Odometer replaced - reset to 0 miles problem
Old Apr 18, 2006 | 09:34 AM
Southsider's Avatar
Chicago Southsider
Back in January, one of the LED's on the gear indicator went out in my 8. When the dealership replaced the guages, they told me that the odometer was reset to 0 but that it is OK because they stamped in my warranty book the event marking the mileage at the time. I gave a little push back at the time, but they insisted that since they stamp the warranty book, it is no problem and won't de-value my car. I'm finding out not that is not the case.
I'm thinking that they did something wrong when they replaced it to lose my mileage and now they just don't want the hassle of fixing it. I have recently brought it up to them since I got it appraised and the dealerships are freaking out when they find out about the odometer and giving me BS apraisals of $11k, $12k for my car. They still contend that it doesn't de-value the car.
I guess my questions are:
1. Does anyone know the proper procedure for replacing the odometer in the RX-8?
2. Has anyone had their cluster replaced and their odometer wasn't reset to 0?
I just need a little ammo before I call Mazda NA Customer Support.
Thanks.
Old Apr 18, 2006 | 09:58 AM
Brice-RX8's Avatar
I had an old car that had the guage cluster replaced under warranty at the time and when I went to trade it, it did in fact hurt the trade in value of the care, even though there was documentation of the change taped into the door frame. From what I understand the dealer doesn't have to update the mileage on the odometer, they just have to document the mileage before the change.
I would push to get it updated, shouldn't be too hard to change with the new digital odometers.
Old Apr 18, 2006 | 12:22 PM
Southsider's Avatar
Chicago Southsider
You would think it wouldn't be difficult, but they are telling me its "impossible".
Old Apr 18, 2006 | 01:20 PM
Macius8's Avatar
Hehe its possible to change a digital odometer fairly easily from what I have seen. However I never have seen it done on a rx8. I say try to spush them to get it updated.
Old Apr 18, 2006 | 09:57 PM
zoom44's Avatar
its in the can module - they have to "suck" in the info in the module with the WDS or Equivalent then drop that info into teh new module. its not dificult at all- the sevice manual makes it very clear and the Service tool gives on screen prompts as to what to do next.
however now that your old one is gone there is nothing to get the info from and no way to change it. check with your states attorneys general office if this is a violation of state law.
Old Apr 18, 2006 | 10:05 PM
Gomez's Avatar
Shifty Bastard.
Alternatively, get another RX-8 with similar mileage to your car along to the dealership and have them suck the mileage out of that one.
Shouldn't cost you more than 24 cans of Bud!! Someone here will put their hand up, I'm sure .
Old Apr 18, 2006 | 10:11 PM
zoom44's Avatar
2005 - RX8 - Workshop Manual - Body Accessories
INSTRUMENT CLUSTER REMOVAL/INSTALLATION
CAUTION:
When replacing the instrument cluster, the configuration procedure must be performed before removing the instrument cluster.Replacing the instrument cluster without performing the configuration procedure will result in system malfunction.
1. Perform the instrument cluster configuration when replacing it.(See INSTRUMENT CLUSTER CONFIGURATION.)
1. Connect the WDS or equivalent to the DLC-2 (16-pin).
2. Input vehicle information following the directions on the screen.
3. Select “Module programming” from the menu.
4. Select “Programmable Module Installation”.
5. Select the item below, and follow the directions on the screen.
* Item
“IC”
Old Apr 20, 2006 | 12:27 PM
Southsider's Avatar
Chicago Southsider
Thank you guys.
Old Apr 20, 2006 | 07:30 PM
snap-on's Avatar
Before you take a knife to a gunfight...
Mileage is not "inhaled" when performing a PMI on a CAN module.
All the IDS inhales is the As Built data.
Old Apr 20, 2006 | 09:45 PM
zoom44's Avatar
is so! i cant find the exact phrasology right now. but ill find the exact wording tomorrow when i have time .
Old Apr 20, 2006 | 09:46 PM
zoom44's Avatar
oh and ttthhhhhppppppttt(thats a rasberry sound the boy was just making. i think he thinks it sounds like an elephant.)
Old Apr 20, 2006 | 09:59 PM
zoom44's Avatar
hmmmm had time now- and i cant find what i thought i read previously. just this crap that supports snap-ons side
SPEEDOMETER REPLACEMENT PROCEDURE
APPLICABLE MODELS
All Models
DESCRIPTION
In accordance with Federal regulations, follow the procedures listed below when replacing a speedometer.
NOTE:
1.
Mazda vehicles are manufactured with tamper-proof speedometers and the mileage can not be altered or adjusted.
2.
When a speedometer is replaced, the new speedometer will read zero (0).
3.
This procedure is extremely important to accurately represent actual vehicle mileage.
4.
The "Speedometer Replacement Label" referenced below is available through the Mazda Program Center for a limited time. Mazda Motor of America, Inc. is providing 1 sheet of 20 labels with this bulletin.
1. Remove and replace the speedometer according to the workshop manual.
2. Complete the following information on the "Speedometer Replacement Label."
Mileage before speedometer replacement.
Date of replacement.
Dealer code.
3. Attach the label to the driver's side "B" pillar.
4. Complete the "Speedometer Replacement Record" in the Warranty Information Booklet referenced below.
Old Apr 20, 2006 | 10:22 PM
cleoent's Avatar
n00b
I would hope that a simple device at the dealership wouldn't be able to change the mileage of clusters! that would lead to a whole knew realm of odo cheating.
Old Apr 20, 2006 | 10:41 PM
snap-on's Avatar
Yeah..I make that sound alot this time of evening.
Many Asian import models take "speedometer tampering" in a different perspective.
The Japanese translation makes no real sense to us as U.S. consumers. They look at the speedo as a "part" and we look at it as the "vehicle". All U.S. models I have dealt with have a way to call and order a speedo/odometer to match with the correct mileage. This avoids rollback reports when the car is registered.
This has been addressed at the highest level. Sadly our vehicle will always re-start with 00.0
DSTM=Don't shoot the messenger.
Old Apr 21, 2006 | 08:29 AM
Southsider's Avatar
Chicago Southsider
Unhappy
Had I known this or if the dealer trold me this before, I would have lived with the burnt out LED on the gear indicator.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
delicious_dallan
Jan 17, 2020 09:17 AM
rotorsnsaabs
Aug 26, 2015 08:21 PM
SIllver
Aug 1, 2015 07:34 PM
MarkX
Jul 31, 2015 07:50 AM
