Oil consumption
Old Jan 25, 2006 | 10:47 AM
bd32322's Avatar
Question Oil consumption
My 8 is a week old and I checked the oil after 2 gas fills - its used up one-quarter of a quart (US quart). Wondering what kind of oil comsumption you guys have seen.
The oil level was between full and the first mark - the first mark is 0.5 US quarts I think.
Thanks,
Bodi
Old Jan 25, 2006 | 10:56 AM
StealthTL's Avatar
Metatron
New.....
You should really look around the site before posting such a basic question. Lots of info on that subject.
The car uses more oil when it's new, the consumption should settle down after a few thousand miles. One quart per 3000 would be normal....
S
Old Jan 25, 2006 | 10:58 AM
expo1's Avatar
He's as bad as Can
Did you check it the day you picked it up? A week is not enough time to tell if anything is wrong. The RX-8 uses oil by design, mine takes about a quart every 3,500 miles. So continue to check every 2 fill-ups and get back to us after a few thousand miles.
Old Jan 25, 2006 | 05:43 PM
Nubo's Avatar
Lubricious
Thanks,
Bodi
That works out to (very roughly) 1600 miles per quart. That's just fine. The oil consumption is VERY dependent on driving conditions. High-rpm driving uses a lot more, and stop&go traffic does also since it results in lots more engine revolutions *per mile*. I've had times where I've gone through a quart in 1000 miles due to traffic congestion and I've gone on 1000 mile trips using just a few onces.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
