Problem w/ Fuel
Old Jan 10, 2006 | 06:17 PM
RollinsX's Avatar
Problem w/ Fuel
I'm not entirely sure where this belongs, so I'm guessing.
I bought a brand new RX-8 on 12/31 and the last 2 times I tried to refuel it, the gas pumps cut off at 3/4 of a tank. I didn't even realize it until I turned the car on and the fuel gauge didn't go all the way up. Any idea what might cause this?
Thanks,
RollinsX
(2005 Titanium Gray 6spd)
Old Jan 11, 2006 | 06:56 AM
Go48's Avatar
Are you setting the nozzle for automatic shutoff? If so, the nozzle may be faulty and shutting off too early. I've had that problem before. If that's not the problem, the rollover flap inside the gas tank filler tube may be stuck, so take it in and have it checked out.
Old Jan 12, 2006 | 05:04 PM
Mazmart's Avatar
Or it's full and you don't know it. The guages in most cars register properly in a minute or so after filling. Just a thought.
Old Jan 12, 2006 | 05:45 PM
zoom44's Avatar
saddle bag tank- tank is full but the fuel hasnt shifted to the other side to register on the guage(just giving one reason- this hasnt happened on mine)
Old Jan 12, 2006 | 06:11 PM
StealthTL's Avatar
Metatron
Full is full....
So was it really full? How much gas went in?
S
Old Jan 13, 2006 | 01:59 PM
Juice's Avatar
I made some poos
This has also happened to me. Its not really that big a deal. I think that if you hold the pump completely perpendicular to the ground then it will fill it completely and if not it shuts off prematurely. I used to hold it at a slight slant just because the filler of the gas tank is kind of slanted and sometimes but not always it would stop at around 3/4 of a tank. Anyways, I have since held it perpendicular to the ground and not a problem.
RevMeHarder
Jun 1, 2026 02:30 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
XianUnix
Sep 29, 2015 03:48 PM
