#@%$ help
Old Jan 29, 2006 | 03:43 PM
Moonrover333's Avatar
My Goodness My Guinness
Angry #@%$ help
ok so i bought my car bout 5 mo ago and whoever had it previously decided they wanted to keep the mcguard key. thankfully they left me the registration card so i ordered one directly from mcguard. it came in last week and so today i go to pull wheel to clean up rotors. well i put key on (goes on perfectly) i try to loosen and aparently someone over tightened the crap out of it. so i put all the muscle i can into and *CRACK!* it broke the top of the lugnut itself off. so i cuss it for bout 10 min than try to somehow get the key on again no good. so i go around to other wheel and same thing. now i have 2 busted lugnuts stuck on there and a screwed up key. does anyone know a trick on how to get lugs off?
heres the passenger rear wheel
heres the driver rear
any help is good folks
Old Jan 29, 2006 | 03:49 PM
automaton's Avatar
Take it to a shop and have them drill the lug out and install some new ones.
Is the car still under warranty? If it is, that covers the lug nuts, too.
Old Jan 29, 2006 | 03:50 PM
expo1's Avatar
He's as bad as Can
Looks like a job for a tire shop.
Old Jan 29, 2006 | 03:53 PM
yeah mazda said 36bux to remove locks
ok thats what i figured i guess i'll ask around and see what peopel can do
mcguard can bite me
Old Jan 29, 2006 | 04:00 PM
two rotors's Avatar
If you bought the wheel locks from a Mazda dealer,take your car to them and let them deal with the problem.The chances are your wheel will be damaged drilling off the broken locks--let Mazda pay for it.
Old Jan 29, 2006 | 05:33 PM
Nubo's Avatar
Lubricious
I keep debating whether or not to ditch the locking nuts and put the oems back on. Those pics have just about convinced me. Mazda's specs for the lug nuts are 108 lb-ft of torque which is pretty damn tight.
Old Jan 29, 2006 | 05:37 PM
Terrance26's Avatar
8 all the way
This happened on my beretta once. Get a socket just a little bit bigger that the nut get a hammer and beat the socket on it and when you get it on tight enough loosen it the socket is no good afterwards, but it worked for me.
Old Jan 29, 2006 | 05:45 PM
DarkBrew's Avatar
Extraordinary Engineering
Nubo,
I was looking at these to replace the original locks because thay look harder to strip.
http://www.tiretrends.com/acc_catalo...ccessoryID=189
Right now I am running similar shaped fasteners requiring a large allen key.
Old Jan 29, 2006 | 07:13 PM
i bought the key from mcguard and i bought the car from a used car dealer so i guess i'm gonna have to just find away to remove it, also i tried the just a bit larger socket trick no good it won;t go on or it just breaks more
so basically i'm screwed
which sux cause i need to do brakes and i have 1 tire leaking god my luck sux
Old Jan 29, 2006 | 07:18 PM
Nemesis8's Avatar
Bigus Rotus
Except the locking lug nut is round on the outside... No hex to grab.
Old Jan 29, 2006 | 07:30 PM
Ericok's Avatar
Rotary Wanker
Sears sells some special fluted sockets designed to remove damaged nuts. Don't know if they make one big enough for a lugnut.
Old Jan 29, 2006 | 07:38 PM
^ yeah i tried that too lol just too small
Old Jan 29, 2006 | 09:43 PM
MazsportScott's Avatar
Mazsport.net
Snap on sells a couple of sockets just for this problem. Someone at local tire shop probably has one.
Old Jan 29, 2006 | 09:51 PM
Ike's Avatar
Ike
Blue By You
Originally Posted by MazsportScott
Snap on sells a couple of socket just for this problem. Someone at local tire shop probably has one.
That's for people that son't have the key I believe, not people who break the locking lugnuts.
Old Jan 30, 2006 | 06:40 AM
Go48's Avatar
Yeah, 108 ft-lbs is way too high. I think that number is recommended as a fix for cars experiencing the snapping noise in the front wheels. I wouldn't go beyond 80 ft-lbs.
Old Jan 30, 2006 | 06:55 AM
sco's Avatar
sco
That's the point of hitting the socket on with a hammer... forcing one far enough will hopefully get you enough grip to turn it. This is exactly how theives remove these and why they are useless to stop anyone other than an opportunist with a only a standard wheel brace.
Forcing a socket on is what I'd be trying next.
Old Jan 30, 2006 | 07:02 AM
Gomez's Avatar
Shifty Bastard.
Spot-on sco. That method of lock nut removal is standard fare in the tyre shops.
Old Jan 30, 2006 | 07:41 AM
Go48's Avatar
Man, you Aussies stick together, but what's with this "tyre" thing?
Old Jan 30, 2006 | 02:04 PM
lol ok well i guess i'll try again but these are pretty hard i'll try again this weekend
Old Jan 30, 2006 | 02:37 PM
rkostolni's Avatar
I lost my wheel key one time and used a set of reverse threaded sockets specifically made to remove those lugs. I got my set from salvo's, but you can probably find them at just about any big autoparts store. I used an electric dewalt impact gun with those sockets and it worked great. 5 Minutes or so and I had them off.
Old Jan 31, 2006 | 03:24 AM
^if i can find em i'll def try that
