Subwoofer Air Space
Old Nov 28, 2005 | 07:37 AM
said7's Avatar
Subwoofer Air Space
In a sealed box with a 12 inch sub typically how much air space is needed on the front of the subwoofer. Right now the way the box fits i only have about 2 inches between the fron of the sub and the floor.
Will this effect the sub dramatically. Even break it?
Old Nov 28, 2005 | 09:57 AM
truemagellen's Avatar
Attracts tree branches
need a lot more info here
what kind of sub? specs?
also why is the face of the sub facing the floor??
pics of setup?
etc.
any more info will be helpful
Old Nov 28, 2005 | 04:30 PM
said7's Avatar
pics of setup?
etc.
Thanks for the replies true adn dj.
Heres the box that i have.
http://www.polkaudio.com/caraudio/products/mm12/
Problem is that its too tall to fit straight up in the back of the trunk. The only way to make it fit is to put the sub face down and the plexi facing the outside of the strunk. Which looks really sweet btw.
This only leaves about 2 inches of clearence if i raise the box up off the floor (sub face down).
Its has a 12 inch elcipse titanium sub in it. Not sure of the model number.
And its being pushed by 350 watts mtx amp.
Old Nov 28, 2005 | 05:52 PM
oh ic, wow I'm not sure what to do there...but best position for the sub is to have it face the rear of the car IMHO, my box is also for a 12 but fits upright, I should show you a picture since I got mine for only $26 shipped you might want to sell your box and go that route...the eclipse sub doesn't need that much air if I remember hmm
Old Nov 28, 2005 | 10:33 PM
NVMYGT's Avatar
IM2BZ2P
truemagellen,
does your sub fit all the way back against the seats or is it in the deeper part of the trunk?
Old Nov 28, 2005 | 10:47 PM
mine is just a bit too tall to fit under the metal brace but it does slide in under the amplifier so that it does not hang over the depression in the trunk at all...the boxes depth is not huge at all...nice thing is it fits so snugly that I don't need to do any mounting work, just slide it in I'll take pics when I can, '4yrs to supercharge' bought the box for me and will have the same setup soon with a higher power amp
since I have hundreds of wires running behind there and an avelectronics switcher and some noise filters for the xbox I don't mind the extra space, once I have some more time I'm going to probably add one or two midbass speakers to the pass through with a small box behind my current 12inch box, all removable, I'm a skier so I'll need the pass through every once and a while, removing the subs is easy
Old Nov 29, 2005 | 06:03 AM
BoosTED's Avatar
Not too sure about adding mids to the center pass-through True.
The box is 14 inches tall and like he said not very deep.
Here are the dimensions: 18"L x 14"H x 4.75"D (top)/8.25"
This is where we got them (they come as a pair):
http://electrogalaxy.dtopinc.com/ind...bject=xes212tp
Here are more enclosures:
Old Nov 29, 2005 | 07:38 AM
said7's Avatar
Hmmmm, I guess ill just try it out see how it sounds. I really like the look of the box .
What line converter do you guys use> I need to order me one so i can finally test this out.
Old Nov 29, 2005 | 08:29 AM
I just ordered Dave Navone's NE-7V for $19.95, my amp has a lowpass crossover so I don't really need the fancy AL6 stuff I spoke to him yesterday to confirm this is the best for my application.
http://www.davidnavone.com/adaptor_products.htm (second one down)
Old Dec 5, 2005 | 10:26 AM
said7's Avatar
I got my NE7v today in the mail. Do i have to connect it to both rear speakers? or just one?
Old Dec 5, 2005 | 10:55 AM
BoosTED's Avatar
Both since you will want to bridge the amp to make it mono.
You can do it by the amp since the wires for the two speakers will be together.
Old Dec 5, 2005 | 03:22 PM
BoosTED's Avatar
Originally Posted by djseto
Not necessarily true. You bridge the amp by connecting the two channels of the amp, but if its being fead a mono signal, then it only needs one channel of input. If you use the LOC with only one channel, then you will only get 1 channel's worth of bass, but that shouldnt matter since both speakers should be getting the same amount of bass from the source. If anything I would connect them both just for future expandibility, but if your amp is bridged mono, it should only need one channel of input.
As long as a person hooks up both sets of wires to the LOC then a person can bridge. It wouldn't do much bridged if only one set of speaker wires were hooked up because the amp when bridged would only put out + or - . With only one of these there will not be any sound coming from the sub.
Yes a person could hook both sets up to just one speaker but how much draw does the LOC pull off of the wire? It is better to balance it out by tapping two channels right and left.
The directions for this converter do say to tap as close to the head unit as possible to prevent a ground loop.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Danield97
Sep 30, 2015 05:59 PM
Learners_Permit
Sep 27, 2015 07:38 PM
