Differences between RX8 and RX7 Engine
Old Nov 12, 2005 | 03:57 PM
cas2themoe's Avatar
PoloRican Rotary
Question Differences between RX8 and RX7 Engine
I know both the RX7 and the RX8 have the 13B in them. But besides the ports being moved to the side on the New Renesis, what are the main differences between the two Engines?
Old Nov 12, 2005 | 04:17 PM
Ike's Avatar
Ike
Blue By You
cas
Old Nov 12, 2005 | 04:28 PM
StealthTL's Avatar
Metatron
If I recall.....
Inside, I think the main difference is lighter rotors.
S
Old Nov 12, 2005 | 05:01 PM
rotarygod's Avatar
Different rotors, lighter with larger oil passages inside. Lighter counterweights to match.
Lighter flywheel.
Different stationary gears. Although interchangeable, the RX-8 gears are stronger.
Obviously different rotor housings and irons.
Coolant seals moved from the irons to the rotor housings.
Shorter apex seals. They are a stronger material though.
Addition of cutoff seal on the rotor sides.
Wedge shaped side seals as opposed to older, thinner flat style.
Steel corner seal insert instead of old rubber ones.
Dual oil injectors per rotor housing. Old style was 1 per housing and either 1 or none on the manifold.
I probably forgot something somewhere but basically nothing is shared between the 2 engines although certain pieces can be made to work on the other with some effort. Everything else that is bolted to the engine is different.
Old Nov 12, 2005 | 05:39 PM
cas2themoe's Avatar
PoloRican Rotary
Lighter flywheel.
Thanks. You really know your stuff.
Old Nov 12, 2005 | 06:08 PM
Mugatu's Avatar
Even My Dog Searches
cas
Old Nov 12, 2005 | 07:38 PM
Moostafa29's Avatar
Storm Trooper
What is this cas???
Old Nov 12, 2005 | 08:04 PM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Thanks RG, I wondered about this also...
Old Nov 13, 2005 | 02:41 AM
Ike's Avatar
Ike
Blue By You
Originally Posted by Mugatu
cas
chrysler
Old Nov 13, 2005 | 04:07 AM
rotarygod's Avatar
I have no idea how that is relevant?
Old Nov 13, 2005 | 04:28 AM
Zuhalter Vati's Avatar
LMAO...I just think it is funny...but it could be the 151 talking tonight
Old Nov 14, 2005 | 09:35 AM
snizzle's Avatar
Shakezula, the Mic Rula
Originally Posted by IkeWRX
chrysler
as in Chrysler Crossfire?
I hope it's the 151 talking
Old Nov 14, 2005 | 11:58 PM
Nocty's Avatar
Wink
:: looks at his '83 12A/auto ::
:: looks at the RX8 spec sheet ::
I'd say about 100 kW, if not more...
Old Apr 9, 2016 | 11:17 PM
Rx8boy19's Avatar
Questions about turbos?
Will turbos from a 94 rx7 fit into a 2004 rx8? Can anyone help me.
Old Apr 10, 2016 | 02:00 AM
sinkas's Avatar
No mo
Old Apr 10, 2016 | 11:11 AM
ZiG's Avatar
ZiG
05 GT
Well, they'll fit in the trunk if you're planning to take them to the scrap yard?
Old Apr 11, 2016 | 11:46 PM
Rx8boy19's Avatar
Why do you say that? Should II just get a new turbo setup to put in my 8?
Old May 16, 2016 | 06:54 PM
Ethanman's Avatar
Camaro
Should I be able to beat a 5th gen Camaro ss with a turbo setup?
Old May 16, 2016 | 08:17 PM
ZiG's Avatar
ZiG
05 GT
lol, no.
Old May 17, 2016 | 03:22 PM
EarlQHan's Avatar
CAS = crank angle sensor
Old May 18, 2016 | 10:37 PM
djgiron's Avatar
Beat how, in a drag race or around a short track? No and depends.
mr. GrandGame
Sep 9, 2025 10:41 PM
F51
Aug 2, 2021 04:07 AM
vapor2
Nov 3, 2020 03:38 PM
RX7.9
Jul 20, 2015 12:01 PM
ironj221
Jul 16, 2015 10:16 PM
