Warped Rotors 18K
Old Apr 11, 2006 | 01:23 PM
LTABA's Avatar
Warped Rotors 18K
Just got back from dealer--pulsing brakes due to warped rotors, which are too far gone to machine. $650 for front brakes only...this is not a car that has been driven hard. Anyone received warranty assistance in a case like this? By the way, the dealer did a brake inspection at my request at 15,000 and found nothing.
Old Apr 11, 2006 | 01:27 PM
BlueRenesis82's Avatar
Registered Tracker
The dealer told you that they are too far gone? Take em to a machine shop and get a second opinion. Much cheaper to get em turned than buy new rotors
Old Apr 11, 2006 | 01:36 PM
LTABA's Avatar
I'm in Wis also, Madison--any recommendations?
Old Apr 11, 2006 | 02:01 PM
Brice-RX8's Avatar
Had mine machined by the dealer around 23k for free, they started pulsating again and asked them about it when I took it in a 26k for an oil change, this time they wanted $80 to turn them. I said no, when they get bad enough I will just get some better rotors on the web. I believe stock rotors from Mazda are around $150 a piece, there is better options on the web for cheaper.
From what I have heard and experienced once they are warped, machining just is a temp fix to it, they will act up again. I don't believe the factory rotors are of the highest quality.
Old Apr 11, 2006 | 07:10 PM
Registered Tracker
Originally Posted by abbid
I got mine replaced free along with brake pads. Keep at it, and show them the TSB of the brake squeel. That should get you somewhere.
and if you still are being quoted that high to get those bad boys replaced, youre better off getting a set of cross drilled/slotted along with new pads for less than that. ebay pwns.
.02
drilled FTL, slotted or solid are much better for longevity, esp. if you are hard on the brakes.
Old Apr 11, 2006 | 07:12 PM
Registered Tracker
I think Advance Auto parts or Checker will do it, just take the rotors off and have them check the thickness of the rotor. If they are so far gone that they won't even work after being turned, then I would contact MNAO for replacement. Brake rotors should last much longer than that, I have 24k miles of hard driving on mine, and no issues.
Old Jul 6, 2010 | 10:41 PM
silverkillrx8's Avatar
so is warped rotors the only explanation of the pulsing when i brake
Old Jul 6, 2010 | 10:51 PM
Pico's Avatar
It's Complicated
.02
+1
A good set of crossed drilled and slotted rotors will hold up just fine for daily spirited driving.
Careful with ebay brands-- do your research
Old Jul 6, 2010 | 10:52 PM
so i guess what i heard about drilled n slotted rotors isnt true i was told they dont last nearly as long and pads wear down faster
Old Jul 6, 2010 | 10:53 PM
maskedferret's Avatar
Oooh, shiny!
4 year old thread, yey!
Could be uneven pad deposits.
Old Jul 6, 2010 | 10:56 PM
well the only wierd thing is that when i got my new motor like a 2 months ago mazda did that whole inspection and said they r fine so obviously they know nothing
Old Jul 6, 2010 | 11:01 PM
Pico's Avatar
It's Complicated
^ Dam dealers
Just another reason I don't go to dealers unless I know I will be getting the work done for free...
Hell of a bump too
Old Jul 6, 2010 | 11:04 PM
laythor's Avatar
I zoom therefore I am.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Jul 6, 2010 | 11:14 PM
jasonrxeight's Avatar
donno how you guys drive, Ive never had wrapped rotors on my cars.
Old Jul 6, 2010 | 11:24 PM
paulmasoner's Avatar
Asshole for hire
most likely, since rotors never/almost never warp. bed your pads properly and use pads that have a heat range condusive to your use and you wont have that problem
Old Jul 6, 2010 | 11:28 PM
ne suggestions on good pads to get
Old Jul 7, 2010 | 12:58 AM
yiksing's Avatar
the giant tastetickles
Try re-beding the brake pads, it could just be a small problems. Warped brakes is sort of a myth and even if its true its unlikely to happen from street driving.
Old Jul 7, 2010 | 03:46 AM
Yep could be deposits.
fine means they are in tolerance. If they measured them, that means they could be .001 from the limit and they are still fine.
Especially when it comes to used cars. Everyting is fine.
Buyer BE WARE
Old Jul 7, 2010 | 10:22 AM
ken-x8's Avatar
They do warp if the lug nuts are not tightened evenly and in the right sequence. I've had that happen several times after state safety inspections. But they've usually come back after loosening and properly tightening the nuts.
Ken
Old Jul 7, 2010 | 09:07 PM
it seems like its not all the time and idk how that makes any sense like it didnt do it today that i noticed and im just kinda doing some minor testing as far as hard braking and easing on the brake
Old Jul 13, 2010 | 02:11 PM
well ive been watching my braking and it seems like they only make the pulsating when its hot outside because when i go to work at 4 am i have no problems but when i get off and its in the high 90's it does it idk if there is any explanation for that
Old Jul 13, 2010 | 02:40 PM
DarkBrew's Avatar
Extraordinary Engineering
For a daily driver it's hard to beat Hawk Ceramic pads
Old Jul 13, 2010 | 08:23 PM
elysium19's Avatar
there is so much misinformation on this thread... thank you paulmasoner and others for at least trying to clear it up a bit
it is VERY unlikely that you have actual warped rotors.
Unless you're looking to spend thousands of dollars for a very track-oriented setup, sticking with the OEM brakes are by far your best option.
Bring in the TSB as recommended. The service people "should know better" and these guys sound like they're trying to dick you over, so you should ideally find another service place. Customers shouldnt have to haggle for the proper car under warranty.
good luck...
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
coolcars44
Sep 24, 2015 05:47 PM
