Trans & Diff fluid change = CEL... Why?
Old Feb 12, 2006 | 09:15 AM
MadDashRX8's Avatar
Resu Deretsiger
Switched over to Red Line mt-90 and 75w90 this weekend. Also replaced the tires at the same time. Left the dealership with a check engine light. I'm guessing it's due to the fluid level drop in the tranny. Does the car know when that fluid is low? I'm pretty sure that's all it is. See anything wrong with just resetting my ECU?
Old Feb 12, 2006 | 11:23 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Why don't you get your CEL code pulled and remove all the guess work? The CanScan and Scanalyser tools are very good investments. Might be something as simple as a loose gas cap. There's no reason changing your fluids should trigger a CEL unless your dealership screwed something else up (which is another great reason to this this easy work yourself).
nowakm99
Oct 9, 2015 07:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
