Inside exhaust tips dirty on every 8?
Old Nov 8, 2005 | 09:40 PM
mauricio's Avatar
Arrow Inside exhaust tips dirty on every 8?
HI my 8's inside exhaust tips are always super dirty is this the same for everyone or is it the gas I"m currently using or what is it?
Old Nov 8, 2005 | 09:47 PM
zoom44's Avatar
same on everyones
Old Nov 8, 2005 | 10:01 PM
micdark's Avatar
At least part of the cause is probably the oil being injected into the engine -- it is unlikely that the motor oil burns as cleanly as gasoline.
Old Nov 8, 2005 | 10:29 PM
dmorales's Avatar
Spin Triangles! Spin!
Same as every rotary ever.
________
The View Condo Prathumnak
Old Nov 8, 2005 | 11:12 PM
RX8SaxMan's Avatar
Haven't there been some reports that higher-milage 8's experience less soot in their tailpipes? Like the possibility that the ECU leans it out after a certain point
Old Nov 9, 2005 | 05:31 AM
Go48's Avatar
Some other cars have the same black carbon on the tailpipes as well. Just look around. In some cases, the design of the tailpipe ends/extensions make this deposit more noticable. Such is the case with the RX-8 OEM tailpipes.
Old Nov 9, 2005 | 05:57 AM
Bastage's Avatar
DEVILMAN
cleaning the soot
What's the best stuff to use to clean this soot?
Old Nov 9, 2005 | 06:43 AM
Spin9k's Avatar
Momentum Keeps Me Going
A small dab of almost any polishing compound will take it off in a couple rubs...
Old Nov 9, 2005 | 06:52 AM
YT1300's Avatar
Turning and burning
Warm water and a mild detergent will do the trick. My old B16A2 Civic had the same problem of running rich when VTEC kicked in, and the little spot clean every once in a while was easy.
Old Nov 9, 2005 | 08:33 AM
Mugatu's Avatar
Even My Dog Searches
it's a muffler, people. it's meant to be for the wasted fumes of the engine. waste is dirty. c'mon, now.
Old Nov 9, 2005 | 08:36 AM
dazygirl415's Avatar
NEVR Dull works well for the hard to get off grime on the tips. I shined up the outer edges but left the insides alone. What's the point if they're used for waste fumes anyway?
Old Nov 9, 2005 | 08:18 PM
BodyGuy's Avatar
cleaning the inside of the exhaust tip to me would sorta be like sticking my finger up my ***, sure clean around the hole.......don't go inside!
Old Nov 9, 2005 | 08:47 PM
RX8SaxMan's Avatar
I use Nevr Dull as well every time I wash the car. It cleans em up nicely
Old Nov 9, 2005 | 08:55 PM
xrider01's Avatar
127.0.0.1
i only clean the outside of the tips. it's the only worthwhile part of the exhaust tips to clean since carbon deposits are coming out of the pipes
Old Nov 9, 2005 | 09:08 PM
midlifer's Avatar
Nevr Dull!
Bob
Old Nov 9, 2005 | 09:56 PM
woodysjh's Avatar
I already searched!!!!!!!
Augh......well to me it isn't the same thing, I don't thing your car will tense up when cleaning the exhaust pipe.
Old Nov 9, 2005 | 10:13 PM
staticlag's Avatar
The Professor
Amazingly, I have had very good results with zaino to polish them and keep them clean.
Old Nov 10, 2005 | 11:23 AM
jp4wd's Avatar
The Big kahuna
Metaphor of the year....
Old Nov 10, 2005 | 11:56 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
^^^ I sure don't understand your emoticons.
*** HOLE ??? C'mon, the exhaust tip is no more disgusting than any other part of the car prone to getting dirty. Cleaning inside the exhaust tip ranks with cleaning and dressing inside the wheel wells, inside the front air scoop, etc.--a little compulsive, maybe. But it sure improves the appearance of the vehicle.
Once the tips are well-polished, keeping them clean is simple--usually just soap and water, an occasional NEVR DULL inside and out.
Old Nov 10, 2005 | 12:19 PM
unless you can easily afford weekly visits to a pyschiatrist I would suggest contacting your local Dirty Exhaust Tips therapy support group
Old Nov 15, 2005 | 01:02 PM
LBrx8fan's Avatar
Body Guy, I havent laughed so hard in days, thanks!!
Old Nov 16, 2005 | 01:28 AM
mazdabob's Avatar
I found something that works well at keeping exhaust tips clean - Rejex.
http://www.corrosionx.com/rejex.html
I just made an 1100 mile trip, and it worked well on my tips, and rear end. The C6 rear end really accumulates dirt, and Rejex did a good job of keeping it clean. You can also use it on wheels, and everything else for that matter.
Old Nov 16, 2005 | 11:30 AM
Nubo's Avatar
Lubricious
Oh come on, once you get started, there are no end of things to clean!
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
titaneum_grey
Sep 16, 2015 11:51 PM
