Where is System Outlet for Canscan?
Old Feb 25, 2006 | 04:43 PM
Tastic's Avatar
All of the instructions I've encountered imply that everyone knows where it is. One said is next to the hood release. It is not visible to me near the hood release. Could someone tell me how I can get to the plug with some level of detail?
Old Feb 25, 2006 | 05:03 PM
StealthTL's Avatar
Metatron
Arrow Under....
Under the dash.
I believe the OBDII spec calls for it to be "within 100mm of the steering column".
S
Old Feb 25, 2006 | 06:11 PM
jowettw's Avatar
funemployed
conveniently located right ABOVE the clutch pedal. you gotta get on your hands and knees to see it. good luck not knocking the thing loose while driving - i have that problem ALL the time.
Old Feb 25, 2006 | 06:41 PM
Tastic's Avatar
Wow I'm dumb. I was looking under the hood where the release latch is. Thanks for the info.
Old Feb 25, 2006 | 09:14 PM
Student Driver
Sorry for the jack...
If I understand you correctly, the can-scan is permanent?
After you get your map the way you want it the Can-Scan can't be removed?
Forgive my ignorance......
Old Feb 25, 2006 | 09:53 PM
jowettw's Avatar
funemployed
CAN stands for "Controller Area Network" - which is just another way of saying OBDII (i think the difference is data rate is faster vs. OBD2 systems).
CAN is just a diagnostic tool to let you see how the car is behaving - you can't change any AFRs with JUST a CAN tool. with a CAN tool (Autoenginuity/ Dan Harrison's/ Hymee's Scananalyser) and software and a laptop, it'll tell you info about your car: RPM, speed, ambient air temps, catalytic converter temps, AFR, ignition timing, etc.
with the info you are logging from the car, you develop a map specific to your car and upload to a piggyback or ECU to make the actual changes to your AFR.
Old Mar 10, 2006 | 07:28 AM
Hymee's Avatar
Race Steward
<shamless plug>
No such problem with the sCANalyser, it has a convient right-angled low-profile connector to keep the stuff out of the way. Perfect for leaving the cable/interface in all the time.
</shameless plug>
Cheers,
Hymee.
Or should I have said "shameless connector" hahaha.
Old Mar 11, 2006 | 01:50 AM
Originally Posted by Hymee
<shamless plug>
</shameless plug>
Cheers,
Hymee.
i have to agree, it is a great product. and the latest software is the bomb.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
Jb4ker96
Sep 27, 2015 10:06 PM
MolsonB
Sep 11, 2015 12:24 PM
