how would these specs look?
Old Mar 29, 2006 | 10:59 PM
eastaznboi's Avatar
g35/350z's have the same bolt pattern as the rx8 right?
how would these specs look on our 8
19x8.5 245/35/19 front, 19x9.5 275/30/19 rear 20 mm offset all around.
i saw that huff04titanium had the same set up with smaller tires and a higher offset of 35. https://www.rx8club.com/showthread.p...=tsw+thruxtons
how will the 20 mm offset look on the 8, will it make the rims go farther into the wheel well or make it stick out more?
there's someone local that's willing to sell it for 1200 for the wheels and tires with only 800 miles on them. you guys think that's a good deal? thanks in advance
Old Mar 29, 2006 | 11:08 PM
hoosteen's Avatar
"No 8 Left Behind"
20 offset will stick out more.
20 offset is WAY too low... you'll end up ripping a fender off if you hit any bumps.
I'd say lowest would be +42 as a general rule... although it all depends on wheel, width of wheel, and tiresize.
Old Mar 29, 2006 | 11:09 PM
epitrochoid's Avatar
Riot Controller
yes, Z33's and G35's are designed with much lower offsets, particularly in the rear. you will almost certainly rub and cause damage
Old Mar 29, 2006 | 11:12 PM
NgoRX8's Avatar
^what they said. Man 20 mm offset, that'd stick outta the fender bad.
Old Mar 29, 2006 | 11:38 PM
eastaznboi's Avatar
ahh that sucks, i thought i found a good deal :-P i guess it just wasn't meant to be. 1200 was a good deal right? so the rule of thumb is to get rims with at least a 42 mm offset, any number i shouldn't go past?
Old Mar 30, 2006 | 12:37 AM
BigOLundh's Avatar
#1 Legend
when i was looking for rims... i was on ClubRSX.com very often. There offsets are similar to ours, and they usually never run staggered since they are FWD. I was looking for 17s at the time, but if you want 18 or 19"... they probably won't have it.
If you don't mind having a staggered setup, check Club240.com - Their offsets are similar to ours, and youll usually be able to 5X114.3 pattern wheels easily. They also have 18 and 19" rims on their occasionally.
Quiggs321
Sep 30, 2015 05:34 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
djp6783
Sep 19, 2015 12:12 PM
patriotjj
Sep 13, 2015 08:09 AM
