painting calipers
Old Dec 9, 2005 | 03:04 PM
terretsboy's Avatar
Official "That Guy"
painting calipers
I was wondering if this paint would be okay to put on my calipers or does it not have the necesary heat resistance? How can I find out? Does anyone know if this works like it says it does?
The paint:
http://store.newlevelmotorsports.com/micoshpasy.html
Old Dec 9, 2005 | 03:07 PM
RX8SpdDmn's Avatar
The paint:
That isn't high-temp paint.
Don't expect too much even from high-temp paint. I burnt mine off heat cycling my brake pads.
The best solution is to remove the calipers and have them powdercoated.
Old Dec 9, 2005 | 03:10 PM
terretsboy's Avatar
Official "That Guy"
Is there any way i can prep the calipers so that I could use that paint?
Old Dec 9, 2005 | 03:11 PM
RX8SpdDmn's Avatar
yeah, just paint them and then NEVER step on your brakes. The heat will boil the paint right off.
Old Dec 9, 2005 | 03:38 PM
Glyphon's Avatar
脾臓が痛みました
you'll need to use a high temperature paint, such as engine, brake, or grill paint.
but, if you prep it right, it will last years (i'm speaking from personal experience with a previous car). all you need to do is clean the surface really well, and then apply a few coats, allowing the paint to dry inbetween each coat according to the directions.
when i did it before, i used a glossy black grill paint, and it still looked great 3 years later when i sold the car. no fade and no cracking/peeling. but any high temp paint should work and last. just follow the instructions. but i don't any of those come as a prismatic paint.
Old Dec 9, 2005 | 03:54 PM
terretsboy's Avatar
Official "That Guy"
what about for my radiator? (I think thats what is behind the fog lights) Or does that have the same heat problem?
Old Dec 9, 2005 | 03:55 PM
RX-Aight's Avatar
shaaaaaa...
you could maybe use a clear coat to seal the paint in after painting.
Old Dec 9, 2005 | 03:59 PM
Tigster's Avatar
RX8 ADDICTED!!!
the clear coat will come right of too. Just use a high temp paint.
The radiator gets hot too.
Old Dec 9, 2005 | 07:18 PM
RX8SpdDmn's Avatar
Those are your oil coolers. Don't paint them, or they won't work!! Their job is to transfer heat away from the pipes through the fins that you see. If you coat them with more paint, you'll inhibit them from doing what they're supposed to do and possibly hurt the motor.
Old Dec 9, 2005 | 07:55 PM
NgoRX8's Avatar
Ok, I actually have experience with mirage paint. I used it with polak's rx8 stencils and it is fine. I used only that little middle section on the caliper so the heat doesn't get there as much. However, I think it wouldn't be wise to use these for the whole caliper. The paint would come right off. It is also a real pain to use these for the calipers. I used about 9 coats for the small sections, then painted the caliper red. It is really not worth it.
Old Dec 9, 2005 | 08:04 PM
NgoRX8's Avatar
Here's a pic of VHT Red Caliper Paint with ICE Mirage Paint
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
TheRedRotor
Sep 22, 2015 05:30 AM
