NorthWest RX8 Dyno day pics, etc.
Old Jan 21, 2006 | 07:32 PM
dmp's Avatar
dmp
RX8 and a Truk....
Thanks to those who made the trip out! I think there were as many rx8 owners who just showed up to hang out, as there was who actually dyno'd. Fantastic!
Here's my car's 'before and after'...the redline is my car last year, Stock w/ M-Flash, < 3K miles
The higher line is my car today, with R-Flash, RB intake and RB Catback, and 16k miles. Fairly substantial gains in the higher rrpms, I'd say. Over-all peak power went up by 11, but more at some points in the curve - as shown the difference is greater.
Here's another - both were 1st-6th gear runs. Ignore the choppiness of the 1st few gears, the car was shaking on the rollers. Note the substantial (for a N/A RX8) increases between the two plots. This run (5th gear) was my car's highest number-reached, of 197.
partial video of that run:
http://www.d-mphotos.com/movies/dmpdynofullgear.wmv
Note custom intake manifold:
Group watching a very nice MS-Kit RX8 run. I say the MS kit gave him power, as he made 197whp with just a RB Catback as his only mod. Unknown flash - 27k miles.
More Black MS Kit
http://www.d-mphotos.com/movies/blackmsRx8dyno.wmv
Silver. Downforce didn't help while on the dyno.
Nemesis and Me
dannobre
Group
Parked, and ready to eat lunch
More vids:
First run of the day:
http://www.d-mphotos.com/movies/2rotordyno.wmv
Nemesis partial run:
http://www.d-mphotos.com/movies/kevinrx8dyno.wmv
Spark at 2500, 5000, 10000, 25000 rpm intervals.
http://www.d-mphotos.com/movies/sparky.wmv
Guys - post up and claim your pics! I don't rememberl everyone's name, so that'd help too!
- Darin
Old Jan 21, 2006 | 08:09 PM
BlueRenesis82's Avatar
Registered Tracker
what is that DOHC ford doin in those pics?
Blue87Sport's Avatar
Rotary only since 1980
Nice pictures as always, Darin.
The first picture below your dyno charts is very interesting. If it is an RX-8, it has more than just a custom intake manifold done to it. That thing have a Hemi in it?
Old Jan 21, 2006 | 08:10 PM
Nemesis8's Avatar
Bigus Rotus
Awesome - how did you get back so quickly and post all this up?
Old Jan 21, 2006 | 08:18 PM
Nice Mod Darrin...is that your car :D Didn't know you liked Ford engines. How the hell did they get that crammed into your 8
Old Jan 21, 2006 | 08:20 PM
dmp's Avatar
dmp
RX8 and a Truk....
I LOVE ford Engines. :D
I How did YOU get back so quickly, Kevin?? lol...I got to my Dad's for taxes in Kent around 3:20...left there at 4, got home and started fixing pics and vids.
:D
And yeah, w/ my new 5.4L Kenne Bell SC'd V8, I've lost my car's 50/50 weight distro - it's worth it, however.
Old Jan 21, 2006 | 08:27 PM
Nemesis8's Avatar
Bigus Rotus
Raw scans from Carb Connection
I picked up 16.9 RWHP and 6.2 FT/LBS of Torque over last year. Mods are Unorthodox Pulleys and the CZ. My fuel map is not perfect, and the timing map is zeroed. I did not have time to get the Innovative Wideband installed to properly tune the maps. I used an older fuel only map, and it looks like 13.3 at the peak HP. Need to fine tune it now. The only other bolt on I could add will be the header.
Attached Thumbnails NorthWest RX8 Dyno day pics, etc.-rwhp_torque_web.jpg   NorthWest RX8 Dyno day pics, etc.-rwhp_afr_web.jpg
Registered Tracker
you jammed a cobra engine into your 8? wow
Old Jan 21, 2006 | 08:31 PM
dmp's Avatar
dmp
RX8 and a Truk....
This really bothers me - Note TaeYung's dyno (blue) over-lapped with one of my runs.
TWENTY-SIX HP difference...and wtf is up w/ my A/F ratio????
I'm REALLY hoping the 11K miles more his car has is the difference.
Old Jan 21, 2006 | 08:34 PM
dmp's Avatar
dmp
RX8 and a Truk....
Indeed- Adobe makes a universal engine-swap kit.
Old Jan 21, 2006 | 08:37 PM
Registered Tracker
ok maybe im reading that wrong, but it looks like your car is putting down 197 hp?
Old Jan 21, 2006 | 08:38 PM
dmp's Avatar
dmp
RX8 and a Truk....
Yeah - did on one run. The other guy did on a few runs.
Old Jan 21, 2006 | 08:41 PM
Registered Tracker
ok, so how much power are you expecting on that?
damn,i just realized that its a lightning motor.....
Old Jan 21, 2006 | 08:43 PM
dmp's Avatar
dmp
RX8 and a Truk....
On my car's motor? I expect 200whp eventually - or, 238hp at the flywheel - what the car SHOULD have had, stock.
:D
Actually, the engine was from a Mustang Cobra - 550whp, if I recall.
Old Jan 21, 2006 | 08:45 PM
Registered Tracker
I thought Cobra's were 4.6 DOHC, but I don't keep up on em as much as I used too. Those cobra engines sure do sound good thru a Borla exhaust, just a mean growl.
Old Jan 21, 2006 | 08:57 PM
Ducky's Avatar
haha.. damn there was evidence I was there with my daughter... must... hide... pic.
Old Jan 21, 2006 | 09:05 PM
Nemesis8's Avatar
Bigus Rotus
There was also a 562 HP Procharged C5 Vette there with Nitrous! It had Borla out back that was awesome
Old Jan 21, 2006 | 09:08 PM
lazi's Avatar
drivelinestore.com
ncie vid. not bad on the numbers
Old Jan 21, 2006 | 09:58 PM
Darrin: I think part of the difference comes in the way the ECU handles the closed loop to open loop transition. Yours went into open loop later than his....the leaner A/F in closed loop won't make as much power. Your A/F was the same ater the transition. It seems that the load variable with time must alter the transition point. If you can remember if you went straight into 5th without a coastdown....or if you had a wait to drop the startup RPM it might give us an idea what happened. I got the scanner working on the way home(...and got some tires too )as per usual I really wanted to get logged runs that would have shown us a lot of the data that we need to see what the variations are caused by.
Better luck next time I guess
Old Jan 21, 2006 | 10:00 PM
Nemesis8's Avatar
Bigus Rotus
Oh yeah, got it working on the way home ehhh
Old Jan 21, 2006 | 10:02 PM
Ya...it ran all the way home without crashing......it worked great........what's up with that
Old Jan 21, 2006 | 11:16 PM
e46328's Avatar
hey DMP, thanks for posting the vids.
I am glad my car did pretty well w/ just racing beat cat back
Old Jan 21, 2006 | 11:19 PM
dmp's Avatar
dmp
RX8 and a Truk....
I've got a vid of your car on the dyno if you'd like me to post it - shows lotsa smoke and stuff and junk. Oh - and I think I kept the pedal at about half-throttle between the shift; is that what you mean?
dmp's Avatar
dmp
RX8 and a Truk....
I am VERY jealous of your car's engine!! lol :D
- darin
Old Jan 21, 2006 | 11:58 PM
ECHO1's Avatar
don't forget about that twin-turbo gto up on the lift though i think the boosted and juiced c5 wins in the wow factor department
kudos darin for putting this all together!
