Help With Head Unit
Old Dec 29, 2005 | 01:56 AM
RX8INCH's Avatar
RX8INCH
Exclamation Help With Head Unit
Well I took my car into Sound Waves in Canoga Park. To make a long sotry short... they installed 2 amps. JL 300/4 & 500/1. they took out my head unit and when they went to put it back the display dosent work... They said it loads discs but the disoplay dosent work.... They are telling me its some emc or something or other that needs a dics to be installed from the dealership... because the CD player (non bose) thought it was being stolen.... The dealer, who I called, siad they might have damaged the micro wires that connect to the front of the head unit(the screen/faceplate)... has anyone had this problem??? ITs takeing them forever...
They said it would be a 4 hour install now this is the second night I have left my car with them and Im loosing pacients with them? I paied them 400 to install 2 amps, 4 speakers and my sub.
Does anyone know what problem might have happened???
Please let me know
Rusty
Old Dec 29, 2005 | 02:25 AM
Tamas's Avatar
Registered Lunatic
There is no theft protection code built into the head unit - the dealer is probably right. They either damaged some wiring or a plug is not inserted properly.
Old Dec 29, 2005 | 03:09 AM
AutoBahnRX8's Avatar
Socially Distorted
Same thing happened to me. Took it to Mazda (Heidelberg) and they said some connector (details lost in translation) broke. They replaced it for FREE!
Old Dec 29, 2005 | 03:31 AM
you might want to read the diy on radio removal. that way you could make sure all the connectors are correct.
if so i would wonder what they tapped into.
Old Dec 29, 2005 | 07:04 AM
lurch519's Avatar
www.evoperform.com
i had a similar issue with my 8 awhile back. it could be a loose plug, or it could be a damaged pcb (printed circuit board) that sits right behind the face of the radio. that was the issue with mine. also with mine, my heater/ ac controls didnt work either, only thing that worked was my fan control.
Old Dec 29, 2005 | 12:52 PM
forbidden's Avatar
Does your climate control display work and do the climate controls themself work? If the climate control display is not working, it might be the molex for it is not plugged in. If the display is working, then they have damaged something in the install. This vehicle is not a easy task, this should serve as a reminder to all when they take their vehicle to any shop to have work done.
Old Dec 29, 2005 | 01:25 PM
RX8INCH's Avatar
RX8INCH
i just got a call from then and they said they it was fixed and my car should be done in about 30 min... thanks fdor your help guys... I hope its fixed right.. the shop was a good shop, i have seen their work... but just incase they are trying to pull the wool over my eyes this information will help... thanks
Rusty
Jelliott5384
Oct 26, 2016 05:15 PM
olyrx7
Oct 26, 2015 09:23 AM
ShellDude
Oct 1, 2015 09:55 PM
Stubbs
Sep 27, 2015 04:06 PM
mattymack
Sep 6, 2015 10:33 PM
