People who have aftermarket gauges...
Old Jan 13, 2006 | 05:24 AM
BlueRenesis82's Avatar
Registered Tracker
What if any other hardware did you need for the install? I have a set of Defi BF gauges with the control brain box and I just ordered teh RB oil and water sensor adapters. Any other wiring or cables I might need?
Old Jan 14, 2006 | 05:14 PM
Registered Tracker
bump for a decent question
Old Jan 16, 2006 | 08:48 AM
rkostolni's Avatar
What gauges are you installing?
Old Jan 16, 2006 | 09:30 AM
XeRo's Avatar
Normality is Obscene
well...based on the fact that he said Defi BF guages as well as the brain...and then i think he hinted towards Oil and water since he did buy the adapters from RB...i could be WAY out there...but i'd put money on that what he's gonna be getting..or got...
i did this same thing but with Blitz BLM guages...mounted on the A-Pillar in CF...Oil P/Oil Temp/Water Temp...
Old Jan 17, 2006 | 01:34 PM
Registered Tracker
Thats what I have, Oil temp/pressure and water temp. I have a custom pod. So any other hoses or stuff?
Old Jan 18, 2006 | 10:31 PM
Registered Tracker
bump!
Old Jan 19, 2006 | 06:38 PM
ScudRunner's Avatar
On time, on target
I didn't need any other hoses, etc. All of the wiring that came with the gauges was sufficient. However, the RB Water Temp adaptor is threaded in a different size than the DEFI Water Temp Sensor. I think it would be fair to say the Oil Filter sandwich block would be the same way. That's easily fixed by going to the plumbing section of Lowe's/Home Depot and buying an adaptor fitting. IIRC, you need to go from 3/8" down to 1/8". The only other problem I experienced was after I put in the RB Water Temp sensor; I got an air bubble in my coolant lines and couldn't get hot air in the cabin anymore. Quick little bleed and refill solved it.
Old Jan 19, 2006 | 09:29 PM
Registered Tracker
so just those 2 adapters?
Old Jan 19, 2006 | 10:13 PM
ScudRunner's Avatar
On time, on target
You might need three, one for the water temp and one each for the oil pressure and oil temp. That should do it for ya.
Old Jan 19, 2006 | 10:41 PM
Registered Tracker
thanks so much!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jb4ker96
Sep 27, 2015 10:06 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
