JIC Install issues
Old Apr 1, 2006 | 11:36 PM
Bindon's Avatar
Fire-Spewing Maniac
JIC Install issues
So I have all the bolts undone, and the shock unbolted at the top and bottom
But for the life of me, I cant figure out how to walk the shock and spring out of the wheel well!
I pull the bottom of the shock towards the rotor and it slides down a bit into a lower area of the lower A arm, then the threads on the top pop out of the holes, and its free from all braces. This is where it gets wierd. youd think you could pull the shock right out, but no! the seat of the shock (where the spring sits) is hitting the upper control arm... so am I doing this completely wrong?? Im using a diy, but im thinking that because I have S-TECHS it may be harder to walk it out because the spring is harder.
SO maybe ill get a spring compressor and do it that way?
Please help, my cars sitting on jackstands
Old Apr 2, 2006 | 12:35 AM
You need to remove the upper A-arm bolts on the front to get it out..you also need to have both sides removed and drooping...or remove the sway end-link on one side.
Then you can get it out
Old Apr 2, 2006 | 12:52 AM
Bindon's Avatar
Fire-Spewing Maniac
so unbolt the entire A arm??/
How does unbolting the sway end link help?
Old Apr 2, 2006 | 01:01 AM
Sway bar will keep the lower control arm from drooping as far as possible.......If you are careful you don't need to...let both sides droop and it will come out. If you do 1 side at a time...loosen the end link
Old Apr 2, 2006 | 03:58 AM
you unbolt the upper A-arm from the two sets suspension bushing tabs on the inner sidewall, this lets you swing the top of the shock assembly outside the wheelwell where you can then extract it out, it's pretty easy once you see how it's done, you don't have to pull the end link if you have the shocks unbolted on both sides
wait until you get to the rear ...
Old Apr 2, 2006 | 07:41 AM
Also....undo the headlight adjuster switch...if you break it they are expensive
( front and rear drivers side)
When you do the rears undo the top rear trailing arm and not the rear.....then it won't be as hard on your alignment settings...ie//you can at least drive it to get an alignment
he part I found difficult was adjusting the coilovers themselves to get the proper preload and ride height. They came setup too low for what i wanted. When you set them...leave the preload the same and adjust the ride height only.
Old Apr 2, 2006 | 11:31 AM
Bindon's Avatar
Fire-Spewing Maniac
for sure.
So right now, the car is completely jacked up (it was only on one side before) and both wheels are off.
Im waiting for the liquid wrench to work on the bottom bolt for the shock assembly on the other side.
It seems that the shock wont slide down as far now, because the upper A arm is lower.
So do you suggest remove the end links? will this make it easier ot play with?
Or should I unbolt the upper A arm, although, i cant see how this would help all that much.
Maybe im moving the shock in the wrong direction? do you guys slide the shock off the side of where its sitting (towards the front of the car) or do you pull it towards the disk to get it to slide into that groove??
Old Apr 2, 2006 | 11:44 AM
You don't follow directions very well
Old Apr 2, 2006 | 11:50 AM
Bindon's Avatar
Fire-Spewing Maniac
so ill undo the upper control arm, swing iit up, then slide the **** out, got it., will try it
Old Apr 2, 2006 | 12:20 PM
Undo the 2 bolts on the INSIDE of the A-arm Not the outboard Ball joint end
Read the above again....and if you follow our directions it will work...if not......
Well good luck! :D
Old Apr 2, 2006 | 01:42 PM
Bindon's Avatar
Fire-Spewing Maniac
Phew those bolts are a ***** to get at. I loaded some more liquid wrench on, and im gonna go out and get a better set of metrics, I left my good set back at home.
While im out, any suggestions on a tool that would make it easier to get at those nuts?
Maybe a speed socket?
Old Apr 2, 2006 | 04:19 PM
Use 6Pt 17MM socket...then you won't strip the nut/bolt. U can use 12 pt after you crack it to get better angles on the ratchet. U need a good length bar to loosen them the first time....esp cause of the salt corrosion in the winter
Old Apr 3, 2006 | 04:00 AM
umm, the nuts on the inside for the upper control arm bushings are welded to the brackets, you have to undo the bolt heads on the outside ends of the bushings ... I just use a 1/2" ratchet, an 18" or 24" long one will give you a lot more leverage, and by all means only use 6-point sockets
Old Apr 3, 2006 | 07:00 AM
Nut/bolt on the shock...bolt on the A-arm Team...you must be a teacher
Old Apr 3, 2006 | 01:34 PM
they say a picture is worth a thousand words, forgive me for being so wordy
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
drebbrnator
Dec 27, 2018 07:02 PM
Stubbs
Jul 28, 2015 09:23 PM
dbarber
Jul 25, 2015 01:34 PM
