greddy turbo vs t4 turbo
Old Jan 9, 2006 | 10:05 PM
freakn rican's Avatar
Question greddy turbo vs t4 turbo
hey guys just wondering the difference as far as air fuel mixtures between the small turbo compared to a bigger turbo. will the bigger turbo(t4) require a richer air fuel mixture compared to say the greddy turbo? just curious
Old Jan 12, 2006 | 10:01 AM
rkostolni's Avatar
The air fuel mixture isn't really dependent upon a particular turbo. A bigger turbo will flow more lbs/min of air, and will require more fuel, but the ratio stays the same.
Old Jan 12, 2006 | 03:10 PM
agoodcave's Avatar
The big difference between small and big is the matching it has with the engine. Compressor pressure ratio and flow is a function of speed, which comes from the turbine. A small turbine will spool up faster, build pressure ratio faster and match to the middle rpm of the engine.
However, to keep pressure ratio under control, you need a wastegate.
The larger compressor will match only at the high end because there won't be enough exhaust gas to power it until you get the rpms up.
Order "Fundamentals of TurboCharging" from ConceptsNREC. They also have a 4day course on it. It assumes you have an ME degree with a good understanding of turbomachinery.
If you can get the compressor maps that will really tell the difference.
Mike
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
jDt!
Oct 2, 2015 04:04 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
