wouldnt start
Old Dec 6, 2005 | 07:35 AM
DropTheHammer's Avatar
wouldnt start
car was warmed up driven 2 miles and sat for about an hour and a half , when i went to start the car it just cranked, so i shut it off waited 30 seconds or so, and cranked it again this time i let it crank 4 or 5 times and it finally turned over and when it did it sounded weak. once it started every thing seems fine. any ideas?
Old Dec 6, 2005 | 08:25 AM
any ideas ?
Old Dec 6, 2005 | 12:29 PM
demob05's Avatar
Have you checked the battery?? If it's stock and you've had your 8 for a while, it may be weak.
Old Dec 6, 2005 | 04:23 PM
actually i just bought it last week , only 130 miles on her now
Old Dec 6, 2005 | 04:47 PM
Go48's Avatar
This engine usually cranks a few cranks, like RRRRR, before it will start. Is that what you're referring to when you say "4 or 5 times"? If so, that is not unusual. It will never start without a few cranks/revs of the engine. As far as sounding weak I assume you are talking about the sound of it cranking as compared to the same sound in a piston engine? Ya can't really make that comparison since they are different animals and they definitely do sound different when cranking. So drive the car and don't worry about it unless it doesn't start at all. Then worry alot.
Old Dec 6, 2005 | 05:31 PM
sounds good to me if it is a usual thing for this car.. time to go to work and c if sher does it again lol.
Old Dec 6, 2005 | 05:58 PM
tiggerlee's Avatar
May Cause Anal Leakage
Interesting. I've never had this happen. Mine's always started right up,no hesitation what so ever. I could see this if he were starting it in very cold weather OR if in fact the battery is weak.
Originally Posted by DropTheHammer
car was warmed up driven 2 miles and sat for about an hour and a half , when i went to start the car it just cranked,so i shut it off waited 30 seconds or so, and cranked it again this time i let it crank 4 or 5 times and it finally turned over,.....
DropTheHammer- I'd keep an eye on it. If it continues take it and have the battery checked. Batteries do go bad,even in new cars. Also if your living in a extremely cold area it may take a bit more to start it(from a cold start). This is not unusual.
therm8's Avatar
Bummed, but bring on OU!
Warmed up is relative. The car won't really warm up at idle, unless you idle for a very long time. I consider it "warmed up" 5 minutes after the temperature needle hits the normal position. This allows for all of the coolant and oil to be at normal operating temp.
The short trip, long shutoff period is the number one cause of flooding. When the car didn't start the first time, this caused a heavy wetting of the plugs, I'm thinking. That's why the car was "weak" after it did start. Familiarize yourself with the deflood starting procedure in the manual, just in case this happens again. Continually trying to start it the "normal" way can aggravate the semi-flooded condition and drain the battery. The deflood procedure allows cranking of the engine without supplying fuel.
Old Dec 7, 2005 | 07:45 AM
yes, i will be reeading on how to deflood.... and this morning after work 25 degrees out , first shot quick turn of the key .. and same after i got out of the gym about one hour later started rite up again.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
T_Mags
Jul 24, 2015 11:29 AM
