? Is this guage Okay-
https://www.rx8club.com/showthread.p...r%2Ffuel+ratio
Old Apr 30, 2006 | 02:53 PM
port hacker
i don't know why they say it doesn't oscillate the afr....the computer does that, not the sensor.
find out more info on that to see what kind of sensor it uses.
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
