Installing HKS suction, have one question...
Old Feb 4, 2006 | 03:26 PM
DailyDriver2k5's Avatar
The Prototype
For you guys with the HKS suction kit, the wires coming off of the MAFS connector going to the silonoid valve connector. Once you take off the stock box,what do you do with that connector going to the silonoid valve? Do you take off the silonoid valve off the stock air box and re-connect the connector and put it aside?
Or do you not worry about the connector because the silonoid valve won't be needed anymore?
The HKS instructions dosen't go into detail about this part, thanks.
Old Feb 4, 2006 | 06:00 PM
toca's Avatar
u dont worry about it just plug the line with a cap by the intake tube at that thing is for a to tell the air temp does nothing with the afr so u be fine
Old Feb 4, 2006 | 07:24 PM
StealthTL's Avatar
Metatron
Plug....
Cap the vacuum connection, under the throttle body, remove all the black tubing.
Leave the electrical solenoid connected, disconnecting may be a check engine light cause.
S
Old Feb 5, 2006 | 10:24 AM
toca's Avatar
nope no check light with if off
Old Feb 5, 2006 | 10:58 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Not exactly... that solenoid operates the VFAD door that opens at high RPM (7250?) to allow more air in... nothing to do with the air temp. If you plug the vacuum line, it forces the VFAD door open (which is its default position until vacuum is applied)... which is what you probably want with an aftermarket intake anyway.
Old Feb 5, 2006 | 05:47 PM
Moonrover333's Avatar
My Goodness My Guinness
ok what solenoid are we talking about, can i get a picture, or is it that thing that is snapped onto the stock airbox i left all the stuff hooked up when i put on my simota intake its just laying under the intake
Old Feb 5, 2006 | 09:59 PM
G8rboy's Avatar
It's the solenoid attached to the left rear of the airbox with two screws... if you left that and the black snap-in chamber thing from the right side laying underneath your new intake that should be fine too... the VFAD will continue to operate as it did with the original airbox. The consensus on the VFAD is it can be left open at all times with the only downside being more intake noise at all RPM's, rather than just during high RPM operation.
Old Feb 6, 2006 | 02:58 PM
wurd up thanx
Old Apr 8, 2006 | 04:17 PM
S
just trying to verify that I can leave the VFAD solenoid off without any issue?
thanks
Old Apr 8, 2006 | 04:38 PM
G8rboy's Avatar
thanks
Mine has been disconnected and removed from the car for two weeks now (because of RB ram air duct installation)... no CELs or problems otherwise.
Old Apr 8, 2006 | 04:47 PM
thanks
Old Apr 9, 2006 | 02:39 AM
ddub's Avatar
always preoccupied.
Yah no issue, I ziptied the plug off to the side after the AEM installation.
JimmyBlack
273
Feb 10, 2020 10:23 PM
FubarI33t
Sep 28, 2015 08:45 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
Rupanrx
Sep 4, 2015 06:44 AM
