Gears And Speed
Old Apr 15, 2006 | 09:45 AM
devious12's Avatar
Flame Thrower
Gears And Speed
I Searched But Did Not Know What To Look Under. If There Is Already A Thread On This Please Let Me Know.
I Was Wondering What Speed The Car Should Be At Depending On Which Gear Your In. If I'm In Second Gear And At 7,000 Rpms, Then What Speed Should The Car Be At? I'm Trying To Figure Out If The Issues I'm Having Are From The Engine Or A Faulty Clutch.
Thank You
Old Apr 15, 2006 | 10:02 AM
RazzyBRX-8's Avatar
Representin'!
uhm...shifting out of first into second at about 3500 RPMs and then punching/redlining second im at about 67. maybe 55ish?
That probably doesnt help but it was worth a shot.
Old Apr 15, 2006 | 11:34 AM
expo1's Avatar
He's as bad as Can
First post in the thread below has a chart.
https://www.rx8club.com/series-i-tech-garage-22/rpm-versus-mph-25420/
Old Apr 15, 2006 | 12:25 PM
yiksing's Avatar
the giant tastetickles
Thank You
Don't think this is an accurate way to diagnose clutch problem.
Old Apr 15, 2006 | 12:37 PM
therm8's Avatar
Bummed, but bring on OU!
Here's some approximate values (I believe they were calculated, and do not reflect speedo error, drag, etc).
Old Apr 15, 2006 | 01:05 PM
devious12's Avatar
Flame Thrower
Yeah I know it's not the most accurate way to tell. The problem is that the dealer is telling me my issue is with the clutch not the engine, which of course we all know is b/s. He said that if my car is in 2nd gear and only at 55-60 mph, then he can conclude that it is the clutch, not the engine. He said that the mph in 2nd gear should be 80... yah right!
Thanks for the help guys!
Old Apr 15, 2006 | 02:36 PM
RazzyBRX-8's Avatar
Representin'!
I redlined first today and then on the way back up in second at 7000RPMs it was like 57.
Old Apr 15, 2006 | 06:33 PM
Paul_in_DC's Avatar
Rotary Public
https://www.rx8club.com/showthread.php?t=25420
Dang! Wish I'd seen that before. I looked all over the net to find an rpm/gearing calculator! The numbers I get are very close to those on the chart, maybe 2-3% lower. Let's see if a 'paste' will work:
Gear
RPM 1 2 3 4 5 6
500 2 4 5 7 8 10
1000 5 7 10 14 17 20
1500 7 11 15 21 25 30
2000 9 15 20 28 34 40
2500 11 19 25 35 42 50
3000 13 22 31 42 50 60
3500 16 26 36 49 59 70
4000 18 30 41 56 67 80
4500 20 33 46 64 76 90
5000 22 37 51 71 84 100
5500 25 41 56 78 92 110
6000 27 44 61 85 101 120
6500 29 48 66 92 109 130
7000 31 52 71 99 118 140
7500 34 56 76 106 126 150
8000 36 59 81 113 134 160
8500 38 63 87 120 143 170
9000 40 67 92 127 151 180
According to this, 2nd gear at 7000 rpm should be around 52 mph, give or take.
Old Apr 15, 2006 | 06:43 PM
Paul_in_DC's Avatar
Rotary Public
ps - Here's the address for that Speed/RPM Calculator
Old Apr 16, 2006 | 09:44 AM
BunnyGirl's Avatar
Thank You
My manual says the recommended shifting points are (speed wise):
2nd: 14
3rd: 22
4th: 29
5th: 36
6th: 46
Old Apr 16, 2006 | 05:37 PM
Freddie's Avatar
2nd: 14
3rd: 22
4th: 29
5th: 36
6th: 46
I gotta think they tell us that in an effort to achieve their claimed MPG numbers.
However, I think that shifting at those speeds is:
1. Not really too good for the engine
2. Not really too much fun
I mostly shift at 5,000 to 6,000 RPM, higher if I'm feeling frisky. Both the engine and the driver seem a lot happier that way.
Old Apr 16, 2006 | 11:31 PM
Paul_in_DC's Avatar
Rotary Public
Yeah, those numbers imply shifting at ~3,000 RPM. Blech. My normal is around 5,000.
JimmyBlack
273
Feb 10, 2020 10:23 PM
nowakm99
Oct 9, 2015 07:10 AM
juicemantwon
Sep 26, 2015 12:30 PM
GARCIAC951
Sep 10, 2015 07:17 PM
titaneum_grey
Sep 6, 2015 10:21 PM
