Technical thoughts on the rotary from tprmag.com
Old Jan 10, 2006 | 10:40 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
An interesting article sent to me by a friend. Note the authors. I pasted the first page for you to read. Click the link if you are interested in reading more.
I dont care if this is a repost. Just ignore it if you have read it before.
http://www.tprmag.com/issue/11/11_rotary_1.shtml
Originally Posted by TPRmag.com
The Lab: Rotaries Revisited, From 13B To Renesis
Technical Info By Jim Mederer and Chris Ott
Supporting Text By Arnold Eugenio
Photographs Provided By Racing Beat
This issue's topic will be a discussion of some of the distinctive features of a Mazda rotary when compared to a production-based four-stroke reciprocating engine. Much of the comparison will be technical, but some will be based on opinion.
For simplicity, we'll compare two 1-cylinder engines and we'll only talk about one of the rotor flanks.
All rotational angles are quoted for the output shaft (eccentric shaft/crankshaft), not the rotor. Both engines burn a compressed fuel-air mixture to develop rotational power. Both are four-stroke engines.
However, one big difference between them is that the recip has 180 degrees per stroke (or 4 x 180 = 720 degrees per thermodynamic cycle) while the rotary has 270 degrees per "stroke" (or 4 x 270 = 1080 degrees per thermodynamic cycle). Yeah, you may have to think about that one for a bit, but trust us, it's true.
This has some good and some bad consequences. Assuming that both engines have similar maximum rpm's (and I think that is roughly true), it means that the rotary has 1.5 times as many milliseconds to accomplish each "stroke". This is the reason why rotaries breathe so well - they have more time (in milliseconds) to draw in and spit out the mixture. They also have more time for the power stoke - a real plus to get the most out of the combustion gas, especially at high rpm.
Now the bad part. The rotary also has 1.5 times as many milliseconds to transfer heat from the burning mixture into the oil and water. This is one reason why rotaries waste more heat in the process of staying cool. Another consequence is that, if you only consider one flank of one rotor, the rotary only gets 2/3 times as many power pulses as the recip. However, there are 3 flanks to each rotor, each at a different point in the thermodynamic cycle, so each complete rotor actually gives 2 times as many power pulses (3 times 2/3) as a 1 cylinder recip. Confused? Take a moment to study Figures 2 and 3 and soak it all in!
Put another way, a 2-rotor rotary has the same number of firing pulses as a 4-cylinder recip, but the DURATION of each firing pulse is 270 degrees, the engine runs smoother due to the overlap of the firing pulses.
OK, so what is the point of all this math? Well, the point is to get a better understanding of WHY certain things are so important to a rotary - especially heat transfer. Remember, heat is potential power, so keeping heat in the combustion mixture makes more horsepower you can use.
On to the next item: In comparison to a recip, the intake charge (once it is inside the engine) actually travels a long, tortured path, as shown in the combustion cycle shown above. In a recip, the center of gravity of the intake charge only moves an inch or two as the piston moves back and forth between top dead center (TDC) and bottom dead center (BDC). In Mazda's rotary, the charge moves along way more like 20 inches-from intake to exhaust. One bad result is that there are a lot of square inches of surface through which to transfer heat, reducing thermal efficiency. However, here is the big point: The entire mass of the intake charge must pass through the narrow area between the rotor housing and the rotor as each rotor flank passes through TDC. This is made possible by the "rotor depression" which is cast into each flank of the rotor-if it weren't for that path, the partially burned mixture would never be able to squeeze through the narrow clearance between the rotor housing and rotor (usually around .010-.015 inch) at high rpm. There is a crude parallel with a recip that has a "pop-up" piston that tends to cut the combustion chamber in two at TDC. Some recips even cut a "fireslot" (notch) in the middle of the pop-up area to prevent it from stopping flame front propagation in the chamber. Fo this reason and others, the shape of the rotor depression is quite important. It also has a major influence on determining the compression ratio of the engine and, as all the "Internal Combustion Engine" textbooks point out, the compression ratio is a major determinant of the power and efficiency of any engine. Actually, this points out a weak point in the rotary - the maximum PRACTICAL compression ratio is not determined by detonation (as is common in recips) but by the ability of the burning charge to pass through the rotor depression! If the depression is too small, pressure builds up in the vicinity of the trailing spark plug causing NEGATIVE WORK! This can reduce power, overheat the trailing spark plug, and subsa ntially increase the heat dumped into the oil and water. Therefore, the shape of the rotor depression is a cut-and try balancing act to find the best compromise. Before we leave the subject of the rotor depression, one more point - The physical shape of the depression at its leading edge has a lot to do with the maximum usable leading ignition advance. You can understand this better if you set a late-model rotary at 35 degrees BTC, take out the #1 leading spark plug, and took into the spark plug hole (a mirror and light might be helpful). What you will see is the curved flank of the rotor rather tight up against the bottom of the spark plug hole. If the spark plug were to ignite at this point, the engine might misfire because the flame front might be snuffed out (quenched) when it hit the rotor surface. If you now turn the engine to 20 degrees BTC, the way is open to burn into the mixture in the rotor depression. This is an important part of the reason why nearly all 1974 and later engines can run no more than 20 to 25 degrees ignition advance at high power (earlier USA model engines had a very long, shallow depression that allowed more advance). As I explained earlier, there are some parallels between rotaries and recips here - combustion chamber and piston top design are major concerns in recips - but there are some distinctive items to consider when working with rotaries.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
projectr13b
Mar 1, 2019 09:00 AM
ribbon
Nov 24, 2015 09:21 PM
HMSS013
Aug 28, 2015 03:08 PM
Rx808BI
Aug 9, 2015 10:06 AM
