remote power turn on wire..i know there is a DIY buuuutttt
Old Jan 6, 2006 | 09:37 AM
BomberNYC's Avatar
I know there is a DIY sticky but what i wanna know is how to access the accessory plug in the back. the picture just shows the plug being tapped already and doesnt go into how to run the plug underneath the center trim of the car. any help would be appreciated...
Attached Thumbnails remote power turn on wire..i know there is a DIY buuuutttt-pc072155.jpg
Old Jan 6, 2006 | 11:08 AM
StealthTL's Avatar
Metatron
Post Taps....
I recently tapped into that plug for my XM radio, in the trunk.
Pretty difficult if it's already wired like that, you'd have to get the whole plug assembly thru!
I taped coat hanger wire to my power wires, then pushed it from the rear passenger seatbelt buckle to the back of the plug, and wired it in, pretty simple.
S
Old Jan 6, 2006 | 11:18 AM
staticlag's Avatar
The Professor
S
I did mine pretty much the same way with a coat hanger.
Old Jan 6, 2006 | 11:20 AM
staticlag's Avatar
The Professor
Oh, running it under the center trim?
Well, your going to just have to remove the whole center piece to get under it. Its not too difficult, just start removing screws and pulling things and it should come off no problem.
Old Jan 6, 2006 | 01:14 PM
BomberNYC's Avatar
thanks for the input guys.. i'm just planning a step by step plan in my head on how to replace all the sepakers in my car and add a 10" sub. I'm planning on doing it this weekend and dont want to have any surprises when I do the install. got 2 hours and 46 mins left till i'm out of work! =)
Old Jan 6, 2006 | 02:04 PM
rkostolni's Avatar
I just removed a few screws so I could tilt the edge up and then tucked it underneath. I didn't have to remove the entire console.
Old Jan 6, 2006 | 02:05 PM
truemagellen's Avatar
Attracts tree branches
try this DIY...helps you take apart the center console (the entire thing)
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-s-video-into-nav-av-electronic-video-switcher-install-44095/
Old Jan 6, 2006 | 02:41 PM
BomberNYC's Avatar
https://www.rx8club.com/showthread.php?t=44095
thanks dood! that is the last thing I had a question about.. thanks to all for the help!
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
D13
Aug 28, 2015 12:21 PM
